Torture tests: what do they mean? - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: Not HP Calculators (/forum-7.html) +--- Forum: Not remotely HP Calculators (/forum-9.html) +--- Thread: Torture tests: what do they mean? (/thread-1309.html) |
Torture tests: what do they mean? - jebem - 05-13-2014 10:58 PM This site calls my attention to how different calculators are concerning the used algorithms to get a result for a specific problem. For example, the tan(355/226) has an ideal result of -7497258.185... It gives me the following results (in Radian mode) for these models: HP-Prime: -7497089.06508 HP-50G: -7497089.06508 Casio FX-991DE PLUS: -7497258.44 WP-34S: -7497258.194 Clearly the HP models algorithms deviates somehow from the expected result, contrary to what the Walter&Pauli algorithms which are giving fantastic close results. My new acquisition, the Casio FX-991DE PLUS, is a nice surprise with a close second in this torture test, probably because it uses 15 digits internally like many others Casio calculators. RE: Torture tests: what do they mean? - Paul Berger (Canada) - 05-14-2014 01:03 AM On a prime in CAS mode I get -7.49725847868E6. RE: Torture tests: what do they mean? - Paul Dale - 05-14-2014 01:24 AM To toss a spanner in the works a little. The 34S is getting the correctly rounded result for its precision. Code: Formula Exact result 16 digit rounded result This final number is what the 34S is giving, the correctly rounded sixteen digit result that was asked for. - Pauli RE: Torture tests: what do they mean? - DavidM - 05-14-2014 02:05 AM (05-13-2014 10:58 PM)jebem Wrote: For example, the tan(355/226) has an ideal result of -7497258.185... As Pauli has mentioned, the 34s is giving the correctly rounded result to 16 digits. Likewise, I believe you will find that the Prime/50g results listed above are the correctly rounded results to 12 digits for a 12-digit input parameter. In other words, the results are not for the exact value of 355/226, but rather 355/226 rounded to x digits. For what it's worth, a SysRPL program using 15-digit extended reals on a 50g gives a result of -7.49725824999067E6 (-7497258.24999067). A quick check with Wolfram Alpha shows this to be a correctly rounded result to 15 digits for the 15-digit input of "tan(1.57079646017699)". RE: Torture tests: what do they mean? - Paul Dale - 05-14-2014 03:35 AM Using my trusty 34S and the RSD function, I've produced a table of the corectly rounded results for differing numbers of significant digits. Code: digits 355/226 tan(column 2) The Prime and 50G are both producing the correctly rounded twelve digit results. The fifteen digit extended precision on the 50G is also getting the answer correct. I've no idea what the CASIO is doing ![]() - Pauli RE: Torture tests: what do they mean? - DavidM - 05-14-2014 05:35 AM It appears that the original author of the "torture test" chose 355/226 due to its rough approximation of \(\pi\)/2. I wonder how much more interesting Pauli's table would be with \(\pi\)/2 as the target of the TAN function? ![]() 50g: Code:
I'd be especially curious as to what the Casio results are for that. This all seems very reminiscent of a recent post in the HP Prime section. While I'm not trying to re-hash the issues brought up in that discussion, I think it does point out the importance of understanding the implications of guard digits, precision, and how a given calculator displays full values vs. rounded representations of internal numbers. RE: Torture tests: what do they mean? - Dieter - 05-14-2014 05:49 AM (05-13-2014 10:58 PM)jebem Wrote: For example, the tan(355/226) has an ideal result of -7497258.185... Sure. They all do not calculate tan(355/226). The argument cannot be respresented exactly in 10, 12 or even 16 or 30 digits. All you can expect on a 12-digit machine is a 12-digit result for a 12-digit-rounded input, i.e. tan(1,57079646018). Take a look at the derivative. At 355/226 it is 1/cos²(355/226) = 5,62 E+13. On an n-digit calculator, the input may be off by 5 E–n (half a ULP), which means that the tangent can by off by 2,81 E+14 · 10–n. For a 12-digit machine this means that the result has a tolerance of ±281. In other words: you cannot even trust the three last digits left (!) of the decimal point! Your results prove this. The possible relative error is 3,7· 107–n, which means that 8 digits are lost and only n – 8 digits of the result can be trusted. Quote:Clearly the HP models algorithms deviates somehow from the expected result, contrary to what the Walter&Pauli algorithms which are giving fantastic close results. Even with a "perfect" algorithm a 10-digit calculator will only get two (!) digits right, and on an 8-digit machine the result is completely meaningless. If you want 12 valid digits in the result, you need 20 digit precision for 355/226. We should always keep in mind that our calculators usually do not work with exact numbers. So the output cannot be exact either. Dieter RE: Torture tests: what do they mean? - HP67 - 05-14-2014 06:19 AM (05-14-2014 05:35 AM)DavidM Wrote: point out the importance of understanding the implications of guard digits, precision, and how a given calculator displays full values vs. rounded representations of internal numbers. Where can one learn about this? Some of you guys seem to really understand this well and it is an interesting topic I would like to know more about. RE: Torture tests: what do they mean? - Paul Dale - 05-14-2014 06:30 AM (05-14-2014 05:35 AM)DavidM Wrote: I wonder how much more interesting Pauli's table would be with \(\pi\)/2 as the target of the TAN function? Assuming the 34S calculates accurately this close to the pole: Code: digits pi/2 tan(col #2) rounded(pi)/2 tan (col #4) The second column is round(pi/2). The fourth is round(round(pi)/2) but only where it is different. The difference for fifteen digits from the above is that 1.57079632679489 isn't correctly rounded ![]() As Deiter wrote, we're really in a steep part of the tan function here. - Pauli RE: Torture tests: what do they mean? - Manolo Sobrino - 05-14-2014 07:47 AM A machine that can give you x accurate digits for all the domain is not working internally with just x digits. As was discussed in another thread, the HPs are likely using 2x significant digits in their trigonometrics. The bizarre thing here is that rounding to x for the input data and the arithmetics and then performing the cordic calculations with 2x tables is considered consistent. In this case, the Mathematica arbitrary precision results are: 12 significant digits: N[355/226, 12] = 1.57079646018 Tan[1.57079646018`12] = -7.4971*10^6 Now, 355/226 rounded to 12 and then calculating the tangent with 24: Tan[1.57079646018`24] = -7.4970890650760106*10^6 Rounded to 12 for output: N[%, 12] = -7.49708906508*10^6 There you go. You need at least 19 significant digits to get that. I don't know what Casios do here. They should get -7.4972582*10^6, yet they are calculating Tan[1.5707961934128066`16]. There must be a small flaw in their implementation of the tangent. RE: Torture tests: what do they mean? - Paul Dale - 05-14-2014 08:03 AM HP's have three guard digits typically. They do have very carefully designed algorithms. Pauli RE: Torture tests: what do they mean? - DavidM - 05-14-2014 03:10 PM (05-14-2014 06:19 AM)HP67 Wrote: Where can one learn about this? Some of you guys seem to really understand this well and it is an interesting topic I would like to know more about. By no means would I consider myself in the category of those who understand this well, but I'm at least aware enough of it to be suspicious whenever discussions about disparate results from different platforms come up. It's no small coincidence that the "targeted values" of these functions are almost always chosen to be near points of inflection, infinity, discontinuities, extremes, etc., because differences in implementation will more often be magnified in those areas. To me, the more subtle and somewhat philosophical issue is that of how "internal" numbers are displayed when not in an exact/CAS mode. If you divide 1 by 3 on your favorite calculator, then multiply that result by 3 again, what should the result be? There are valid arguments for and against implementations with different answers to that question. Knowing how your chosen platform responds to that type of sequence can make a difference in how you approach a solution in some cases. (05-14-2014 06:30 AM)Paul Dale Wrote: The difference for fifteen digits from the above is that 1.57079632679489 isn't correctly rounded Indeed! Interesting (though contrived) example of how small differences in implementation can sometimes result in large numerical differences. (05-14-2014 06:30 AM)Paul Dale Wrote: As Deiter wrote, we're really in a steep part of the tan function here. Which is no accident. We were intentionally taken there by the designer of the test. RE: Torture tests: what do they mean? - jebem - 05-14-2014 06:20 PM (05-14-2014 05:35 AM)DavidM Wrote: It appears that the original author of the "torture test" chose 355/226 due to its rough approximation of \(\pi\)/2. I wonder how much more interesting Pauli's table would be with \(\pi\)/2 as the target of the TAN function? Well, my Casio FX-991DE Plus refuses to give me an answer for that question other than this: Tan(pi/2) = "Math.-Fehler" This is a German edition machine, you know. So that sentence means that I did something that can not exist in this calculator small brain - what is the meaning of infinite by the way? RE: Torture tests: what do they mean? - Dieter - 05-14-2014 07:15 PM (05-14-2014 06:20 PM)jebem Wrote: Well, my Casio FX-991DE Plus refuses to give me an answer for that question other than this: This simply means "math error". So it's not a specific detailled error message. Obviously the Casio handles "pi/2" as a special case and does not translate the input to tan(1,57079632679...). Quote: - what is the meaning of infinite by the way? I am sure you know the meaning of "infinite". ;-) If it's the German term you're asking for: that's "unendlich". Dieter RE: Torture tests: what do they mean? - Dieter - 05-14-2014 07:23 PM (05-14-2014 07:47 AM)Manolo Sobrino Wrote: A machine that can give you x accurate digits for all the domain is not working internally with just x digits. As was discussed in another thread, the HPs are likely using 2x significant digits in their trigonometrics. Most HP calculators since the HP-91 work with three additional digits. For internal calculations, that is. These digits are not presented to the user. The input has always just the number of digits you can enter. That's the crucial point here: you would need a 20-digit input for 355/226 in order to get the output (the tangent) correct to 12 digits. As already stated, you cannot trust the last eight digits. Quote:There you go. You need at least 19 significant digits to get that. Let's make this 20. See my previous post and, even better, Pauli's table with all results from 8 to 20 digits. The tangent of the 19-digit respresentation of 355/226 is off by 3 units in the 12th digit. Dieter RE: Torture tests: what do they mean? - Manolo Sobrino - 05-14-2014 08:49 PM (05-14-2014 07:23 PM)Dieter Wrote: Most HP calculators since the HP-91 work with three additional digits. For internal calculations, that is. These digits are not presented to the user. The input has always just the number of digits you can enter. That's the crucial point here: you would need a 20-digit input for 355/226 in order to get the output (the tangent) correct to 12 digits. As already stated, you cannot trust the last eight digits. I don't know. Testing the 50G while trying to understand the behaviour of the Prime I found that arguments are passed to functions rounded to 12. That's what they do here, they round 355/226 to 12. If they had considered 15 digits they wouldn't have got those results. There's just no way to reproduce that while rounding 355/226 to 15... In fact, the last 8 digits are accurate for the argument rounded to 12 digits, so you can really trust them if you're looking for tan(1.57079646018). But weren't we interested in tan(355/226)? In such a case the last 8 digits are not accurate. The question is why do you round when you can work with more digits? And if you have to round, what's the point of producing an accurate output for the rounded input which is of no use? The whole precision issue for the trigonometrics was hard to understand until I found a document from TI explaining what they did for the TI-68. Then it was clear, they were doing the same. Storing Pi to 24 digits. You can't get more precision from just an algorithm in this case. You need additional information to calculate such a number of significant digits. It has to come from high precision data in the CORDIC tables, 15 digits just don't cut it. I got the HP results for 19 significant digits as well, probably an effect of rounding the result to 12. But the real number is not 19 or 20, for Sin it's 12*2=24, so it's likely that for all the trigs. I haven't tested it thoroughly in order to find where they use the guard digits. I like calculators but I have the growing feeling that there's no point in wasting much more productive time with black boxes and marketing sales pitch. I've just found too many bizarre practices that are even more bizarrely rationalised. I would never work with double precision for some things, single precision for others, and then mix them. For me, it's just a lousy way to deal with numbers that has to do with the limitations of the platform and an ill-conceived idea of accuracy. RE: Torture tests: what do they mean? - jebem - 05-14-2014 08:58 PM (05-14-2014 06:19 AM)HP67 Wrote:(05-14-2014 05:35 AM)DavidM Wrote: point out the importance of understanding the implications of guard digits, precision, and how a given calculator displays full values vs. rounded representations of internal numbers. +1 I'm digging the WWW now for calculator algorithms. Starting from the basics: Alan Sultan explain the CORDIC. Nice reading. http://www.qc.cuny.edu/Academics/Degrees/DMNS/Faculty%20Documents/Sultan1.pdf RE: Torture tests: what do they mean? - Jim Horn - 05-14-2014 09:39 PM Alan Sultan's CORDIC article is a fine introduction. It misses one important simplification, though - instead of multiplying the result of the rotations by K, you can start with (K,0) as the initial vector. Then *no* multiplication is needed other than the binary shifts and adds. This was covered in the HP Journal article on the HP35 algorithms. Pretty nifty! RE: Torture tests: what do they mean? - jebem - 05-14-2014 10:31 PM (05-14-2014 09:39 PM)Jim Horn Wrote: Alan Sultan's CORDIC article is a fine introduction. It misses one important simplification, though - instead of multiplying the result of the rotations by K, you can start with (K,0) as the initial vector. Then *no* multiplication is needed other than the binary shifts and adds. This was covered in the HP Journal article on the HP35 algorithms. Pretty nifty! Very cleaver, indeed! My digital electronics background is coming back to my mind now... Thanks for all people sharing their knowledge and thoughts here (so far: Paul, Pauli, David, Pauli, Dieter, HP67, Manolo, Jim). I'm learning a lot from you, as I'm not a mathematician by education, but I have the basics to follow what is being said. So, apparently the big three (HP, CASIO and TI) were using CORDIC variants in the beginning, keeping absolute secrecy (and patents?) about the inner implementation details. But now in 2014, when we have so much more processor power (ALU and FPU) in convenient small low power packages... What algorithms are in use at hardware and software level, that combined, can support our trigonometric functions? Do they still maintain secrecy after all this years? Or in more than 50 years nothing was really created to beat or at least give an alternative to CORDIC algorithms? I know that 50 years is just a time tick in science. Technology is a different matter, however. RE: Torture tests: what do they mean? - Paul Dale - 05-14-2014 11:55 PM (05-14-2014 06:19 AM)HP67 Wrote: Where can one learn about this? Some of you guys seem to really understand this well and it is an interesting topic I would like to know more about. I've posted this list before but here are some good texts on numeric mathematics:
Be prepared to pay anything from $500 - $1k for these in hard copy. And before you start these read and digest all of William Kahan's writings. - Pauli |
