Update of Emu48 Classic to v1.60
01-23-2018, 07:54 PM
The classic version of Emu48 v1.60 is available at http://hp.giesselink.com.
This is a minor update fixing problems with the menu item "Edit/Copy Screen". In prior versions you mostly got a "Zoom 1" image in the clipbaord when the KML Zoom factor was greater than 4 or when using the KML command Zoomxy with different x and y magnification arguments.
Further in all versions the menu screen part was corrupted when the main screen had a left offset greater than 0.
A complete list of bugfixes and changes is available here.
When your last Emu48 installation is the Emu48 20th Anniversary edition, _don't_ uninstall this version. Just install the new version over the old one and choose at the question "An older version of Emu48 is installed on your system. It's recommended that you uninstall the current version before installing. Select the operation you want to perform and click Next to continue." the item "Do not uninstall"
This will preserve all data in the installation directory and only overwrite the changed files. This is necessary because the regular installation file contain only a subset of the KML files included in the Emu48 20th Anniversary edition.
A reference to the latest Emu48+ source code fork used by Debug4x can be found at http://hp.giesselink.com/Emu48/PlusSvn/emu48plus.htm.
Christoph
01-23-2018, 08:00 PM (This post was last modified: 01-23-2018 08:03 PM by pier4r.)
RE: Update of Emu48 Classic to v1.60
kudos for the huge amount of work over years!
Dunno why it was not in the http://www.wiki4hp.com/doku.php?id=resources:start page. I wonder how many great (but "taken for granted") resources that page is still missing.
01-23-2018, 10:51 PM (This post was last modified: 01-23-2018 11:10 PM by sunhp.)
Awesome work thank you Christoph !
Question : Would it be at least possible to think about a version of Emu48 decoupled from any Windows Code ( Timers, Filer, etc ) a version ready for Emscripten -- > jsEmu48 online emulator ?
01-24-2018, 11:44 PM
(01-23-2018 10:51 PM)sunhp Wrote:  Question : Would it be at least possible to think about a version of Emu48 decoupled from any Windows Code ( Timers, Filer, etc ) a version ready for Emscripten -- > jsEmu48 online emulator ?
Not be me. I focused my work on the Windows platform with the languages C and C++ only. That's quite difficult enough in some situations.
01-25-2018, 11:18 AM
Sure thing, again thank you very much for your work on Emu48 Windows it helps a lot.
01-25-2018, 12:38 PM
Hello, one of the problems of emu48, with respect to masks or skins, is that they are linked to certain ROM files, the famous emulator TIemu, has a function, which is that after loading the mask you can change the ROM
1: if the skn file does not find a specific ROM, show a pop-up window that shows, for example, all ROMs of a certain type for the mask to can start, without having to edit the skn file
2: the SCALE command could be a function of the menu, this would allow an external zoom of the skin
08-23-2018, 07:59 PM (This post was last modified: 08-23-2018 11:32 PM by compsystems.)
1: Emu48 1.61 patch (august 2018)
executable in:
https://www.hpcalc.org/details/3646
2: Emu48+ 1.?? (august 2018)
Who can compile the following source code for the emu48 + version?
https://hp.giesselink.com/Emu48/PlusSvn/emu48plus.htm
08-26-2018, 11:37 PM
(08-23-2018 07:59 PM)compsystems Wrote:  2: Emu48+ 1.?? (august 2018)
I'll do it in a week or two. Still on holiday abroad so I have other priorities right now!
09-12-2018, 03:09 AM
Emu48+ is now compiled and posted on my site (numbered as version 1.59, and based on Emu48 1.61). I fixed the Zoomxy bug that was reported with the previous release, too.
09-12-2018, 03:35 PM
(01-23-2018 07:54 PM)Christoph Giesselink Wrote:  The classic version of Emu48 v1.60 is available at http://hp.giesselink.com.
(09-12-2018 03:09 AM)Eric Rechlin Wrote:  Emu48+ is now compiled and posted on my site (numbered as version 1.59, and based on Emu48 1.61). I fixed the Zoomxy bug that was reported with the previous release, too.
Thanks to you both! Your continued efforts for these applications are greatly appreciated, and you can rest assured that they will be put to good use.
