TI Math/Utilities & HP-41 Advantage Integration Programs
12-24-2023, 08:09 PM (This post was last modified: 12-24-2023 08:11 PM by Matt Agajanian.)
Hi all. Since I have RCL-59, I’m looking for a listing of Romberg Integration from the Math/Utilities SSM. Only the Master Library module is included in RCL-59 and no, there are no In-App modules available.
By the same token, does anyone have the listing for the integration program from the HP-41 Advantage module?
Thanks.
12-25-2023, 03:45 AM
RE: TI Math/Utilities & HP-41 Advantage Integration Programs
I'm not sure if it helps, but the app for Android ti5x does have the math module, and others..
As for the 41, maybe Bob, Massimo or Diego can help you?
Merry Christmas!
JL
12-25-2023, 03:55 AM
(12-25-2023 03:45 AM)Jlouis Wrote:  I'm not sure if it helps, but the app for Android ti5x does have the math module, and others..
Merry Christmas!
JL
Which makes me wonder why the iOS version only has the Master Library.
Merry & Happy to you as well!
12-25-2023, 12:37 PM
(12-24-2023 08:09 PM)Matt Agajanian Wrote:  does anyone have the listing for the integration program from the HP-41 Advantage module?
This is not what you asked for but here is Jean-Marc Baillard's Romberg's method for the HP-41.
12-25-2023, 01:44 PM
(12-24-2023 08:09 PM)Matt Agajanian Wrote:  Hi all. Since I have RCL-59, I’m looking for a listing of Romberg Integration from the Math/Utilities SSM.
This may help.
(12-24-2023 08:09 PM)Matt Agajanian Wrote:  By the same token, does anyone have the listing for the integration program from the HP-41 Advantage module?
The Advantage Solve an Integrate routines come from the HP-15C and are coded in mcode, I don’t think that their listing has been published and I doubt that it would be useful for the TI-59 anyway.
12-25-2023, 10:22 PM
You will find the "Math Utilities" module for download on my "ti58c" site in the "ti58c emulator" page.
For information, the MU-10 module contains 21 programs :
- Prompt
- Alpha messages
- Print formatting
- Superplotter
- Sorting
- Data arrays
- Data packing
- Prime factors
- Hyperbolic functions
- Gamma function
- Factorials
- Random numbers
- Normal distribution
- Interpolation.
- Roots of a function
- Maximum/minimum
- Romberg Integration
- Differential equations
- Discrete Fourier series
- Calculator stalus
- Arithmetic variable
http://ti58c.phweb.me
http://clones.phweb.me
http://www.instagram.com/ti58c
"No! Do or Do not. There is no try!" [Master Yoda]
12-26-2023, 02:07 AM
Is there a way to get this to work with RCL-59 ?
I had thought the answer was no… ?
12-26-2023, 05:55 AM
(12-26-2023 02:07 AM)Gene Wrote:  Is there a way to get this to work with RCL-59 ?
I’m in the same boat also. I have an iPhone 13. So RCL-59 is the version for iPhone/iOS. So yes, is there a way for the Math/Utilities module to be installed in RCL-59?
