Estimates M0 and magnitude.
Estimates distance/time.
Compares relative size and strength.
Most functions allow lists of values.
In English, francaise and polskie.
LOCAL VER:=" V1.2: ";
LOCAL MN:="Earthquake"+VER;
LOCAL CRID:=MN+" © 2019 StephenG1CMZ";
LOCAL LANGSE:={" English ",""," French ","","","","",""," Polish "};
LOCAL LANGS :={" English ",""," français ","","","","",""," polskie "};
LOCAL LANGS2:={"EN","","FR","","","","","","PL"}; //EN CHINESE FR GERMAN SPANISH DUTCH PORTUGUESE JAPANESE PL
LOCAL SL:=1;//SL
EXPORT RigidityTypical:=3ᴇ10; //FOR CONVENIENCE
//VELOCITY in unit/s (to match Centre distance)
EXPORT VP; //TYPICAL 6 km/s OR 1.7*VS
EXPORT VS; //TYPICAL 3 km/s
//THE TYPICAL VALUES HERE REFER TO LOCAL WAVES
LOCAL EPSILON:=1ᴇ−308;//STD MATH:SMALLEST NONZERO (LIMIT VALUE USED FOR LOG0)
LOCAL MNF:={"Earthquake","","Tremblement de terre","","","","","","Trzęsienie ziemi"}+VER;
LOCAL MAGT:={"Magnitude","","Grandeur","","","","","","Wielkość"};
LOCAL RELT:={"Relative ","","Relative ","","","","","","względna "};
LOCAL AMPLT:={"Amplitude","","Amplitude","","","","","","Amplituda"};
LOCAL ENERGT:={"Energy","","Énergie","","","","","","Energia"};
ABOUT()
LOCAL ABT:={"Earthquake calculations are estimates and can be calculated differently. No liability is accepted.","",
"Les calculs sismiques sont des estimations et peuvent être calculés différemment. Aucune responsabilité n'est acceptée.","","","","","",
"Obliczenia trzęsienia ziemi są szacunkowe i można je obliczyć inaczej. Nie ponosimy odpowiedzialności."};
PRINT();
PRINT(CRID);
PRINT(MNF(SL));
PRINT(ABT(SL));
WAIT;
//STD MATH
LOG10(NUM) //AVOID RISK OF MISTAKING LOGS
RETURN LOG(NUM);//LOG10
//END MATH
// Calculations for a single quake
// Parameters may be numeric or lists
EXPORT M0Nm(RigidityNm2,Aream2,Slipm)
//Calculate SeismicMoment in Nm^2
//=rigidity x area x slip
//The rigidity of rock is a constant number based on the rock type. It has units of pressure. Typical assumptions are on the order of 3 x 10^10 N/m2.
//Slip is a length and it is on the order of centimeters (meters for a great earthquake).
//Area is in units of length2 and is often on the order of km2.
//The units for seismic moment are then Nm (newton meters).
//As an example, the 2004 26 December Sumatra-Andaman earthquake had the following dimensions as reported by Lay et al. (2005): Its slip averaged about 5 m, its rupture length was about 1300 km and the fault width was between 160 - 240 km. Assuming a rigidity of 3 x 10^10 N/m2 gives us a seismic moment of 4.4 x 10^22Nm.
LOCAL Rigidity:=IFTE(RigidityNm2,RigidityNm2,RigidityTypical);//Use Typical value if none supplied
LOCAL Area:=Aream2;
LOCAL Slip:=Slipm;
RETURN Rigidity*Area*Slip;
MW(M0)
//Calculate Mw = (2/3)*logM0 - 6.05
LOCAL M00:=MAX(M0,EPSILON);//GUARD M0≤0
LOCAL MM:=(2/3)*LOG10(M00)-6.05;
IF MIN(M0)≤0 THEN
MSGBOX(MN+"MW:\n"+"LOG≤0: "+STRING(M0));
RETURN MM;
EXPORT Magnitude(RigidityNm2,Aream2,Slipm)
RETURN MW(M0Nm(RigidityNm2,Aream2,Slipm));
//These magnitudes are approximations to Richter scale but not same
EXPORT Magnitude_(M0)
RETURN MW(M0);
EXPORT EnergyJ(Magnitud) // //"Magnitude" is a reserved word or function
// Calculate E, where Log10(E) = 5.24 + 1.44M
//Empirical good for M>5
//This estimates damaging energy
RETURN ROUND(ALOG(5.24+1.44*Magnitud),0);//J
EXPORT Energyt(Magnitud)
LOCAL TNT:=4.184ᴇ9;//J PER TONNE
RETURN EnergyJ(Magnitud)/TNT;
EXPORT EnergyH(Magnitud)
LOCAL HIROSHIMA:=7.4ᴇ12;//J
RETURN EnergyJ(Magnitud)/HIROSHIMA;
//Timing requires VP and VS to be set
//Typically km/s but ensure these units match
//VP VS (km/s) DISTANCE (km) TDELTA (s)
EXPORT GetVPVS()
//PROMPT USER FOR VP VS
//(CALLABLE BY USER OR AUTOMAGICALLY TO AVOID ERROR)
//TYPICALLY 6km/s and ?
LOCAL TTL:={"Enter Velocity of P and S waves","","Entrez la vitesse des ondes P et S","","","","","","Wprowadź prędkość fal P i S"};
LOCAL LBL:={"VP","VS"};
LOCAL HLPP:={"Primary wave (typically 6 km/s, 1.7*VS)","","Vague primaire (généralement 6 km / s, 1.7*VS)","","","","","","Fala pierwotna (zazwyczaj 6 km / s, 1.7*VS)"};
LOCAL HLPS:={"Secondary wave (typically 3 km/s)","","vague secondaire (généralement 6 km / s)","","","","","","Fala wtórna (zazwyczaj 3 km / s)"};
LOCAL HLP:={HLPP(SL),HLPS(SL)};
INPUT({VP,VS},TTL(SL),LBL,HLP);
EXPORT CentreL(TDELTA)
//Distance to centre-Local usable up To 100-250km.
//Simple formula for constant velocity
//TDELTA=(TimeS-TimeP) s (alt. to match VP VS)
//RESULTS in m or km (ie. as VP VS)
LOCAL DST;
IF VP-VS==0 OR VP==0 OR VS==0 THEN
MSGBOX(MN+"CentreL\n"+"VP-VS=0");
GetVPVS();
//MSGBOX({TDELTA,VP,VS});//INPUTLOG
DST:=(TDELTA)*(VP*VS)/(VP-VS);
RETURN ROUND(DST,0);//unit matching VS//ROUND to km
//These trivial distace-time-velocity formulae assume constant velocity
EXPORT Delay(DISTANCE) // DISTANCE ≤250 km
//GIVEN DISTANCE,HOW LONG AFTER P WILL S ARRIVE
//DISTANCE:UNITS TO MATCH VP VS
//RESULTS MATCH UNITS OF VELOCITIES VP VS
IF VP==0 OR VS==0 THEN
MSGBOX(MN+"\n"+"VP/0 VS/0:"+STRING({VP,VS}));
GetVPVS();
//MSGBOX({DISTANCE,VP,VS});//INPUTLOG
RETURN (DISTANCE/VP)-(DISTANCE/VS);
EXPORT AnEarthquake(Magnitud)
//Describe an Earthquake
PRINT();
PRINT(STRING(Magnitud)+" Magnitude");
PRINT(" ");
PRINT(STRING(EnergyJ(Magnitud))+" J");
PRINT(STRING(Energyt(Magnitud))+" t(TNT)");
PRINT(STRING(EnergyH(Magnitud))+" Hiroshima");
//Comparing 2 Quakes (unused)
RelAmplitude(MagA,MagB)
//Compare relative amplitude, any order
LOCAL BIGGER := 10^ABS(MagA-MagB);
RETURN BIGGER; //unitless
RelEnergy(MagA,MagB)
//Compare relative energy (damage), any order
LOCAL BIGGER := RelAmplitude(MagA,MagB);
LOCAL STRONGER := 10^(ABS(MagA-MagB)/2)*BIGGER;
RETURN STRONGER; //unitless
// Comparing a list of quakes
EXPORT Amplitudes(Magnitudes,INDX)
//Compare relative amplitude with indexed value=1
//Errors return empty list (except LOG:LIMITED)
LOCAL MAG;
LOCAL BIGGER;
CASE
IF TYPE(Magnitudes)=Type({}) THEN
IF SIZE(Magnitudes)=0 OR INDX>SIZE(Magnitudes) THEN
RETURN {};
MAG:=Magnitudes(INDX);
BIGGER := 10^(Magnitudes-MAG);
DEFAULT
RETURN {}; //{MN+"Provide a list"};
EXPORT Energies(Magnitudes,INDX)
//Compare relative energy (damage) with indexed value=1
LOCAL MAG;
LOCAL BIGGER;
LOCAL STRONGER;
CASE
RETURN {};
BIGGER := Amplitudes(Magnitudes,INDX);
STRONGER := 10^((Magnitudes-MAG)/2)*BIGGER;
DEFAULT
EXPORT Earthquakes(Magnitudes,INDX)
//Describe relative earthquakes
//Values onscreen need to be rounded to 9
//to prevent occasional overlap.
//You may prefer to omit this rounding.
LOCAL II;
LOCAL DP:=9;
LOCAL SW:=320;
LOCAL AMPLS:=Amplitudes(Magnitudes,INDX);
LOCAL STRONGS:=Energies(Magnitudes,INDX);
RECT_P();
TEXTOUT_P(MN+MNF(SL),0,220);
TEXTOUT_P(MAGT(SL),0,0);
TEXTOUT_P(AMPLT(SL),SW/5,0);
TEXTOUT_P(ENERGT(SL),2*SW/4,0);
TEXTOUT_P(RELT(SL)+INDX,3*SW/4,0);
IF TYPE(Magnitudes)==TYPE({}) THEN
FOR II FROM 1 TO MIN(SIZE(Magnitudes),10) DO //10-11 PER SCREEN:1SCREEN
TEXTOUT_P(ROUND(Magnitudes(II),4),0,20*II);
TEXTOUT_P(ROUND(AMPLS(II),DP),SW/6,20*II); //ROUND FOR DISPLAY
TEXTOUT_P(ROUND(STRONGS(II),DP),2*SW/4,20*II); //ROUND FOR DISPLAY
FREEZE;
WAIT;
//Examples
ExM0()
// Calculate upper and lower bounds for ex
// Demonstrates mixing list and numeric
PRINT ({M0Nm(3*10^10,{1300ᴇ3*(160ᴇ3),1300ᴇ3*(240ᴇ3)},5)," =4.4 x 10^22"}+" Nm ");
ExMW()
PRINT ({MW(4.4ᴇ22),"=9.05"}+" Magnitude ");
ExEnergy()
//PRINT({EnergyJ({5.0,6.0,7.0}),"=2.8ᴇ12 =7.8ᴇ13?? =2.1ᴇ15"}+" J ");
//PRINT({EnergyH(5.0),EnergyH(6.0),EnergyH(7.0)," "}+" Hiroshima ");
//PRINT({EnergyJ(9.05),"=1.84ᴇ18"}+" J ");
//PRINT({Energyt(5.0)}+" tTNT ");
WAIT;
AnEarthquake(7.1);
ExRel()
PRINT({RelAmplitude(7.1,6.4)," =5"});
PRINT({RelEnergy (7.1,6.4)," =11.2"});
//PRINT(Amplitudes({7.1,6.4},1));
//PRINT(Energies({7.1,6.4},1));
//PRINT(STRING(Amplitudes({7.1,6.4},2))+" =5");
//PRINT(STRING(Energies({7.1,6.4},2))+" =11.2");
WAIT;
Earthquakes({1,2,3,4,5,6,7,8,9,10,11,12,13},4);
EXPORT Examples()
ABOUT();
//PRINT();
PRINT("[=] signifies expected value");
WAIT;
ExM0();
ExMW();
ExEnergy();
ExRel();
EXPORT HELP()
LOCAL ALL:={"Most functions allow lists","","La plupart des fonctions permettent les listes","","","","","","Większość funkcji pozwala na listy"};
LOCAL MAG:=MAGT(SL)+": "+{"Not exactly","","Pas exactement","","","","","","Nie dokładnie"}+" Richter";
LOCAL UL:= {"Unitless","","Sans unité","","","","","","Bez jednostki"};
ABOUT();
PRINT();
PRINT(ALL(SL));
PRINT(" ");
//PRINT("UNITS");
PRINT("M0Nm: Nm");
PRINT(MAGT(1)+": "+MAG(SL));
PRINT(ENERGT(SL)+": J, Hiroshimas or tonnesTNT");
PRINT("GetVPVS: km/s?");
PRINT("CentreL: km ? (≤100-250km");
PRINT("Delay: s?");
PRINT(" ");
PRINT("RelativeAmplitudes: "+UL(SL));
PRINT("RelativeEnergies: "+UL(SL));
PRINT(" ");
EXPORT Languages()
LOCAL TTL:=IFTE(SL,LANGS2(SL)+LANGS(SL)+LANGSE(SL),LANGS2+LANGSE);
IF CHOOSE(SL,TTL,LANGS2+LANGS+LANGSE) THEN
MSGBOX(LANGS2(SL)+LANGS(SL)+LANGSE(SL));
EXPORT EARTHQUAKE() //MAIN
ABOUT();
Languages();
//ABOUT();
1.
2.
3.
