User defined fit in apps Stats 2Var
04-21-2014, 09:16 PM
Are you able to use the User defined it in Stats 2 Var. the predefined fit work very well but not the user defined fit
Thanks |
04-21-2014, 09:41 PM
(This post was last modified: 04-21-2014 09:42 PM by eried.)
RE: User defined fit in apps Stats 2Var
I think you first need to learn to use the browser, then the calculator, otherwise all your questions might have relation with layer 8 issues.
My website: erwin.ried.cl |
