(Casio fx-CG50/9750GIII): System of Two Differential Equations
08-02-2020, 02:38 PM
Blog link: http://edspi31415.blogspot.com/2020/08/c...em-of.html
Solving systems of differential equations would be a nice addition to the HP Prime. Here it is for the Casio fx-9750GIII/fx-CG 50: The program TWORK4 uses the Runge Kutta 4th Order method to solve the following system of differential equations: dx/dt = f(t, x, y) dy/dt = g(t, x, y) with initial conditions x0 = x(t0) and y0 = y(t0) The next step is calculated with step h from: x1 ≈ x0 + (k1 + 2 * k2 + 2 * k3 + k4) / 6 y1 ≈ y0 + (l1 + 2 * l2 + 2 * l3 + l4) / 6 k1 = h * f(t0, x0, y0) l1 = h * g(t0, x0, y0) k2 = h * f(t0 + h / 2, x0 + k1 / 2, y0 + l1 / 2) l2 = h * g(t0 + h / 2, x0 + k1 / 2, y0 + l1 / 2) k3 = h * f(t0 + h / 2, x0 + k2 / 2, y0 + l2 / 2) l3 = h * g(t0 + h / 2, x0 + k2 / 2, y0 + l2 / 2) k4 = h * f(t0 + h, x0 + k3, y0 + l3) l4 = h * g(t0 + h, x0 + k3, y0 + l3) For the next step set t0 = t0 + h, x0 = x1, and y0 = y1. Inputs: DX/DT: Enter dx/dt as a function of T, X, and Y. T is the independent variable. DY/DT: Enter dy/dt as a function of T, X, and Y. T is the independent variable. T0, X0, Y0: Enter the initial conditions STEP: Enter the step size ITERATIONS: Enter the number of iterations desired. This allows you to calculate a far point in one leap. Example, if your initial condition is to = 0 and you want to find the point when t = 1 using the step size of 0.1, enter 0.1 for STEP and 10 for ITERATIONS. Casio fx-9750GIII and fx-CG 50 Program: TWORK4 Notes: * Although the code for the two calculators are the same, the programs will need to be programmed on each calculator separately. * The slash character (/) is accessed from the CHAR submenu. The submenu shows up at the top-level menu which would read: TOP/BOTTOM/SEARCH/MENU/A ←→ a/CHAR * fn1 and fn2 are stored as function memories. Code: "2020-06-18 EWS" Example dx/dt = x sin y dy/dt = y^2/500 + y/3 - y Initial conditions: x(0) = 0.1, y(0) = 0.1, h = 0.1 T0 = 0 STEP = 0.1 ITERATIONS: 10 Results: (T, X, Y): (1, 0.1075645239, 0.05134921355) ITERATIONS: 10 Results: (T, X, Y): (2, 0.1116714419, 0.02636554462) Source: John W. Harris and Horst Stocker. Handbook of Mathematics and Computational Science. Springer: New York. 2006. ISBN 978-0-387-94746-4 Stack Exchange. "Help with using the Runge-Kutta 4th order method on a system of 2 first order ODE'S" Asked March 2014. Last updated February 2019. https://math.stackexchange.com/questions...t-order-od Retrieved June 17, 2020 |
10-28-2022, 09:33 AM
RE: (Casio fx-CG50/9750GIII): System of Two Differential Equations
@ https://www.hpmuseum.org/forum/thread-19012.html
One can use this above. Its working & I have checked. HP Prime G1 Python via Android Termux... |
