"ZENROM + 2 Memory Modules" in single X-Memory module - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: "ZENROM + 2 Memory Modules" in single X-Memory module (/thread-1726.html) |
"ZENROM + 2 Memory Modules" in single X-Memory module - HP-01 - 06-26-2014 10:19 PM I have an X-Memory module that contains a "ZENROM + 2 memory modules" in a single X-Memory module. I have all of the normal ZENROM documentation, but can't find the receipt or any info on the web about how many were made of this type. I recall it cost about the same (more?) than my HP-41CX when I bought it in the 80's. Does anyone have documentation on this item they can share? RE: "ZENROM + 2 Memory Modules" in single X-Memory module - Ángel Martin - 06-27-2014 05:08 AM Surely it was a custom job done by some of the handcrafts of yore, those kind of arrangements were done on demand back then. Another common configuration was X-Functions and X-Memory together, or even the Extended-IO in the HP-IL housing. I think EduCalc offered that as a service too. Apart from the fact that both items were in the same enclosure there was nothing different to them from the stand-alone items. RE: "ZENROM + 2 Memory Modules" in single X-Memory module - TASP - 03-01-2015 06:27 AM Yes, I have an Edu-Calc flyer from 1991. double module conversion was $30 triple was $55 HP-IL + either a Development, Extended I/O or Plotter was $45 It looks like they had an arrangement with S.O.S. to do the actual work. There was a 1 year warranty too. I have an Extended Functions + 2 Extended Memory, but I don't recall if I had the S.O.S. conversion, or one of the advertised ones in the PPC Journal. I don't recall, but I'll keep looking thru my collection, if anyone was doing modules internal to the 41 body itself. Seems like individuals have done some on there own, but I haven't found an advertised service from back then. RE: "ZENROM + 2 Memory Modules" in single X-Memory module - TASP - 03-04-2015 12:56 AM I recall (vaguely) a good article in the PPC Journal (I think) that was a great reference for where everything was locatable in regards to HP41 modules and how the addressing scheme worked. Seems like a Time module could be in any port and wired to appear to the processor as though it were in any other port (maybe that applied to all modules?) there was a rule about where Extended Memory modules could go, or you had to observe that rule if they were de-cased and wired inside the calculator housing, certain modules had the same ROM numbers but I don't recall how you knew before hand which combos were bad (this was important if you wanted to put 2 ROMs in the same housing). I'm looking through the archives here, but it is so easy distracted and wind up reading some very interesting, but not what I had actually started out looking for in the first place. RE: "ZENROM + 2 Memory Modules" in single X-Memory module - rprosperi - 03-04-2015 03:10 AM (03-04-2015 12:56 AM)TASP Wrote: ...so easily distracted and wind up reading some very interesting, but not what I had actually started out looking for in the first place. I hate it when that happens. I love it when that happens. Almost every day. RE: "ZENROM + 2 Memory Modules" in single X-Memory module - TASP - 03-04-2015 03:55 AM LOL ! How do the curators here ever get what needs done with so much interesting stuff about distracting them away from the task at hand ?? Wish I had pulled my stuff out of storage 5 years ago, I might be up to speed now if I had. |
