"Turbo" - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: "Turbo" (/thread-1189.html) Pages: 1 2 |
RE: "Turbo" - Claudio L. - 06-20-2014 01:32 PM (04-27-2014 03:38 PM)jebem Wrote: 1) Overclocking the 49G+ Actually, Al's tools were never very safe, as they change the clock of the CPU only, and that affected the memory speed as well (you hit it right in the nail). To do proper turbo nowadays, you need to use hpgcc. The clock changing procedure was completely reimplemented in hpgcc and hpgcc3 to make it safe to use. It adjusts CPU clock, but also the memory clock is adjusted to keep the memory working at the same original speed, so it doesn't crash. If somebody were to improve Al's tools by looking at how hpgcc corrects the memory timings, it could be made to work consistently on all models. However, I'm not sure this qualifies as overclocking. The ARM chip in the 49 series has selectable clock up to 200 MHz, so we are never exceeding any design parameters. So this is one of the cases where "Turbo" is not the same as overclocking. Claudio RE: New "Old" Member - Raymond Del Tondo - 06-20-2014 02:27 PM So I'll throw in my software Turbo for the HP 48G series: SpeedUI. If you're used to the normal, built-in UI, you'll see and feel the difference immediately:-) RE: "Turbo" - Jim Horn - 06-20-2014 03:08 PM Yes, the HP-67 could be run at roughly double speed as well by changing the capacitance of its LC clock oscillator. If you lifted one end of the stock capacitor from the circuit board and wired a second smaller value in series with it, it ran faster. By shorting the added capacitor, it ran at the original speed. My '67 ended up with a flush mounted toggle switch that did just that as well as a momentary contact phase zero interrupt pushbutton that allowed creation of virtually any desired bit pattern in memory. Great for creating custom register data on cards to explore the then-new HP-41C: one weekend I pressed around 20,000 keystrokes doing same. Aah, the days of free time! |
