HP41 FOCAL programming: characters on stack? - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: HP41 FOCAL programming: characters on stack? (/thread-19946.html) |
HP41 FOCAL programming: characters on stack? - smartin - 05-11-2023 08:54 PM Hello, Question on programming the HP41: Is it possible to copy the alpha register contents onto stack registers other than X? Steve RE: HP41 FOCAL programming: characters on stack? - Valentin Albillo - 05-11-2023 09:40 PM . Of course, but storage registers admit only up to 6 alpha characters per register, so if you have a full 24 chars in the ALPHA register you should do something like this: ASTO X ASHF ASTO Y ASHF ASTO Z ASHF ASTO T or any other registers you care, say 01, 02, 03, 04. V. RE: HP41 FOCAL programming: characters on stack? - floppy - 05-12-2023 09:25 AM Add from my side: - if you have in ALPHA "TT", which would be a program name - when you make "ASTO 00" and "XEQ IND 00", it will execute the program "TT" |
