Mathematician Finds Easier Way to Solve Quadratic Equations
04-23-2024, 07:20 PM
This article apparently first ran in Popular Mechanics... who knew to look there for math news??
Let the doubters and defenders come forth and critique.... --Bob Prosperi |
04-23-2024, 08:36 PM
RE: Mathematician Finds Easier Way to Solve Quadratic Equations
(04-23-2024 07:20 PM)rprosperi Wrote: This article apparently first ran in Popular Mechanics... who knew to look there for math news?? The YouTube video linked in the article is four years old and we haven't heard of this "easy" method ever since. So my conclusion is, that Mr. Darwin's principle took care of it ;-) But really I find it hard to understand what he is explaining there and how his method would work so easily with non-integer factors. Regards Max |
04-23-2024, 11:19 PM
(04-23-2024 07:20 PM)rprosperi Wrote: This article apparently first ran in Popular Mechanics... who knew to look there for math news?? Here is an HP-42S program using his method: Code:
Same usage of this quadratic solve and same number of steps. This first attempt takes up one extra byte, though. |
04-24-2024, 12:20 AM
04-24-2024, 12:34 AM
(04-23-2024 08:36 PM)Maximilian Hohmann Wrote: Hello! Indeed he doesn’t explain it step by step. Hopefully, the following is easier to understand: x² + b.x + c = 0 x₁ + x₂ = -b x₁.x₂ = c u = (x₁ + x₂)/2 = -b/2 => x₁ = -b/2 - u (1) x₂ = -b/2 + u (2) and x₁.x₂ = c (-b/2 - u)(-b/2 + u) = c or, from the difference of squares formula, (-b/2)² - u² = c u² = (-b/2)² - c u = √((-b/2)² - c) Then, from (1) and (2) above: x₁ = -b/2 - √((-b/2)² - c) x₂ = -b/2 + √((-b/2)² - c) Regards, Gerson. |
04-24-2024, 04:14 AM
(This post was last modified: 04-25-2024 05:17 PM by Gerson W. Barbosa.)
(04-23-2024 11:19 PM)Gerson W. Barbosa Wrote: Same usage of this quadratic solve and same number of steps. This first attempt takes up one extra byte, though. Second attempt. Same size, same number of steps: Code:
P.S.: Exactly the same program, actually. But I don’t remember I had previously used this method. P.P.S.: HP-41 version: Code:
28 bytes Notice these preserve the original stack register X. |
04-24-2024, 03:11 PM
(This post was last modified: 04-24-2024 05:35 PM by Dave Frederickson.)
(04-23-2024 07:20 PM)rprosperi Wrote: This article apparently first ran in Popular Mechanics... who knew to look there for math news?? Ahhh, Popular Mechanics. My step-father had a subscription/prescription. I remember the article from the '60's about spiders on LSD spinning rectangular webs. |
04-25-2024, 12:17 AM
I couldn't get it to work on this: x^2+4x+7=0.
04-25-2024, 03:16 AM
RE: Mathematician Finds Easier Way to Solve Quadratic Equations | |||
04-25-2024, 03:49 AM
There must be something I haven't understood. How is this new? I learned this method at school 40 years ago.
That said, thanks for reminding me. |
04-25-2024, 07:11 AM
Hello all,
it works on equations with complex roots, too. The new way can be reduced to two steps: \[ 1.\quad u^2 = \frac{b^2}{4} - c \qquad\qquad 2.\quad x_{1,2} = - \frac{b}{2} \pm \sqrt{u^2} \] The traditional way: \[ 1.\quad D = b^2 - 4c \qquad\qquad 2.\quad x_{1,2} = \frac{- b \pm \sqrt{D}}{2} \] For me it seems to be a question of taste which way someone prefers. The only difference is: \[ D = 4u^2 \] |
04-25-2024, 09:27 AM
same? (anno 198x)
https://www.hpmuseum.org/forum/thread-14...#pid145482 HP71 4TH/ASM & Multimod, HP41CV/X & Nov64d, PILBOX, HP-IL 821.62A & 64A & 66A, Deb11 64b-PC & PI2 3 4 w/ ILPER, VIDEO80, V41 & EMU71, DM41X, HP75D |
04-26-2024, 12:51 AM
(This post was last modified: 04-26-2024 12:52 AM by Pyjam.)
I'm delighted that this subject has allowed me to rediscover this formula, whose simplicity I admire.
x² − Sx + P = 0 With S = Sum, P = Product, M = Mean, δ = Deviation M = S/2 δ² = M² − P x = M ± δ Code: Input Sum |
04-26-2024, 04:18 AM
(This post was last modified: 04-26-2024 04:20 AM by Rolief_Rechner.)
Would be grateful if someone could direct to instructions for including formula with text.
Ended up attaching a pdf. Regards - RR |
04-26-2024, 06:01 AM
(04-26-2024 04:18 AM)Rolief_Rechner Wrote: Would be grateful if someone could direct to instructions for including formula with text. \( \begin{align} x_{1,2} = - \frac{b}{2a} \pm \sqrt{\left(\frac{b}{2a}\right)^2 - \frac{c}{a}} \end{align} \) Which is the same as the well-known quadratic formula: \( \begin{align} x_{1,2} = \frac {-b \pm \sqrt {b^2 - 4ac}}{2a} \end{align} \) Just this post to see how to use LaTeX. PS: You missed a factor 2 in the denominator. |
04-26-2024, 09:25 PM
Thomas Klemm wrote:
... PS: You missed a factor 2 in the denominator. - - - - Enjoy reading your (and others) post here. Have learned much. It is nice knowing RPN users are not alone. However, this must be politely pointed out. Those who are used to textbook formula make this error. A consolation is you are not the first to do this. Have attached pdf of short Mathcad worksheet for illustration. best regards - RR |
04-27-2024, 10:50 AM
(04-26-2024 09:25 PM)Rolief_Rechner Wrote: A consolation is you are not the first to do this. I'm not sure I understand you correctly, but your QuadForm.pdf attachment uses the following incorrect formula: \( \begin{align} x_{1,2} = - \frac{b}{a} \pm \sqrt{\left(\frac{b}{a}\right)^2 - \frac{c}{a}} \end{align} \) This led to my comment. Example \( \begin{align} a &:= 1 \\ b &:= -5 \\ c &:= 6 \\ \\ x_{1,2} &= 5 \pm \sqrt{19} \\ \\ x_1 &\approx 0.641101 \\ x_2 &\approx 9.3589 \\ \end{align} \) \(\Rightarrow\) Incorrect BTW: The proper way to quote a post is using the button: (04-26-2024 06:01 AM)Thomas Klemm Wrote: PS: You missed a factor 2 in the denominator. |
04-27-2024, 08:21 PM
(This post was last modified: 04-27-2024 08:23 PM by Rolief_Rechner.)
(04-27-2024 10:50 AM)Thomas Klemm Wrote:(04-26-2024 09:25 PM)Rolief_Rechner Wrote: A consolation is you are not the first to do this. The formula is derived by completing the square. It was checked with Wolfram Alpha, attached. If you still insist this is wrong, remedial education is suggested. |
04-27-2024, 09:02 PM
(04-27-2024 08:21 PM)Rolief_Rechner Wrote: The formula is derived by completing the square. This is where it get wrong. (x + y)^2 = x^2 + 2 xy + y^2 a*x^2 + b*x + c = 0 x^2 + (b/a)*x + (c/a) = 0 x^2 + (b/a)*x + (b/(2a))^2 = (b/(2a))^2 - (c/a) (x + b/(2a))^2 = (b/(2a))^2 - (c/a) x = -b/(2a) ± √((b/(2a))^2 - (c/a)) |
04-28-2024, 12:37 AM
(04-27-2024 09:02 PM)Albert Chan Wrote:(04-27-2024 08:21 PM)Rolief_Rechner Wrote: The formula is derived by completing the square. That is what I ended up with also. It is simpler than what most textbooks have. Once I stumbled upon this, loved it. Regards - RR |
