HP 40gs how to get a submartix from a matrix
08-31-2023, 04:30 AM
I have a 3x3 matrix:
M1 =
1,2,3
4,5,6
7,8,9
It is stored as:
[[1,2,3],[4,5,6],[7,8,9]] STO M1
Display M1
M1 ENTER
How do I get a sub-matrix such as:
M2 =
5,6
8,9
Are there any column and row operations or any indexing operations in order to get a sub matrix M2?
By indexing operations, using index and row column numbers as in arrays in python, matlab.
Thank you
Anthony of Sydney
08-31-2023, 02:40 PM
RE: HP 40gs how to get a submartix from a matrix
I'm not familiar with the HP 40gs but you could use matrix multiplication.
In Python:
import numpy as np
M = np.array(
        [1, 2, 3],
        [4, 5, 6],
        [7, 8, 9],
U = np.array(
        [0, 1, 0],
        [0, 0, 1],
V = np.array(
        [0, 0],
        [1, 0],
        [0, 1],
U @ M @ V
The result is:
array([[5, 6],
       [8, 9]])
08-31-2023, 03:07 PM (This post was last modified: 08-31-2023 03:51 PM by Gilles.)
i've no HP40G here but perhaps :
MAKEMAT(M1(I+1,J+1),2,2)
2,2 are the size of the result matrix
First argument is the expression to calculate for each I,J position in the resulting matrix. No needs to loop, its automatic
08-31-2023, 11:56 PM
Dear Thomas and Gilles,
Thank you both for your replies.
I learnt two new things:
In python, I learned a way of multiplying matrices:
To illustrate:
result = U @ M @ V
Is not the same as
result = U * M * V
In the first statement, the "@" does matrix multiplication.
But in the second statement, the "*" does element-by-element multiplication.
Also learnt that
result = V @ M @ U
produces
[[0 0 0] [0 0 0] [0 0 0]]
For the HP 40GS, one can do subsets of matrices:
MAKEMAT(M1,(I+1,J+1),2,2) STO M2. will produce a submatrix
[[5,6],[8,9]]
Question please
Is there a general method to get any 2x2 submatrix from a 3x3 submatrix using MAKEMAT?
Eg
[[1,3],[7,9]]
Thank you
Anthony ofvSydney
09-01-2023, 02:31 AM
While I tried experimenting with the MAKEMAT in the hp 40gs, it seems to operate with ONLY adjacent rows and columns.
Eg:
MAKEMAT(M1(I,J+1),2,2) returns
[[2,3],[5,6]]
MAKEMAT(M1(I+1,J),2,2) returns
[[4,5],[7,1]]
It appears that you cannot use MAKEMAT to produce a desired result of
[[1,3],[4,6]]
BUT applying the method in the python example it is possible
In the original example we had M1.
We make a matrix M2 being our U
[[0,1,0],[0,0,1]] STO M2
We make a matrix M3 being our V
[[0,0],[1,0],[0,1]] STO M3
Then applying our python program U@M@V
M2*M1*M3
[[5,6],[8,9]]
Similarly apply this
[[1,0,0],[0,0,1]] STO M2
[[1,0],[0,0],[0,1]] STO M3
M2*M1*M3
[[1,3],[7,9]]
Now to get [[1,3],[4,6]]
[[1,0,0],[0,1,0]] STO M2
M2*M1*M3
[[1,3],[4,6]]
Thank you
Anthony, Sydney
09-01-2023, 06:15 AM
(08-31-2023 11:56 PM)Anthony The Koala Wrote:  In python, I learned a way of multiplying matrices:
To illustrate:
result = U @ M @ V
Is not the same as
result = U * M * V
The @ operator only works on objects of type array from numpy.
While you can multiply a list by an integer the result is probably not what you expected.
For objects of type Matrix from sympy you have to use the ordinary * operator:
P = U * M * V
This library allows to use fractions and return the result in LaTeX:
from sympy import latex
print(latex(P.inv()))
\left[\begin{matrix}-3 & 2\\\frac{8}{3} & - \frac{5}{3}\end{matrix}\right]
Or then:
09-01-2023, 07:27 AM
Dear Thomas,
To get an invervse of a matrix P
import numpy as np
from numpy.linalg import inv
#code to calculate the matrix
#defined M1, M and M3
P = M2@M@M3
P = np.matrix(P)
#prints the output of latex output. Normally output to a tex file
print(latex(inv(P)))
Thank you
Anthony, Sydney
09-03-2023, 08:02 AM (This post was last modified: 09-03-2023 03:20 PM by carey.)
(08-31-2023 04:30 AM)Anthony The Koala Wrote:  I have a 3x3 matrix:
M1 =
1,2,3
4,5,6
7,8,9
It is stored as:
Display M1
M1 ENTER
M2 =
5,6
8,9
Thank you
Anthony of Sydney
Hi Anthony,
In answer to your original question using HP40GS commands, the command
SUB M2;M1;{2,2};{3,3}
entered on the Home screen extracts submatrix M2 from matrix M1, starting at {2,2} in a list using row, column notation and ending at {3,3}.
Before issuing the above SUB command, the original 3x3 matrix M1 and an arbitrary 2x2 M2 matrix must be created.
Attached are HP40GS emulator screenshots of the original matrix M1, arbitrary matrix M2 filled with zeros, and the Home screen showing the SUB command and the resulting sub-matrix M2 that you are seeking.
Additional Notes:
1) The above command also works within a program if the command line ends with a colon as follows
SUB M2;M1;{2,2};{3,3}:
In fact, the SUB command can be accessed from CMDS (Shift-MATH) on the keyboard which shows available program commands.
2) As the SUB command is not part of the 40GS CAS, it works also on the HP39GS (as well as the 39G+, 39G, and 38G).
Attached File(s) Thumbnail(s)
