HP 35s key mapping
01-11-2021, 12:57 AM
HP 35s key mapping
After buying my 35s and realizing how much there was to learn and not being able to expeditiously find the keys mentioned in the User Manual the need for a file that let me look up the key was apparent. The attached file is based on the Keyboard figure in the User manual but, being electronic media, is searchable.
The attached file is open source and is available without reservation as my intent is to share my solution to a vexing issue; to wit, learning a complicated subject without knowing where the subject matter material is readily accessible. Short story is that my eyes are not what they used to be and so hopefully this file helps others overcome similar difficulties. Thank you. Respectfully, Daniel P.S.-Editing and other suggestions will be greatly appreciated. “May your choices reflect your hopes, not your fears.” - Nelson Mandela |
01-11-2021, 01:28 PM
RE: HP 35s key mapping
Post approved. Please add your attachment.
-katie |
01-11-2021, 02:38 PM
PDF attached.
01-15-2021, 12:42 AM
thank you!
Cambridge, UK 41CL/DM41X 12/15C/16C DM15/16 17B/II/II+ 28S 42S/DM42 32SII 48GX 50g 35s WP34S PrimeG2 WP43S/pilot Casio, Rockwell 18R |
