EXPORT MOVEM7()
// Version 7
// 2014-02-16
// Collect 10 coins to unlock the goal
// A status screen is added on the bottom
// Bottom row is not avialable for play
// This version puts it all together:
// Coins, trees, and enemies
// Game introduction
MSGBOX("Collect all 10 $ signs to unlock
the goal! Avoid the purple enemies!");
// Clear the screen
RECT();
// Cursor set up
LOCAL A,B,C,D;
A:=150;
B:=216;
C:=150;
D:=216;
TEXTOUT_P("π",A,B,2);
// Draw Coins
LOCAL costr,L2,L3,cx,cy,I,coins;
coins:=10; // counter
L2:=RANDINT(10,0,31)*10; // x coin
L3:=RANDINT(10,1,17)*12; // y coin
costr:=CHAR(36); // $ sign
FOR I FROM 1 TO 10 DO
cx:=L2(I); cy:=L3(I);
TEXTOUT_P(costr,cx,cy,2,#FF00h);
// Draw Trees
// Trees Setup
LOCAL tstr,L0,L1,S,tx,ty,J;
S:=10;
L0:=RANDINT(S,0,31)*10; // x tree
L1:=RANDINT(S,1,17)*12; // y tree
tstr:=CHAR(8857); // tree
// Make sure trees and coins do not
// appear in the same place.
// If there is a conflict, the coin wins.
// Middle
FOR I FROM 2 TO S-1 DO
FOR J FROM 1 TO 10 DO
IF (L0(I)==L2(J)) AND (L1(I)==L3(J)) THEN
// Use CONCAT and SUB
L0:=CONCAT(SUB(L0,1,I-1),SUB(L0,I+1,S));
L1:=CONCAT(SUB(L1,1,I-1),SUB(L1,I+1,S));
// Length of L0 and L1 decrease by 1
S:=S-1;
// Left Side
IF (L0(1)==L2(J)) AND (L1(1)==L3(J)) THEN
L0:=SUB(L0,2,S); L1:=SUB(L1,2,S);
S:=S-1;
// Right Side
IF (L0(S)==L2(J)) AND (L1(S)==L3(J)) THEN
L0:=SUB(L0,1,S-1); L1:=SUB(L1,1,S-1);
S:=S-1;
// Draw the forest
FOR I FROM 1 TO S DO
tx:=L0(I); ty:=L1(I);
TEXTOUT_P(tstr,tx,ty,2,#8000h);
// Ememy Setup
LOCAL estr,d1,d2;
LOCAL ey1A,ey2A,ey3A;
LOCAL ex1A,ex2A,ex3A;
LOCAL ey1B,ey2B,ey3B;
LOCAL ex1B,ex2B,ex3B;
// Delay
d1:=120;d2:=20;
// Enemy 1 jumps to random places
// Enemy 2 flies left to right
// Enemy 3 flies right to left
ex1A:=RANDINT(0,31)*10;
ey1A:=RANDINT(1,17)*12;
ex2A:=−10;
ey2A:=96;
ex3A:=330;
ey3A:=96;
estr:=CHAR(9991); //enemy
TEXTOUT_P(estr,ex1A,ey1A,2,#6000FFh);
TEXTOUT_P(estr,ex2A,ey2A,2,#8000FFh);
TEXTOUT_P(estr,ex3A,ey3A,2,#8000FFh);
// House setup
LOCAL hx,hy,hstr;
hx:=RANDINT(0,31)*10;
hy:=0;
hstr:=CHAR(9820); // castle
TEXTOUT_P(hstr,hx,hy,2,#964B00h);
// Lock setup
LOCAL lock:=1;
// Movement
REPEAT
// Delay Counter
d1:=d1-1; d2:=d2-1;
// Press an Arrow Key
K:=GETKEY;
IF K==7 AND A>0 THEN
C:=A-10; D:=B;
IF K==8 AND A<310 THEN
C:=A+10; D:=B;
IF K==12 AND B<216 THEN
C:=A; D:=B+12;
IF K==2 AND B>0 THEN
C:=A; D:=B-12;
// Move the Enemies
IF d1==0 THEN
d1:=120;
// Enemy 1
ex1B:=RANDINT(0,31)*10;
ey1B:=RANDINT(2,17)*12;
IF d2==0 THEN
d2:=20;
// Enemy 2
ex2B:=ex2A+10;
ey2B:=ey2A;
IF ex2B>330 THEN
ex2B:=−10;
ey2B:=RANDINT(1,17)*12;
// Enemy 3
ex3B:=ex3A-10;
ey3B:=ey3A;
IF ex3B<−10 THEN
ex3B:=330;
ey3B:=RANDINT(1,17)*12;
// Clear previous enemy spot
// Fixed objects will be drawn later
RECT_P(ex1A,ey1A,ex1A+10,ey1A+12);
RECT_P(ex2A,ey2A,ex2A+10,ey2A+12);
RECT_P(ex3A,ey3A,ex3A+10,ey3A+12);
// Draw new enemy positions
TEXTOUT_P(estr,ex1B,ey1B,2,#6000FFh);
ex1A:=ex1B;
ey1A:=ey1B;
TEXTOUT_P(estr,ex2B,ey2B,2,#8000FFh);
ex2A:=ex2B;
ey2A:=ey2B;
TEXTOUT_P(estr,ex3B,ey3B,2,#8000FFh);
ex3A:=ex3B;
ey3A:=ey3B;
// Bump in the boundary?
LOCAL collide:=0;
IF D==hy AND lock==1 THEN
collide:=1;
// No BREAK command because there is no
// FOR loop to break out of
// Ran into a tree?
IF C==L0(I) AND D==L1(I) THEN
collide:=1;
BREAK;
// BREAK needed because we have a FOR loop
IF collide==1 THEN
C:=A; D:=B;
// Got hit by the enemy?
LOCAL death;
IF (C==ex1B) AND (D==ey1B) THEN
death:=1;
IF (C==ex2B) AND (D==ey2B) THEN
death:=1;
IF (C==ex3B) AND (D==ey3B) THEN
death:=1;
IF death==1 THEN
MSGBOX("OUCH! :(");
BREAK;
// Collect the coin?
IF C==L2(I) AND D==L3(I) THEN
L2(I):=-1;
L3(I):=-1;
// Remove coin from play
coins:=coins-1;
BREAK;
// Are all the coins collected?
IF coins==0 THEN lock:=0 END;
// Player
RECT_P(A,B,A+10,B+12);
TEXTOUT_P("π",C,D,2);
// Draw a boundary
IF coins≠0 THEN
LINE_P(0,12,319,12,#FF0000h);
ELSE
// Unlock boundary, all coins collected
LINE_P(0,12,319,12,#FF00h);
// Draw the Goal
// Draw the Forest
// Draw the Coins
// Don't draw at -1
IF L2(I)≠−1 AND L3(I)≠-1 THEN
// Draw Status Screen
RECT_P(0,217,319,239);
TEXTOUT_P("Coins Left: "+
STRING(IP(coins)),0,228,2);
IF lock==1 THEN
TEXTOUT_P("LOCKED",260,228,2,#FFh);
// Prepare
for the next move
A:=C; B:=D;
// Arrived home?
UNTIL K==50 OR (C==hx AND D==hy);
// Exit Conditions
// Plus Exit
IF K==50 THEN
MSGBOX("Program Terminated.");
// Home Exit
IF C==hx AND D==hy THEN
MSGBOX("Home! :) "+CHAR(9829));
// CHAR(9829) produces a heart
