[48] how to simplify derivative? - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: [48] how to simplify derivative? (/thread-20183.html) |
[48] how to simplify derivative? - grbrum - 07-15-2023 09:11 PM I need help to simplify derivative of sin(x)/(1+cos(x)) Try it out. RE: [48] how to simplify derivative? - Thomas Klemm - 07-16-2023 08:53 AM I assume that you are familiar with calculating the derivative on the HP-48G: \( \begin{matrix} \frac{\mathrm{d} }{\mathrm{d} x} \frac{\sin(x))}{1 + \cos(x)} = \frac{\cos(x)}{1 + \cos(x)}-\frac{\sin(x) \left(-\sin(x)\right)}{\left(1 + \cos(x)\right)^2} \\ \end{matrix} \) We have to cheat a bit and use the following identities: \( \begin{matrix} \sin(x)^2 + \cos(x)^2 &=& 1 \\ \left(1 + \cos(x)\right)^2 &=& \left(1 + \cos(x)\right) \cdot \left(1 + \cos(x)\right) \end{matrix} \) Therefore we put everything on the stack for the later substitutions: 3: 1 2: '(1+COS(X))*(1+COS(X))' 1: 'COS(X)/(1+COS(X))-SIN(X)*-SIN(X)/(1+COS(X))^2' Now we can enter the equation editor by pressing the ▼ key. Select the expression \(\left(1 + \cos(x)\right)^2\) and use REPL to replace it with \(\left(1 + \cos(x)\right) \cdot \left(1 + \cos(x)\right)\). Select this whole expression: \( \begin{matrix} \frac{\sin(x) \left(-\sin(x)\right)}{\left(1 + \cos(x)\right) \cdot \left(1 + \cos(x)\right)} \end{matrix} \) Use ←A to associate left which leaves us with: \( \begin{matrix} \frac{\cos(x)}{1 + \cos(x)}-\frac{\frac{\sin(x) \left(-\sin(x)\right)}{\left(1 + \cos(x)\right)}}{\left(1 + \cos(x)\right)} \end{matrix} \) Use ←→ to commute the arguments: \( \begin{matrix} \frac{\cos(x)}{1 + \cos(x)}-\text{inv}\left(1 + \cos(x)\right) \frac{\sin(x) \left(-\sin(x)\right)}{\left(1 + \cos(x)\right)} \end{matrix} \) We do the same on the left expression as well: \( \begin{matrix} \text{inv}\left(1 + \cos(x)\right) \cdot \cos(x) -\text{inv}\left(1 + \cos(x)\right) \cdot \frac{\sin(x) \left(-\sin(x)\right)}{\left(1 + \cos(x)\right)} \end{matrix} \) This allows using ←M to merge-factors-left: \( \begin{matrix} \text{inv}\left(1 + \cos(x)\right) \cdot \left(\cos(x) - \frac{\sin(x) \left(-\sin(x)\right)}{\left(1 + \cos(x)\right)}\right) \end{matrix} \) Now we can use AF to add the fractions: \( \begin{matrix} \text{inv}\left(1 + \cos(x)\right) \cdot \frac{\left(\left(1 + \cos(x)\right) \cdot \cos(x) - \sin(x) \left(-\sin(x)\right)\right)}{\left(1 + \cos(x)\right)} \end{matrix} \) We use ←D to distribute-left the expression: \(\left(1 + \cos(x)\right) \cdot \cos(x)\) to end up with: \( \begin{matrix} \text{inv}\left(1 + \cos(x)\right) \cdot \frac{1 \cdot \cos(x) + \cos(x) \cdot \cos(x) - \sin(x) \left(-\sin(x)\right)}{\left(1 + \cos(x)\right)} \end{matrix} \) With COLCT we can clean that up a bit: \( \begin{matrix} \text{inv}\left(1 + \cos(x)\right) \cdot \frac{\cos(x)^2 + \sin(x)^2 + \cos(x)}{\left(1 + \cos(x)\right)} \end{matrix} \) Now we substitute \(\cos(x)^2 + \sin(x)^2\) by \(1\) using the REPL command again: \( \begin{matrix} \text{inv}\left(1 + \cos(x)\right) \cdot \frac{1 + \cos(x)}{\left(1 + \cos(x)\right)} \end{matrix} \) We can now use COLCT on the fraction and then on the whole expression and end up with: \( \begin{matrix} \frac{1}{1 + \cos(x)} \end{matrix} \) The result is then: 1: '1/(1+COS(X))' Conclusion The equation writer is severely limited:
This makes it close to useless. RE: [48] how to simplify derivative? - Gilles - 07-16-2023 10:46 AM (07-16-2023 08:53 AM)Thomas Klemm Wrote: The equation writer is severely limited: Hi, with the 49-50g, its easy, you select the portion of the equition that you want manipulate and then : 1/ expand \((a+b)^2\) to \((a+b)(a+b)\) In the equation writer juste push soft menu FACTO 2/[*] it doesn't know about trigonometric identities In the EQW choose Right Shift TRIG and then there are a lot of possibilité (TCOLLECT, TEXPAND etc.) RE: [48] how to simplify derivative? - grbrum - 07-16-2023 09:57 PM Thank you. I love your explanation. I will study it carefully. I guess the 48 can’t see the sin(x)2+cos(x)2 =1. And the answer is super crazy. Thank you. (07-16-2023 08:53 AM)Thomas Klemm Wrote: I assume that you are familiar with calculating the derivative on the HP-48G: RE: [48] how to simplify derivative? - Gilles - 07-17-2023 07:44 AM There is no native CAS with the 48 serie (49-50 got it). I never used it, but I think that if you want to do this kind of thing on a 48, you can use erable library RE: [48] how to simplify derivative? - BruceH - 07-18-2023 07:54 PM (07-16-2023 08:53 AM)Thomas Klemm Wrote: You can use the MATCH↓ and MATCH↑ commands to create your own functions to carry out these transformations. RE: [48] how to simplify derivative? - FLISZT - 07-18-2023 08:35 PM (07-18-2023 07:54 PM)BruceH Wrote:(07-16-2023 08:53 AM)Thomas Klemm Wrote: … the hard way! RE: [48] how to simplify derivative? - Thomas Klemm - 07-19-2023 12:59 AM (07-18-2023 07:54 PM)BruceH Wrote: You can use the MATCH↓ and MATCH↑ commands to create your own functions to carry out these transformations. The second argument would be for instance: {'(&Z)^2' '&Z*&Z'} This can be done before entering the equation editor. Not sure about the trigonometric identity though. It seems easier to replace the sum by 1 manually in the editor than writing a pattern. But then you'd have to know in advance that you will need this value and put it on the stack. RE: [48] how to simplify derivative? - BruceH - 07-19-2023 11:33 PM The MATCH commands return a test result to say whether a match occurred or not. So for trigonometric identities you would, I presume, create a program that tries several identities in succession, noting which succeed, and then, based on that information, decide which one or ones were the appropriate ones to apply. |
