HP-12C gets 'Entry-RPN' or Error in the QSG? - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: HP-12C gets 'Entry-RPN' or Error in the QSG? (/thread-1779.html) Pages: 1 2 |
RE: HP-12C gets 'Entry-RPN' or Error in the QSG? - Massimo Gnerucci - 07-06-2014 02:56 PM (07-06-2014 01:31 PM)CosmicTruth Wrote: this gets "too fue arguments" error also Only on inferior hardware. RE: HP-12C gets 'Entry-RPN' or Error in the QSG? - hansklav - 07-06-2014 04:51 PM (07-06-2014 12:44 PM)RMollov Wrote: (…) One might ask why so many novices use (lots of) not-needed ENTERs in their programs. For a possible answer see my other post: ENTER↑ is a misnomer, long live ENTER: Hans RE: HP-12C gets 'Entry-RPN' or Error in the QSG? - CosmicTruth - 07-07-2014 02:26 AM (07-06-2014 12:44 PM)RMollov Wrote: I'd do: lets see... 3.7 [ENTER] [ENTER] the stack has 3.7 and 3.7 in level 1 and 2 nothing in the command line * now the stack has 13.69 in the level 1 and nothing else + trying to add 13.69 to nothing gives error. RPN... Superior so i'd do 3.7 ENTER ENTER ENTER * + then i get 17.39 (using RPN) or 3.7 x^2 3.7 + 17.39 but really this post is about a difference in 2 manuals that say the same thing in different ways. you don't have to press enter sometimes if you already have the number out of the command line and in the stack and your doing a math function to it. Pressing [enter] is optional after entering a number, if the next key pressed is an operation. NOTE: pressing [Input] or [=] is optional after keying in a number, if the next key pressed is an operation. RE: HP-12C gets 'Entry-RPN' or Error in the QSG? - Joe Horn - 07-07-2014 05:36 AM (07-06-2014 12:44 PM)RMollov Wrote: I've seen (lots of) not-needed ENTERs only in novice's programs. An HP-41 program recently posted to the HP-41 Software Library contains this interesting sequence: RCL 04 RCL X + RE: HP-12C gets 'Entry-RPN' or Error in the QSG? - RMollov - 07-07-2014 09:51 AM (07-07-2014 02:26 AM)CosmicTruth Wrote:Just for you:(07-06-2014 12:44 PM)RMollov Wrote: I'd do: In RPL you need another ENTER. One more key press on the same key. Heaps better than your solution. Joe's example addresses your problem in a way. |
