(HP-65) Incidence & Recovery Rates estimation - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Software Libraries (/forum-10.html) +--- Forum: HP-65/67/97 Software Library (/forum-12.html) +--- Thread: (HP-65) Incidence & Recovery Rates estimation (/thread-14633.html) |
(HP-65) Incidence & Recovery Rates estimation - SlideRule - 03-13-2020 12:29 PM An extract from Estimation of incidence and recovery rates of Plasmodium falciparum parasitaemia from longitudinal data, Bull. World Health Organ., Vol. 54, 1976 pgs. 685-693 A method is described of estimating the malaria incidence rate ĥ and the recovery rate r from longitudinal data. The method is based on the assumption that the phenomenon of patent parasitaemia can be represented by a reversible two-state catalytic model; it is applicable to all problems that can be represented by such a model. … … The derivation of these formulae is given in Annex 1, with a method for calculating the variance of the estimates. Annex 2 provides a programme for the computation of ĥ, … and t, using the Hewlett-Packard 65 pocket calculator … … Annex 2 CALCULATOR PROGRAMME The formulae (3), (4) and (5) of Annex 1 were programmed for the Hewlett-Packard 65 pocket calculator. Programme: … Replete w⁄ descriptions, equations, figures, formulations, graphs, illustrations, tables, user program {example, instructions, listing, register usage, & remarks}. BEST! SlideRule |
