Info Key (shift Apps), re purposed - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: Info Key (shift Apps), re purposed (/thread-8184.html) |
Info Key (shift Apps), re purposed - AngryNapkin - 04-17-2017 12:50 AM Is it possible to create a custom function to re purpose the Info key like you can the View key in an app? The manual is pretty vague in the topic, and only goes into how to do it for the View key. I tried Info() BEGIN MSGBOX("INFO PRESSED"); END; I tried Infoview() BEGIN MSGBOX("INFO PRESSED"); END; they dont seem to execute. RE: Info Key (shift Apps), re purposed - cyrille de brébisson - 04-17-2017 05:12 AM Hello, Sorry, but I just looked in the source code and there is no app programatic override for the view key. You can override it as a user key however. Cyrille RE: Info Key (shift Apps), re purposed - Carlos295pz - 04-19-2017 02:41 AM RESET //It also does not work BEGIN ... END; |
