HP11C Repair - Printable Version
+--- Thread: HP11C Repair (/thread-19568.html)
HP11C Repair - NivagSwedna - 02-17-2023 09:10 PM
So I managed to repair the HP11C and am now reassembling it... As part of the repair I had to completely remove the PCB to access the underside traces so had to cut the top of all the heat stakes as I went (see attached).
What is the best way to hold the device together now? I could possibly superglue the top of each stake? Or ignore the stakes and try and pad the case somehow to produce forward pressure?
Any suggestions appreciated!
RE: HP11C Repair - Stevetuc - 02-18-2023 07:50 AM
(02-17-2023 09:10 PM)NivagSwedna Wrote:  So I managed to repair the HP11C and am now reassembling it... As part of the repair I had to completely remove the PCB to access the underside traces so had to cut the top of all the heat stakes as I went (see attached).
A hot glue gun might be a good way to repair this .It's commonly used to hold large components or wiring in place and is easy to remove if you ever need to go back in.
RE: HP11C Repair - Didier Lachieze - 02-18-2023 08:14 AM
You may also try to maintain the keyboard plate in place by forcing some thin metal "needles" between each PCB hole and the corresponding heat stake as described here.
RE: HP11C Repair - NivagSwedna - 02-18-2023 04:53 PM
I managed to get it to all hang together by using UV cure glue (Bostik Flash & Fix) onto the heads of the stakes. Seems to work pretty well!
Battery leakage damage and surprisingly the clock trace under the processor had been destroyed... perhaps due to leakage but it is a long way across the board.
RE: HP11C Repair - Dreato - 02-22-2023 08:13 PM
Nice job on this! Repairing these models is tricky.
RE: HP11C Repair - Johnboy - 02-23-2023 09:59 AM
Well done !
