[VA] SRC #012f - Then and Now: Angle
05-01-2023, 04:00 PM (This post was last modified: 05-09-2023 04:40 AM by Valentin Albillo.)
Hi, all,
Welcome to the 6th and last part of my SRC #012 - Then and Now, where I'm showing that advanced vintage HP calcs which were great problem-solvers back THEN in the 80's are NOW still perfectly capable of solving recent non-trivial problems intended to be tackled using modern PCs, never mind ancient handheld calcs.
Now, try and solve the last problem using your vintage HP calcs while abiding by this one rule, s'il vous plait:
    Use any VINTAGE HP CALC (physical/virtual,) coding in either RPN/Mcode, RPL/SysRPL or HP-71B BASIC/FORTH/Assembler. NO CODE PANELS.
Problem 6:  Angle
Once P1 (Probability), P2 (Root), P3 (Sum), P4 (Area) and P5 (Roots) are over, now's the turn for P6 (Angle), the last and allegedly the hardest of the lot, which deals with optimization, namely:
    Six stars of unit mass are fixed at points (2, -1), (2, 0), (2, 1), (3, -1), (3, 0) and (3, 1). A planet of unit mass starts at (0, 0) with unit velocity in direction Angle (in radians, counterclockwise from the X axis,) and travels according to Newton's gravitational law, i.e. under a force of magnitude (di )-2 from each of the six stars, where di is the distance to each star.
    [Image: SRC-12-6-1.jpg]
    Write a program to compute the value of Angle which makes the planet reach the point (4, 1) in the shortest time (a fake path is depicted above) and output the Angle and corresponding minimum time. Assume the gravitational constant G is 1.
Your program should take no inputs and must produce at least 4-5 correct digits (give or take a few ulp), the faster the better.
In a week I'll post my original solution (a straightforward 12-line HP-71B program that does the job) plus comments on my solving strategy and possible enhancements, but first let's see your very own clever solutions. It's your last chance !
V.
Edit: corrected two typos.
05-03-2023, 09:05 AM
RE: [VA] SRC #012f - Then and Now: Angle
Reading Valentin’s original post where he mentions that this last problem of the SRC #12 series is “the last and allegedly the hardest of the lot”, I felt at first discouraged. However, perhaps because I feel more at ease with physics and engineering topics than with advanced mathematics as required in some of his previous problems, I decided to give this one a try.
After some effort to put in paper the equations of motion of the planet in the X-Y plane (position, velocity and acceleration vectors), I realized that they were greatly simplified working with complex numbers. Calculating the gravitational force (i.e., acceleration vector) exerted on the moving planet by the six fixed stars requires just one line of BASIC code in the HP-71B to add the gravitational force of each star (function FNA in line 60 in the program below). Working with complex numbers (which requires the Math ROM), the vectorial operations become extremely simple to implement.
The trajectory is a second-order ordinary differential equation:
p”=f(p) , where f(p)=∑_(i=1)^6▒(s(i)-p)/|s(i)-p|^3
Which can be reduced to a set of two first-order equations:
p’=v
v’=f(p), with boundary conditions p0=[0,0] , v0=[Cos(α),Sin(α)]
Which can be solved using the Runge-Kutta method (FNP in lines 80 to 150).
The problem is that with the Runge-Kutta method we obtain the trajectory of the planet given the position and velocity vector at one end of the trajectory, the starting point (0,0). The position at the target point (4,1) is unfortunately not a boundary condition.
The approach I have followed is to make a sweep of the velocity angle at the starting point, to obtain an ending point where the trajectory crosses the vertical line X=4 (loop starting at line 190).
If the distance of the crossing point to the target point is small enough (less than 0.5), then the program initiates a fine search of the root angle using the FNROOT function of the Math ROM.
For the calculation of the planet trajectory with the Runge-Kutta method I have tried different values of Delta-T (variable H in the program). A smaller Delta-T gives a more accurate result at a cost of longer execution time. A larger Delta-T gives a much less accurate result, particularly if the trajectory travels very close to one of the stars where the gravitational force if very big. I have finally opted for a Delta-T value of 0.025 for the coarse sweep, and a smaller Delta-T of 0.01 for the fine search of the root with FNROOT.
Also, in order not to consume time searching for trajectories that take too long to reach the target point, the trajectory calculation is stopped after the travel time reaches a value of T9=2.5 time units. I started using a larger value of T9, but finally reduced it to 2.5 time units after I saw that the shortest travel trajectory would take less than 2 time units.
In my sleuthing process I have been able to find six starting angles that produce a trajectory arriving at the target point (4,1). These six angles are in the range from -0.5 radians to +0.75 radians (loop staring at line 190). I have scanned the full range from -1 to +1 radians but could not find any additional roots. There may be roots (i.e., trajectories arriving to the target point) for other angles beyond this range, but the travel time will surely be longer, so they are not of interest to us.
Here’s my code for the 71B:
10 DESTROY ALL @ OPTION BASE 1 @ RADIANS
20 COMPLEX P,V,A,S(6),Z,M1,M2,M3,M4,K1,K2,K3,K4
30 INTEGER I,J @ REAL Z0,D,H,L,E(50),U(50)
40 DATA (2,-1),(2,0),(2,1),(3,-1),(3,0),(3,1),(4,1)
50 ! Function to calculate acceleration vector at point P
60 DEF FNA(P) @ A=0 @ FOR I=1 TO 6 @ A=A+(S(I)-P)/ABS(S(I)-P)^3 @ NEXT I @ FNA=A @ END DEF
70 ! Function to calculate trajectory using Runge-Kutta method
80 DEF FNP(D) @ T=0 @ V=(COS(D),SIN(D)) @ P=(0,0)
90 M1=H*V @ K1=H*FNA(P) @ M2=H*(V+K1/2) @ K2=H*FNA(P+M1/2)
100 M3=H*(V+K2/2) @ K3=H*FNA(P+M2/2) @ M4=H*(V+K3) @ K4=H*FNA(P+M3)
110 P=P+(M1+M2+M2+M3+M3+M4)/6 @ V=V+(K1+K2+K2+K3+K3+K4)/6
120 T=T+H @ IF REPT(P)<Z0 AND T<T9 THEN 90
130 IF T>=T9 THEN L=0 @ GOTO 150 ! If time is too long, exit
140 L=IMPT(P)-IMPT(Z)-(REPT(P)-REPT(Z))*(IMPT(V)/REPT(V)) @ T=T-(REPT(P)-Z0)/REPT(V)
150 FNP=L @ END DEF ! L=distance from target vertical line, T=travel time
160 ! Main program SRC #12f
170 T0=TIME @ T5=MAXREAL @ T9=2.5 ! T9 is max trajectory time
180 FOR I=1 TO 6 @ READ S(I) @ NEXT I @ READ Z @ Z0=REPT(Z) ! Read star and target positions
190 FOR D5=-.5 TO .75 STEP .0125 ! Angle search range and step
200 H=.025 @ DISP D5 ! Delta-T for coarse trajectory
210 IF J=0 THEN 230
220 IF D5<E(J) THEN 320 ! If root angle was already found, skip
230 IF ABS(FNP(D5))>.5 THEN 320 ! If too far from target, skip
240 IF T>=T9 THEN 320 ! If time is too long, skip
250 H=.01 @ DISP D5;"*" ! Delta-T for fine trajectory
260 D0=FNROOT(D5,D5,FNP(FVAR)) ! Fine search of root
270 IF T>=T9 THEN 320 ! If time is too long, skip
280 IF J=0 THEN 300
290 IF ABS(D0-E(J))<1.E-11 THEN 320 ! If root angle was already found, skip
300 J=J+1 @ E(J)=D0 @ U(J)=T ! Save root angle and trajectory time
310 IF T<T5 THEN T5=T @ J5=J ! Look for shortest trajectory time
320 NEXT D5 @ T0=TIME-T0
330 DISP "Angle= ";E(J5);"Time= ";T5;T0
The result I obtain with Emu71/Win is:
Angle= -.27488204751 Time= 1.91608960085 298.11
The trajectory with the shortest travel time is with a starting angle of -0.27488204751 radians and its travel time is 1.91608960085 time units.
Execution time with Emu71/Win is 298.11 seconds (on a physical 71B this would take around 80 hours!).
The angles and travel times for each of the six trajectories can be found in vectors E and U:
Angle / Time:
-.461225580816 2.15264790583
-.27488204751 1.91608960085
-.196990737712 1.99997968861
.328560457304 2.02378675724
.55128583185 1.91762537401
.732203465959 2.06532723381
05-03-2023, 07:19 PM
Great explanation!
05-04-2023, 06:31 PM (This post was last modified: 05-04-2023 07:36 PM by J-F Garnier.)
I'm impressed by the performance and quality of the solution from Fernando.
He found all the 6 shortest paths, as far as I can verify them, and some were not easy to catch.
There are probably many more, but much more complex and longer.
At first, I was not sure that integrating the motion equations would work well, because the trajectories are likely to be chaotic. Small changes in the initial angle may produce radically different trajectories, also going too close to a star may produce large acceleration, so integration may not be accurate enough.
So my analysis was looking at other aspects.
One aspect was to consider that the particle (the planet) was free, so the sum of its kinetic energy v²/2 and potential energy (sum of the -1/di quantities for each star at distance di) must be constant.
This gives the value of the final speed:
Initial energy (vi=1 speed) = 1/2 - ( 2/sqr(5) + 1/2 + 2/sqr(10) + 1/3 ) = -1.860
Final energy (vf speed) = 1/2*vf^2 - ( 1/1 + 1/2 + 1/sqr(2) + 2/sqr(5) + 1/sqr(8) )
we get final speed vf = 1.786
Also, since the energy is negative, the planet is bound to the star system and can't escape and may, soon or later, cross the position (4,1) possibly many times.
However, I didn't come to anything really useful for a full solution.
So I was wrong, motion integration was the way to go, and my (small) contribution here will be a few optimizations of Fernando's program.
I noticed that some time consuming fine searches were useless.
I added these 2 tests to avoid them:
- a consistency check of the final speed against the value I calculated above, this protects against some cases where the trajectory goes too close to a star and the integration becomes completely wrong:
    235 IF ABS(V)>2 THEN 320 ! If abnormal final speed, skip
- a better test to avoid testing too close trajectories, that can't be realistic:
    220 IF D5<E(J)+.02 THEN 320 ! If too close from a root angle already found, skip
With these changes, I obtained the same results as Fernando but in 30% less time (223s instead of 326s on my Emu71/Win system).
J-F
05-07-2023, 03:03 PM
I was wondering if Fernando's results were fulfilling the requirement to get "at least 5 correct digits (give or take a few ulp)".
So I tested the solution for different values of the integration step H:
 H          angle (radians)    time
0.05    -.275351678888    1.91851280944
0.02    -.274895222443    1.91612973771
0.01    -.274882047510   1.91608960085 ***
0.005   -.274881158219    1.91608794633
0.002   -.274881218423    1.91609476789
0.001   -.274881245733    1.91609643372
It appears that H=0.01 is the optimum value to get the required 5 correct digits, and it is the value used by Fernando.
Speaking of optimization, there may be some ways to reduce the running time for the solution. At the moment, it would take about 80h of the real HP-71B, can we reduce it to less than a business night (6pm to 9am = 15h) ?
J-F
05-08-2023, 08:40 AM (This post was last modified: 05-08-2023 09:17 AM by Fernando del Rey.)
Thanks, J-F, your two improvements in post #4 make a significant difference in terms of execution speed.
I have tried to optimize speed by using an adaptative H for the Runge-Kutta, with larger H when the absolute value of the acceleration vector A is low, and smaller H when acceleration is high. But I did not get any maningful results out of this idea.
I suspect there must be other cases where the fine search for the root does not make sense and can be aborted, but I could not figure them out.
I'm pretty sure that Valentin's solution is going to be much shorter, faster and cleverer than mine.
05-08-2023, 10:08 PM
Hi, Fernando,
(05-08-2023 08:40 AM)Fernando del Rey Wrote:  I'm pretty sure that Valentin's solution is going to be much shorter, faster and cleverer than mine.
Thanks for your appreciation but let's not raise unwarranted expectations, please. It usually leads to disappointment.
I'll wait some extra days before posting my original solution (concocted almost a year ago), just in case that someone else wants to post something, you optimize your solution even further and/or J-F posts his very own solution.
Talking albout "expectations", this Problem 6 is going to be the one with the least participation in both Replies and Views, as I anticipated. Oh, well ...
Best regards.
V.
05-09-2023, 09:43 AM (This post was last modified: 05-09-2023 02:56 PM by J-F Garnier.)
(05-08-2023 08:40 AM)Fernando del Rey Wrote:  Thanks, J-F, your two improvements in post #4 make a significant difference in terms of execution speed.
There is an easy way to shorten the search for the root, since we are seeking for only 5 significant digits, with this well known trick:
      145 IF ABS(L)<1.E-5 THEN L=0 ! Close enough from the target !
Try it !
(05-08-2023 10:08 PM)Valentin Albillo Wrote:  I'll wait some extra days before posting my original solution (concocted almost a year ago), just in case that someone else wants to post something, you optimize your solution even further and/or J-F posts his very own solution.
So it's time for me to release the latest optimizations I was able to imagine:
- check each trajectory for both the target (4,1) and the symmetric (4,-1) positions, this let us search for positive angles only,
- rewrite the FNA function without loop and without exponentiation (a pure programming optimization),
- replace INTEGER variables with REAL (no speed gain to use INTEGER in 71B BASIC).
The modified program becomes (added/modified lines in bold):
30 REAL I,J,Z0,D,D5,D6,H,L,T,X,E(50),U(50)
60 ! DEF FNA(P) @ A=0 @ FOR I=1 TO 6 @ A=A+(S(I)-P)/ABS(S(I)-P)^3 @ NEXT I @ FNA=A @ END DEF
61 DEF FNA(P) @ X=ABS(S(1)-P) @ A=(S(1)-P)/(X*X*X) @ X=ABS(S(2)-P) @ A=A+(S(2)-P)/(X*X*X)
62 X=ABS(S(3)-P) @ A=A+(S(3)-P)/(X*X*X) @ X=ABS(S(4)-P) @ A=A+(S(4)-P)/(X*X*X)
63 X=ABS(S(5)-P) @ A=A+(S(5)-P)/(X*X*X) @ X=ABS(S(6)-P) @ A=A+(S(6)-P)/(X*X*X)
64 FNA=A @ END DEF
135 IF IMPT(P)>0 THEN D6=D @ L=IMPT(P)-IMPT(Z) ELSE D6=-D @ L=IMPT(P)+IMPT(Z)
140 L=L-(REPT(P)-Z0)*(IMPT(V)/REPT(V)) @ T=T-(REPT(P)-Z0)/REPT(V)
160 ! Main program SRC #12f - with JFG's modif
190 FOR D5=0 TO .75 STEP .0125 ! Angle search range and step
210 IF J=0 THEN 230
220 IF D5<ABS(E(J))+.02 THEN 320 ! If too close from a root angle already found, skip
250 H=.01 @ DISP D6;"*" ! Delta-T for fine trajectory
260 D0=FNROOT(D6,D6,FNP(FVAR)) ! Fine search of root
280 IF J=0 THEN 300
The result is:
Angle= -.274882047936 Time= 1.91608959636 (96.61s)
obtained in about 97s on my Emu71/Win system with ~1400 speed factor,
i.e. about 38 h on a real HP-71B. Not yet a run overnight, but very possible over a week-end.
The 6 trajectories:
    Angle             Time
-.196990679676 1.99998010763
-.274882047936 1.91608959636
 .328560456480 2.0237867079
-.461225625588 2.1526452933
 .551285709122 1.91762496347
 .732203223220 2.06532676912
J-F
Edit: typos.
05-09-2023, 01:37 PM
Although it's not part of Valentin's challenge, I'd love to see what these six trajectories look like!
05-12-2023, 08:04 PM
Hi, all,
Almost two weeks have elapsed since I posted Problem 6 and, as expected, its perceived difficulty has resulted in very few posts, just a single solution (other than my original one, of course) by Fernando del Rey and worthwhile refinements to it by the indefatigable J-F Garnier. Thank you very much to both of you for your interest and overall outstanding contributions.
Now, this is my detailed sleuthing process and resulting original solution, plus additional comments:
My sleuthing process
First of all, the relevant formula is Newton's equation for universal gravitation, further simplified as all seven masses and the gravitational constant G are to be taken as 1. Also, as force, acceleration, velocity and position all are two-component values, representing them using complex numbers is ideal and greatly simplifies the coding while also reducing the running time.
Using the formula we obtain the force exerted by the fixed stars upon the moving planet and thus the acceleration, velocity and position at any given time. I fully knew that those values can be obtained by numerically solving the relevant 2nd-order ordinary differential equation by using for instance a favorite of mine, the 4th-order Runge Kutta method (aka RK4).
However, though this would surely be the choice method for best efficiency, just for fun I decided to use a much simpler, more intuitive procedure, which consist of first computing the force (and thus the acceleration) by adding up the contributions from each star, then updating velocity and position by assuming that the acceleration remains constant within the (tiny) time increment.
This procedure is extremely simple to implement and requires a single call per step to the function which computes the force/acceleration while RK4 would require four calls per step, which for the current complicated function is quite time-consuming. On the other hand, RK4 has a local truncation error (LTE) of O(h5) while the simpler procedure's LTE is O(h2) so we'd be trading accuracy/runtime for algorithmic simplicity; however, for the modest accuracy goal it will likely be adequate enough.
After selecting the algorithm to use, I tried out assorted angles in order to decide on a range where the optimum angle would surely lie, as angles outside it would obviously result in wasteful, unnecessarily longer or even "retrograde" trajectories. Also, though I did notice, I didn't take advantage of the initial position's symmetry. See Notes below.
Now, I'd need to scan the range using a coarse increment (for speed; see Notes below for details on the various heuristics applied) while keeping track of the minimum distance to the destination and, if within a certain tolerance, a refining procedure would then be applied to improve the accuracy, followed by linearly interpolating both angle and time so as to exactly hit the destination (within a small tolerance).
Finally, once the scan is completed, the optimum angle and resulting minimum time among all suitable trajectories would be subjected to a finer refinement to further improve the accuracy. As seen below, this strategy ultimately results in 4-5 correct digits.
My original solution
My original solution is this 12-line, 703-byte HP-71B program:
  1  DESTROY ALL @ OPTION BASE 0 @ DIM B,C,D,J,T,U @ COMPLEX X(6),A,P,Q,S,V,Y,Z @ SETTIME 0
  2  DATA .005,.01,.1,.01,1,9,(0,0),(2,-1),(2,0),(2,1),(3,-1),(3,0),(3,1),4,1
  3  FIX 2 @ READ H,F,M,L,V0,G,X,B,C @ Y=(B,C) @ FOR R=-.5 TO .75 STEP F @ IF FND(R)>M THEN 5
  4  W=FNROOT(R,R,FNY) @ DISP W;T;TIME$ @ IF T<G THEN N=W @ G=T
  5  NEXT R @ H=H/10 @ W=FNROOT(N,N,FNY) @ FIX 4 @ DISP "Min T:";T;"for A:";W;"(";TIME$;")" @ END
  6  Q=P @ A=0 @ FOR J=1 TO 6 @ Z=X(J)-P @ A=A+Z/ABS(Z)^3 @ NEXT J @ P=P+H*V+K*A @ V=V+H*A @ RETURN
  7  DEF FND(R) @ P=X(0) @ V=RECT((V0,R)) @ K=H*H/2 @ U=9 @ FOR T=H TO 3 STEP H @ R=REPT(P)
  8  D=U @ GOSUB 6 @ U=ABS(P-Y) @ IF U>D THEN 'N' ELSE IF REPT(P)<R THEN FND=9 @ END
  9  NEXT T @ 'N': T=T-H @ FND=D @ END DEF
 10  DEF FNY @ H=H/2 @ P=X(0) @ V=RECT((V0,FVAR)) @ K=H*H/2 @ T=0
 11  T=T+H @ GOSUB 6 @ IF REPT(P)<B THEN 11 ELSE S=P-Q @ D=(B-REPT(Q))/REPT(S)
 12  T=D*H+T-H @ H=H*2 @ D=D*IMPT(S)+IMPT(Q)-C @ FNY=D*(ABS(D)>L)
    Notes:
  • Lines 1-2 perform the initialization and define the necessary data. There's no need for a RADIANS declaration because no trigonometric functions are used but RECT, which with a complex argument always uses radians regardless of the angular mode.
    Also, I noticed the symmetry of the starting position (as J-F Garnier did as well) but despite the obvious speed up I decided not to depend on it so that my program would be able to solve generalized cases (including non-symmetric starting positions,) by simply defining all relevant parameters (initial coordinates, velocity, increments, limits, tolerances, etc.) in a single DATA statement.
  • Lines 3-5 are the main program, which coarsely scans a plausible angle range and once a suitable one is found, it uses FNROOT to try and find more precisely the angle which makes the Y coordinate of the final position exactly match the Y of the destination (within a small tolerance).
    Once the scan is over, both a candidate optimum angle and a minimum time have been selected among the tentative trajectories, and then a last, finer refinement is performed to further increase the final solution's accuracy (both angle and minimum time).
  • Line 6 implements a subroutine which is called from both FND and FNY (defined below) and essentially computes the force (and thus the acceleration) upon the moving planet due to the six fixed stars, plus it also updates its current speed and position. It was initially implemented as another UDF but converting it to a subroutine speeds up the process.
  • Lines 7-9 define FND, which computes the resulting trajectory for a given angle and returns an approximation to the minimum distance to the destination, as well as the nearest position's coordinates and the time to reach it. Besides there being a limit on this time, FND further includes heuristics to abort the computation if (a) the current position's X coordinate ever goes backwards or if (b) the distance to the destination eventually increases, to avoid computing a trajectory that can't result in the sought-for minimum time.
  • Lines 10-12 define FNY, which is used while refining the minimum distance for a given angle with greater accuracy than when using FND, and further it interpolates the final coordinates and time so that the X coordinate exactly matches the X of the destination.
  • The MATH ROM is used for all complex-number variable definitions and operations, plus FNROOT is used for the angle refinements.
Let's run it:
    >RUN
      Angle   Time   Runtime
      -0.46   2.15   00:01:26
      -0.27   1.91   00:04:01   {minimum time}
      -0.19   1.93   00:05:41
       0.33   1.97   00:09:28
       0.55   1.92   00:12:06   {second best}
       0.73   2.05   00:14:43
      Min T: 1.9160 for A: -0.2745 (00:24:30) {go71b: 24'30", Emu71/Win: 3'13", HP-71B: ~ 52h}
    The timing for a physical HP-71B may seem a bit steep but it's nothing that an AC adapter and a weekend can't deal with. Just start the program on Friday evening, forget about it and go enjoy the weekend, and by Monday 4 a.m. you'll have the solution displayed, waiting for you to wake up. Smile
The correct 10-digit result is Angle = -0.2748812540, Time = 1.916096918, so we can gauge the accuracy obtained this way:
    >FIX 9 @ T;W
          1.916021524  -0.274541755
    and the errors are:
          (-0.274881254) - (-0.274541755) = 0.000339499
         i.e., we got 4 digits (save 3 ulp)
          ( 1.916096918) - ( 1.916021524) = 0.000075394     i.e., we got 5 digits (save 0.75 ulp)
For the record, the correct answer rounded to 33-34 digits is:
    Angle = -0.274881254026276715509629216558426
    Time  =  1.916096918332004910307460694725436
Additional comments
The six angles obtained by my original solution result in the following trajectories, counterclockwise:
[Image: SRC-12-6-2.jpg]
  • As can be seen in the graphic above, the straightest, most direct paths are the ones for the angles A ~ -0.27 and A ~ 0.55 and matter of fact the latter is clearly the one having the shortest length but the former takes the shortest time, as asked, namely 1.9161 vs. 1.9176, probably due to the close encounter with the (2,0) star significantly increasing the planet's velocity.
    To better see it, an easy challenge extension would be to compute and display not only the arrival time but also the path length and final velocity at the destination for the various trajectories.
  • I hereby "officially" declare J-F Garnier as the valedictorian of this SRC#12, as he posted solutions and/or significant contributions to all six problems, with Fernando del Rey a worthy salutatorian, as he participated in most problems and delivered an excellent solution for this last, allegedly most difficult one. Congratulations and thanks a lot to both of you.
  • Last but not least, I (faintly) hoped that some users of vintage HP graphing calcs would produce RPL solutions, obtaining not just the correct numbers but also graphically depicting the resulting trajectories as shown above, but alas, no such luck. Perhaps it was too difficult, as compared to their usual dealings with this library, or that port, or creating yet another bunch of list utilities and such ...
Well, that's all, at long last SRC#12 has been completed 7 months after I posted Problem 1, and the point has been fully made.
I'm now taking a sabbatical from proposing further elaborate challenges. Thanks for your interest and best regards.
V.
05-14-2023, 08:28 AM (This post was last modified: 05-14-2023 03:20 PM by J-F Garnier.)
Thanks Valentin, for this last episode. It was particularly interesting, and I'm surprised too by the low participation. Especially, graphic calculators able to display the trajectories are missing.
On the other hand, using a fast emulator was really helpful to devise a solution and improvements. Using a real calculator may not be practical, Prime excepted maybe but this machine is not precisely a vintage machine.
Some more comments:
- as I explained, I was not sure that integrating the motion equations would work well. It actually works for this problem because the trajectories are short , and don't pass too close from a star. But generally, the integration fails quickly, and it's impossible to follow the trajectory in this way, after just a few units of time.
- I didn't post a specific solution of mine, because Fernando's solution already had all the key ingredients: angle coarse sweep, RK4 integration, interpolation and fine search with FNROOT. But there was some room for optimisations...
- The HP-71B as no graphic capabilities, so in order to be convinced that the 6 trajectories found by Fernando were the shortest ones, I resorted to my HP BASIC compatible system to display and check the trajectories.
Here is the result:
[Image: attachment.php?aid=12118]
My test program uses the RK4 code from Fernando, but just asks for a starting angle to display the trajectory until crossing the target position.
The lines on top give: starting angle in degrees, final X, Y and speed, and time.
As I demonstrated above, the final speed doesn't depend on the path, the simulation confirms it.
Then, I played further with my code. For most starting angles, it just produces garbage trajectories, but sometime gives funny alternate solutions:
[Image: attachment.php?aid=12123]
See how close starting angles such as 40.8 and 43.3 produce completely different trajectories.
[Image: attachment.php?aid=12124]
So, thanks again, and hope to see more challenges in the future.
J-F
Attached File(s) Thumbnail(s)
05-14-2023, 09:28 AM
Excellent results from a promising challenge! Thanks to all. And for the trajectories!
(The final speeds coming out the same is a good consistency check, I think - energy conservation will, I think, demand that the final energy is the same regardless of path.)
05-14-2023, 04:47 PM
V.
Hi Valentin, participants to all challenges!
First of all thank you Valentin for all your excellent contributions via interesting and fun masterpieces professionally plotted, written and explained here with so special care for all details aiming to our education.
Thanks to all participants for posting solutions which keeps the subject alive. I am a long time follower and enthusiast of those beauties but my skills are just not in par so no active participation from my side. Be sure it does not discourage me to silently follow those threads and studying posts gives me more insight in math, logic, programming - and fun. So thank you again.
Kind regards
Pavel
05-15-2023, 07:11 AM
Dear Valentin,
Thanks for the challenges.
For me, the last one was very interesting, as I have been curious about "rocket science". Probably the low number of replies to the last problem is simply that summer is coming, and also that integration (R_K) seemed to and turned out to work so well. Further, thanks to J-F for showing the paths.
Is it possible to calculate longer paths, say circling the star cluster once twice, or would numerical inaccuracies quickly make any such results rubbish?
BR Gjermund
05-15-2023, 08:09 AM
+1 to what Pavel wrote, from another silent observer. Thanks to Valentin and all the contributors!
vaklaff
05-16-2023, 06:55 PM
Hi, J-F Garnier, pavel nemec cz, Gjermund Skailandand and vaklaff,
J-F Garnier Wrote:Thanks Valentin, for this last episode. It was particularly interesting, and I'm surprised too by the low participation. Especially, graphic calculators able to display the trajectories are missing.
You're welcome, J-F, but I'm not surprised in the least, it's just as expected. Some seven months ago I posted a simple Probability problem which required no special knowledge and I got ~ 90 replies, but now I post a little "physics" problem which requires some very basic knowledge about simple concepts such as force, acceleration, velocity, etc., and I get about 5 replies or less. Oh, well, that's life in this New Forum.
As for vintage graphic calculators missing, consider that all of them are RPL models so no surprise either. ’Nuff said.
J-F Garnier Wrote:See how close starting angles such as 40.8 and 43.3 produce completely different trajectories.
Yes, and to further demonstrate it, in that same figure you include the trajectory for Angle = 80.03º = 1.3968 rad, namely:
[Image: SRC-12-6-4.jpg]
but you don't include the one for the very close Angle = 80.93º = 1.4125 rad (less than 1º apart,) which is much shorter as it doesn't backtrack, though (a) still far from the minimum time, (b) outside of my scanning range, and (c) even if it were included it would nevertheless be rejected by my heuristics.
[Image: SRC-12-6-3.jpg]
pavel nemec cz Wrote:First of all thank you Valentin for all your excellent contributions via interesting and fun masterpieces professionally plotted, written and explained here with so special care for all details aiming to our education. [...] Be sure it does not discourage me to silently follow those threads [...]
Thanks for your kind words, pavel, I'm glad you like my contributions and even somewhat profit from them. As for "silently", as long as you care to post your appreciation here for me to know, your alleged "silence" speaks volumes ! Smile
Gjermund Skailand Wrote:Thanks for the challenges. [...] Is it possible to calculate longer paths, say circling the star cluster once twice, or would numerical inaccuracies quickly make any such results rubbish?
You're welcome, Gjermund, thanks for your interest. As for your question, yes, it's quite possible (if difficult,) see Direct gravitational N-body simulations in N-body simulation.
To minimize numerical inaccuracies while computing the path for extended time periods, it's usually mandatory to use multiprecision with a high-order integration method. For instance, the 33-34 digits I posted were obtained using not RK4 but an RK14 method (which actually produced as many as 50 correct digits that I then rounded down to 33-34 digits for posting here.)
vaklaff Wrote:+1 to what Pavel wrote, from another silent observer. Thanks to Valentin and all the contributors!
Thanks for your appreciation, vaklaff, but as long as you've posted here to voice it, you're not silent anymore. Much appreciated.
Regards to all of you.
V.
