E-Series Chips
06-21-2014, 11:55 PM
E-Series Chips
I have an HP-32E and an HP-38E.
Neither works and I want to try swapping chips to see if I can make one functional machine our of the two.
Both are the original non-solder type (left picture in http://www.hpmuseum.org/30comp.jpg) and have 1 large IC and 3 small ICs.
Does anyone know which ICs are common to both machines and which are specific to each machine?
Does anyone have the pin description for the LED display?
Thank you,
Benoit
06-22-2014, 03:01 AM
RE: E-Series Chips
(06-21-2014 11:55 PM)Benoit Maag Wrote:  I have an HP-32E and an HP-38E.
Thank you,
Benoit
According to Eric's listing of HP Calculator Chips, it appears that the processor and memory chips are not compatible.
Ceci n'est pas une signature.
