An unexpected result involving sums of random numbers
02-28-2023, 06:41 PM
How many random numbers in the interval [0, 1) are required to add up to 1 or higher, in average?
The following HP-42S and HP-15C programs might give an answer to this question in under one minute on the physical calculators (with some cheating due to the choice of seeds and number of results equal or greater than one), or in reasonable on Free42 and other simulators with a large number of results, regardless of the seeds. HP-42S: Code:
6 SEED 252 XEQ “X” -> ______________ (55.5 seconds on the real calculator) Code:
67 SEED 252 XEQ “X” -> ______________ (63 seconds on the real calculator) HP-15C: Code:
6 STO RAN# 32 f A -> ______________ (55 seconds on the real HP-15C) |
02-28-2023, 07:50 PM
RE: An unexpected result involving sums of random numbers
Hi, Gerson, (02-28-2023 06:41 PM)Gerson W. Barbosa Wrote: How many random numbers in the interval [0, 1) are required to add up to 1 or higher, in average? Excuse me, Gerson, not to rain on your parade or anything but isn't this the same thing I recently discussed in my Concoction the First: Weird limit sub-challenge ? Regards. V. All My Articles & other Materials here: Valentin Albillo's HP Collection |
02-28-2023, 08:48 PM
(02-28-2023 07:50 PM)Valentin Albillo Wrote: . Hello, Valentin, Indeed it is, albeit this is only the first part of #1. I did participate in that one, but I had completely forgotten about it. I only tried to address #6 and overlooked all the rest, it seems. I read about this subject one of these days, in a short note in Prime Obsession, a book by John Derbyshire and decided to check it out. I checked also for 2, e and pi, but except for the first one I was unable to identify the constants. Anyway, we can consider this a (very) belated solution to that particular nice sub-challenge of yours :-) Best regards, Gerson. |
02-28-2023, 11:08 PM
The answer is a squewed distribution (Gauss, or Poisson, or something else?).
I did some quick calculations in Matlab. For the sum of 1, the most frequent number of random numbers is 2. The distribution dies out fast. For the sum of 2, the most frequent number of random numbers is 4. Also, the distribution dies out fast. Namir |
03-01-2023, 03:54 AM
(02-28-2023 11:08 PM)Namir Wrote: The answer is a squewed distribution (Gauss, or Poisson, or something else?). Hi, Namir, Perhaps my phrasing was not so clear. Let’s do an example by hand on the HP-15C, step by step: 0 STO RAN#; start the sequence of random numbers with zero 1) f RAN# -> 0.1018 f RAN# -> 0.7365 + -> 0.8383 ; sum < 1, go on: f RAN# -> 0.3248 + -> 1.1631 ; sum >= 1 obtained with 3 random numbers. 2) f RAN# -> 0.3485 f RAN# -> 0.8685 + -> 1.2171 ; sum >= 1 obtained with 2 random numbers. 3) f RAN# -> 0.2789 f RAN# -> 0.3615 + -> 0.6404 ; sum < 1, go on: f RAN# -> 0.1074 + -> 0.7448 ; sum still < 1, go on: f RAN# -> 0.2629 + -> 1.0106 ; sum >= 1 obtained with 4 random numbers. 4) f RAN# -> 0.9252 f RAN# -> 0.5599 + -> 1.4851 ; sum >= 1 obtained with 2 random numbers. Average: (3 + 2 + 4 + 2)/4 = 2.75 That’s exactly what we get when running the program: 0 STO RAN# 4 f A -> 2.7500 The result, 2.75, is close to the constant we’re looking for. I thought of providing an HP-41C program, but then I remembered it lacks a random number generator. Gerson. |
03-01-2023, 01:54 PM
The answer I got was about 3.5. However that was with a normal distribution with mean of 0.5 and standard deviation of 1. 8^)
While I did it in Matlab, it would be easy on the Prime. |
03-01-2023, 03:14 PM
Could anybody present a nice, understandable proof for one of the results, for example for the average "—> e" in case "sum of necessary numbers >=1"?
In a far-fetched way, it reminds me of Benford law, with % of number i(i=1,2... 9) at first place = log (1+1/number i). Regards, Gil |
03-01-2023, 03:36 PM
This post reminded me of something I had seen before posted on Reddit r/programming a couple of years back.
The mean-sum-rand-to-one turns out to be a kinda-sorta-known result, if you're "obsessed with primes" Spoiler alert, do not follow these links: a wonderful article at Mostlymaths with an explanation at Math.Stackexchange Quite intriguing. - Rob "I count on old friends" -- HP 71B,Prime|Ti VOY200,Nspire CXII CAS|Casio fx-CG50...|Sharp PC-G850,E500,2500,1500,14xx,13xx,12xx... |
03-01-2023, 05:03 PM
(03-01-2023 03:36 PM)robve Wrote: Spoiler alert, do not follow these links: a wonderful article at Mostlymaths with an explanation at Math.Stackexchange Thanks for the links! These alone have made worthwhile starting this thread. Gerson. |
03-01-2023, 05:21 PM
(This post was last modified: 03-01-2023 05:50 PM by Gerson W. Barbosa.)
RE: An unexpected result involving sums of random numbers | |||
03-01-2023, 07:14 PM
(03-01-2023 03:54 AM)Gerson W. Barbosa Wrote:(02-28-2023 11:08 PM)Namir Wrote: The answer is a squewed distribution (Gauss, or Poisson, or something else?). Your results are good. With one million iteration I get an average of 2.71. With a sum of 2 I get an average of 4.6. And with an average of 3 I get an average of 6.5. Namir |
03-02-2023, 02:06 PM
If random values are discrete, say coin flips, (head=1, tail=0), the expected value (sum ≥ 1) = 1/p = 2
Code: n * P(n) This gives a neat prove for E = Σ(n/2^n, n=1 .. Inf) = 1/p = 2 see https://math.stackexchange.com/questions...onverge-to At the end of each simulation, sum is exactly 1, without "waste". https://www.fourmilab.ch/documents/random_sum/ examples ("waste" in bold) 0.4770 + 0.0516 + 0.1793 + 0.2250 + 0.0438 + 0.3006 = 1.2773 0.8474 + 0.3005 = 1.1479 0.5535 + 0.2721 + 0.5390 = 1.3646 ... For continuous uniform distribution of [0, 1), we do have wastage (almost always) Last random number, on average = 0.5 Balance (before adding last random number), on average, between 0.5 to 1.0 1.0 < E*0.5 < 1.5 → 2.0 < E < 3.0 FYI, above link has the prove for E = e ≈ 2.71828 |
03-02-2023, 09:15 PM
On HP50G, after a loop of 100 000,
I get an average of 2.80983 for "sum > 1" and 2.58946 for "sum >= 1" with seed (RDZ) =1. It does not seem to converge to e, or very, very slowly. Is it normal? |
03-02-2023, 10:00 PM
(03-01-2023 07:14 PM)Namir Wrote: Your results are good. With one million iteration I get an average of 2.71. With a sum of 2 I get an average of 4.6. And with an average of 3 I get an average of 6.5. I have modified two programs to handle arbitrary sums. Even 5000 iterations, which is quite feasible on the HP-15C LE, will give results close to the theoretical values: 1 -> 2.7182818; e 2 -> 4.6707743; e(e - 1) 3 -> 6.6665656; e(2e² - 4e + 1)/2 Code:
0 STO RAN# 1 ENTER 5000 f A -> 2.7152 ( 55.5 seconds ) 0 STO RAN# 2 ENTER 5000 f A -> 4.6656 ( 100.6 seconds ) 0 STO RAN# 3 ENTER 5000 f A -> 6.6754 ( 146.7 seconds ) Of course, on a computer or smartphone running Free42 we can go even further. For instance, Code: 00 { 40-Byte Prgm } 4 SEED 1 ENTER 1E7 XEQ “X” -> 2.7181530 ( 29.4 seconds ) 4 SEED 2 ENTER 1E7 XEQ “X” -> 4.6711803 ( 50.1 seconds ) 4 SEED 3 ENTER 1E7 XEQ “X” -> 6.6667329 ( 71.6 seconds ) As mentioned earlier in this thread, I was motivated by a short note on a book I read some years ago and ran into it again last week, which read Quote:Here is an example of e turning up unexpectedly. Select a random number between 0 and 1. Now select another and add it to the first. Keep doing this, piling on random numbers. How many random numbers, on average, do you need to make the total greater than 1? The answer is e. Not forgetting about Valentin's Math Challenge linked above would have spared me some time, but then again I would have lost the chance to dust off my calculators and check that out for myself. Detailed information and a shorter and possibly faster RPN program also available in his original solution. Thanks you all for your interest and contributions. Gerson. |
03-02-2023, 10:01 PM
In Matlab with the following script:
sumcount = 0; for i = 1:100000 s = 0; count = 0; while s <= 1 s = s+random('Uniform', 0,1); count = count + 1; end sumcount = sumcount + count; end avgcount = sumcount/100000; I get: 2.7195 2.7196 2.7190 2.7175 2.7183 Or, much better than yours. Of course this does not really "converge" to e. |
03-02-2023, 10:02 PM
I get an average of 2.80983 for "sum > 1" and 2.58946 for "sum >= 1" with seed (RDZ) =1. And, after a loop of 1000 000, I get an average of 2.80983 for "sum > 1" and 2.590195 for "sum >= 1" for "sum >= 1" with seed (RDZ) =1. It does not seem to converge to e, or very, very slowly. The program is the following: \<< TIME 0. 'N' STO 1. RDZ 1. 1000000. START 0. 'S' STO WHILE S 1. \<= REPEAT RAND 1. RND 'S' STO+ 1. 'N' STO+ END NEXT N 1000000. / TIME ROT HMS- \>> Is it normal? |
03-02-2023, 10:20 PM
(This post was last modified: 03-02-2023 10:45 PM by Gil.)
Sorry.
I added a "1 RDZ" unduly in the second part of the program. The found values indeed —> clearly to 2.7 or 2.8, ie e. "\\<< TIME 0. 'N' STO 1. RDZ 1. 100000. START 0. 'S' STO WHILE S 1. \\<= REPEAT RAND 'S' STO+ 1. 'N' STO+ END NEXT N 100000. / TIME ROT HMS- \\>>" Gives 2.71959. With my apologies. |
03-04-2023, 01:32 PM
Same result on the HP 50g. It should take longer on the HP-48G/GX. Even longer on the HP-28S.
1 RDZ 100000 « 0 DUP2 NOT SWAP START RAND DO RAND + SWAP 1 + SWAP DUP UNTIL 1 > END DROP NEXT SWAP / 1 + » TEVAL -> 2.71959 s:1365.9755 (HP 50g) s:57.9261 (iHP48) |
03-04-2023, 02:29 PM
(03-02-2023 02:06 PM)Albert Chan Wrote: Last random number, on average = 0.5 I was wrong about last random number average = 0.5 Balance likely contains many small numbers. Last random thus pushed higher (on average). lua> N = 1e7 -- simulations lua> S, R, E = 0, 0, 0 lua> for i = 1, N do : s = 0; repeat r=random(); s=s+r; E=E+1 until s >= 1 : S, R = S+s, R+r : end lua> S, R, E = S/N, R/N, E/N lua> B = S-R lua> B, R, S 0.7182663624489083 0.6408642227941028 1.3591305852430111 lua> e = exp(1) -- simulation suggested (B+R = S) values, for huge n lua> e-2, 2-e/2, e/2 0.7182818284590451 0.6408590857704775 1.3591409142295225 We expected E*0.5 ≈ S. Here, expected counts estimated with 2S is better than E. lua> E, 2*S 2.7186766 2.7182611704860222 |
03-04-2023, 03:09 PM
And Barbosa's program on EMU48, with Samsung A53:
Less than 13s in approximate mode [/php]for average "1 to 100 000 and seed =1". Parabéns, Gérson! |
