HP48gx/50g - INFORM command
12-16-2023, 10:18 AM
I have developed some programs with an input mask defined using IFB tool.
I would like to make the programs fully compatible with both calculators, hence I would get rid of IFB (which produces platform-dependent SysRPL code) and switch to INFORM.
Unfortunately the description on AUR is quite obscure, with only one code example.
Where can I find more information?
Thank you
12-16-2023, 05:53 PM
RE: HP48gx/50g - INFORM command
Here is a list of books in which you'll find informations about the INFORM command:
  1. HP 48G AUR
  2. HP 48G User's Guide
  3. HP-48 insights Part I: Principles and Programming
  4. The HP 48 Handbook 2nd Edition
  5. An Easy Course in Using and Programming the HP 48G/GX
Bruno
Sanyo CZ-0124 ⋅ TI-57 ⋅ HP-15C ⋅ Canon X-07 + XP-140 Monitor Card ⋅ HP-41CX ⋅ HP-28S ⋅ HP-50G ⋅ HP-50G
