HP50 : indefinite integral of '0^x' gives '?' and 0 for '0*x' - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: HP50 : indefinite integral of '0^x' gives '?' and 0 for '0*x' (/thread-20786.html) |
HP50 : indefinite integral of '0^x' gives '?' and 0 for '0*x' - Gil - 11-06-2023 05:05 PM Try on the HP50G '0^X' INTVX (integral of 0^X). But S (0^X) dX is equivalent to S (0) dX = Constant, as the derivative of a constant is equal to 0. But the HP50G returns '?'. Besides, if you write directly 0 INTVX (integral of 0), the calculator returns 0 (instead of Constant). Somewhat disappointing. However, the HP50G gives correctly the numerical area (with the command —>NUM, but not with EVAL command) from a to b for the function '0^X': 0, as [b-a] × 0 = 0. Does another calculator like the Prime, or CASIO/TI gives the expected answers? RE: HP50 : integral of '0^x' gives induly '?` - rawi - 11-07-2023 02:38 PM This seems to be a strange problem for calculators: HP Prime: G1 and G2: Integral 0^x without lower and upper limit in CAS: undef. Integral from a to b of 0^x --> invalid input (ungültige Eingabe, home) or undef. (CAS) Integral from 1 to 2 of 0^x --> invalid input (Home) or undef. (CAS) TI 89 Titanium and TI nspire CX II T CAS: Integral 0^x without lower and upper limit: no result (input is repeated as result) Integral from a to b of 0^x --> no result (input is repeated) Integral from 1 to 2 of 0^x --> 0 I think the reason why the integrals from a to b do not work is that 0^0 is undefined in all the calculators (there seems to be a new definition among mathematicicians but I am not sure about that). But the integral from 1 to 2 should be no problem. RE: HP50 : integral of '0^x' gives induly '?` - rawi - 11-07-2023 03:11 PM Some additional information: Casio CP 400: Integral from 1 to 2 of 0^x: Undefined. HP 15C: If you integrate the follwing program: LBL A 0 X<>Y Y^X g RTN from 0 to 1 or from 1 to 2 the result is always 0. As well the TI 89 Titanium and the TI nsprire get the integral from 0 to 1 right with the result 0. RE: HP50 : integral of '0^x' gives induly '?` - klesl - 11-07-2023 03:28 PM According to me the function 0^x is undefined khicas + casio fx-cg50 - undefined classpad II - undefined xcas - undefined ti-nspire cx cas - no result mathcad 15 - no result matlab 2023- no result no result means "input is repeated as result" int(a^x)=a^x/ln(a) for a=0 the result is not defined and 0^0 is indeterminate form RE: HP50 : indefinite integral of '0^x' gives '?' and 0 for '0*x' - Gil - 11-07-2023 09:30 PM About the last answer int(a^x)=a^x/ln(a) to be better formulated, with x>0: int(a^x)=a^x/ln(a) for a≠0 int(a^x)=constant, else (for a=0) ? Regarding that "stupid" function 0^X, it seems to be defined for X>0. Note that the area (zero!) is correct when setting real bounds and then the numerical calculation is requested (—>NUM) with the HP50G, but not with the EVAL command. But if you put bounds like variables named a and b, you won't get the expected 0 value with the HP50G, supposing of course x>0 (or the infinity when x<0). RE: HP50 : integral of '0^x' gives induly '?` - klesl - 11-08-2023 07:52 AM small corerction: int(a^x)=a^x/ln(a) for a>0 There is no way how to compute int(a^x,x) for a=0 because you need to rewrite a^x as e^(x*ln(a)) and logarithm is defined for a>0 only. This integral isn't equal to constant, it is undef as logarithm. Also you don't find int(a^x,x) for a=0 in any math tables. RE: HP50 : integral of '0^x' gives induly '?` - Gil - 11-08-2023 09:14 AM Ok for the undefined function '0^x'. But what about the well defined function '0*x'? Integral of (0*x) should be simplified before calculating and (logically?) be equal to integral of (0) = constant (as correctly answers Wolfram Alpha for the aforementioned indefinite integral). Or am I wrong? On the HP50G, however, '0*X' INTVX (with no bounds) gives zero, as it has been initially calculated with a general formulae a*x²/2, and then the factor a is replaced by its original value a=0, which gives a final value of 0, a special case — indeed a correct result when settling real bounds with the HP50G and executing EVAL command or —>NUM command. |
