Difference between HP41CV and CX halfnut? - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: Difference between HP41CV and CX halfnut? (/thread-13974.html) |
Difference between HP41CV and CX halfnut? - Ken S - 11-10-2019 10:59 PM On the halfnut HP41s, is the only difference between a CV and CX the second circuit board attached on the CX? In other words if I soldered the 2nd board from a CX onto a CV would the CV effectively be a CX with the time, extended functions and extended memory? Thanks, Ken RE: Difference between HP41CV and CX halfnut? - grsbanks - 11-11-2019 06:42 AM Almost. But there are some extra functions related to external memory in the ROM of the CX that you don't find in a CV with the time module added on. There's also the text editor "ED" that you won't get with the CV + time module combo. RE: Difference between HP41CV and CX halfnut? - hth - 11-12-2019 12:07 AM (11-10-2019 10:59 PM)Ken S Wrote: On the halfnut HP41s, is the only difference between a CV and CX the second circuit board attached on the CX? In other words if I soldered the 2nd board from a CX onto a CV would the CV effectively be a CX with the time, extended functions and extended memory? If that board is missing on the CV, I believe doing what you suggest will make it a CX minus the stickers. I wonder how they crippled the halfnut 41C model not to be a CV? RE: Difference between HP41CV and CX halfnut? - Ken S - 11-12-2019 12:25 AM (11-12-2019 12:07 AM)hth Wrote:(11-10-2019 10:59 PM)Ken S Wrote: On the halfnut HP41s, is the only difference between a CV and CX the second circuit board attached on the CX? In other words if I soldered the 2nd board from a CX onto a CV would the CV effectively be a CX with the time, extended functions and extended memory? Thanks for that. I will give it a shot and see if it works and report back. I have a halfnut CV which after cleaning the battery terminals works fine and a CX which was damaged pretty badly by leaked batteries with some keys locked up from corrosion. I think all the ram and rom are on one chip for the base 41 functions, I wonder if they just leave some connections on the chip un-soldered from the board? Be a lot cheaper than making a second chip just for the 41C |
