Video about 12C Variants - Printable Version
+--- Thread: Video about 12C Variants (/thread-17091.html)
Video about 12C Variants - kuzibro - 06-11-2021 04:59 AM
I made video about the different variants of the HP-12C that have been released over the years, largely based on information i've found in the archives of this forum...
https://www.youtube.com/watch?ab_channel=CalculatorCulture&v=sSAaZWsaJ70
In researching the video there were a couple of questions that I wasn't able to answer...
1/ How does the 30th Anniversary Edition have different stack lift behaviour from the original 12C. Was the original HP Nut firmware updated? (Also why?)
2/ Did anyone in the community ever release any alternate firmware for the 12C+ using the SDK HP released?
Antony.
RE: Video about 12C Variants - Gene - 06-11-2021 11:17 AM
Thanks!
Couple of variants are missing. :-)
1) 12c platinum without parentheses. This was the first version.
2) 12c prestige - but this was cosmetic only.
RE: Video about 12C Variants - Didier Lachieze - 06-11-2021 12:05 PM
(06-11-2021 04:59 AM)kuzibro Wrote:  1/ How does the 30th Anniversary Edition have different stack lift behaviour from the original 12C. Was the original HP Nut firmware updated? (Also why?)
In the video I don't see any difference between the original 12C result (-3.00 @8:18) and the result from the 30th Anniversary Edition which is also -3.00 (@12:06).
RE: Video about 12C Variants - rprosperi - 06-11-2021 12:55 PM
Here are 2 threads that describe stack behavior differences between 12C and 12CP machines:
https://www.hpmuseum.org/cgi-sys/cgiwrap/hpmuseum/archv015.cgi?read=87191
https://www.hpmuseum.org/cgi-sys/cgiwrap/hpmuseum/archv020.cgi?read=190342
The 30th Ann machine is a 12C+, not a 12CP-based model, so you may be confusing which model the 30th Ann Ed machine is based on.
RE: Video about 12C Variants - kuzibro - 06-11-2021 09:30 PM
Yes my mistake, you are correct. I must have got confused when writing the video script.
RE: Video about 12C Variants - kuzibro - 06-11-2021 09:35 PM
(06-11-2021 11:17 AM)Gene Wrote:  Thanks!
Yeah. It would nice to have a Prestige, they are pretty expensive these days! I did remember to mention those ones in the video though as well as the blue variant.
RE: Video about 12C Variants - Gene - 06-11-2021 10:14 PM
No problem. Great series of videos. I'm so thankful you are doing these.
The 12c platinum without parentheses is the beast, since it is such a pain to use in algebraic mode.
Why do that? It was the entire reason to make a 12c platinum. :-)
Thanks again for all the efforts on the videos!
Gene
RE: Video about 12C Variants - Massimo Gnerucci - 06-11-2021 10:24 PM
(06-11-2021 10:14 PM)Gene Wrote:  The 12c platinum without parentheses is the beast, since it is such a pain to use in algebraic mode.
Punishment for embracing the dark side.
RE: Video about 12C Variants - rprosperi - 06-12-2021 03:02 AM
It is not a coincidence that immediately after introducing Algebraic mode, they quickly updated it adding an Undo feature. You don't see that on any RPN machines... RPN don't need no stinking undo...
(Yes, it's there on RPL machines, but for different reasons...)
