Schur-Cohn Algorithm - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Software Libraries (/forum-10.html) +--- Forum: HP-41C Software Library (/forum-11.html) +--- Thread: Schur-Cohn Algorithm (/thread-11957.html) |
Schur-Cohn Algorithm - Eddie W. Shore - 12-16-2018 06:44 AM Source: Henrici, Peter. Computational Analysis With the HP-25 Calculator A Wiley-Interscience Publication. John Wiley & Sons: New York 1977 . ISBN 0-471-02938-6 Introduction: The Schur-Cohn Algorithm tests whether the roots of a polynomial p(x) lies with in the unit circle. That is for the polynomial p(x): p(x) = a_0 * x^n + a_1 * x^(n - 1) + a_2 * x^(n - 2) + ... + a_n For all the roots of p(x), r_0, r_1, r_2, ... , r_n , |r_k| < 1. The test covers both real and complex roots. Keep in mind that this test doesn't tell us what the roots are, only a clue to whether the roots lie in the unit circle or not. The Schur-Cohn Algorithm returns the test answers b_0, b_1, etc. If |b_k| < 1 holds true for each b_k for k = 0 to n, then we can conclude that |r_k| < 1. The following program is adopted from Peter Henrici's book Computational Analysis With the HP-25 Pocket Calculator [Henrici, 111] for the HP 41C and the Swiss Micros DM 41L. The program deals with polynomials up to the fourth order, but can be expanded on an RPN calculator with more program space and memory registers. Instructions: For the fourth order polynomial: p(x) = a_0 * x^4 + a_1 * x^3 + a_2 * x^2 + a_1 * x + a_4 To the coefficients in the following registers: R00 = a_0 R01 = a_1 R02 = a_2 R03 = a_3 R04 = a_4 The test results will pop momentarily during execution. The program is done when after four test values, 4 is in the display. The last test value is stored in R05. DM 41L and HP 41C Program: SCHUR (77 bytes, 11 registers of memory) Code:
Link to blog post entry: https://edspi31415.blogspot.com/2018/12/dm-41l-and-hp-41c-schur-cohn-algorithm.html |
