(16C) Modular Exponentiation - wynen - 10-26-2018 05:58 PM
Computing \(base^{exponent} \bmod modulus\) for positive integer base, exponent and modulus is a common task in cryptography. The HP-16C is ideally suited to implement a binary exponentiation algorithm.
function modular_pow(base, exponent, modulus)
if modulus = 1 then return 0
Assert :: (modulus - 1) * (modulus - 1) does not overflow word size
result := 1
base := base mod modulus
while exponent > 0
if (exponent mod 2 = 1):
result := (result * base) mod modulus
exponent := exponent >> 1
base := (base * base) mod modulus
return result
from wikipedia: https://en.wikipedia.org/wiki/Modular_exponentiation
The HP-16C has a maximum word size of 64bit, so the maximum possible modulus should be \(2^{32}-1\) (about \(10^9\)). For larger values, the two (modular) multiplications could be implemented in a similar binary multiplication algorithm, but fortunately the HP-16C allows double precision multiplication and division. Using this feature, the maximum values for the modulus are \(2^{63}-1\).
001 43,22,A g LBL A x: modulus, y: exponent, z: base
002 44,0 STO 0 R0 = modulus
003 33 Rdown
004 34 x<->y x: base, y: exponent, z: ?, t: modulus
005 43,33 g Rup
006 42,9 f RMD
007 44,1 STO 1 R1 = base mod modulus
008 43,35 g CLx
009 1 [1] x: result = 1, y: exponent
010 44,2 STO 2 R2 = result
011 33 Rdown
012 43,22,9 g LBL 9 x: exponent
013 43,40 g x=0
014 22,1 GTO 1 if exponent == 0 return result
015 42,b f SR exponent = exponent >> 1
016 43,6,4 g F? 4 Carry set?
017 43,2 g x<0 yes, but x<0 is always false (because of shift right)
018 22,2 GTO 2 Carry not set
019 45,2 RCL 2 Carry set
020 45,1 RCL 1 x: modulus, y: result, z: exponent
021 43,20 g DBLx x: xy..., y: ...xy, z: exponent
022 45,0 RCL 0
023 43,9 g DBLR x: xy mod modulus, z: exponent
024 44,2 STO 2 result = (result * base) mod modulus
025 33 Rdown x: exponent
026 43,22,2 g LBL 2
027 45,1 RCL 1
028 36 ENTER x: base, y: base, z: exponent
029 43,20 g DBLx x: xy..., y: ...xy, z: exponent
030 45,0 RCL 0
031 43,9 g DBLR x: xy mod modulus, z: exponent
032 44,1 STO 1 base = (base * base) mod modulus
033 33 Rdown
034 22,9 GTO 9 x: exponent
035 43,22,1 g LBL 1
036 45,2 RCL 2
037 43,21 RTN
Quote:usage:
[f][UNSGN] 64 [f][WSIZE] base [ENTER] exponent [ENTER] modulus [GSB][A]
Register:
R0: modulus
R1: base
R2: result
Best regards
Hartmut
