INPUT Command Syntax (SOLVED).
03-23-2015, 05:13 PM
(This post was last modified: 03-24-2015 07:07 PM by Spybot.)
Hi Everyone!! I guess I need a little bit of help on the syntax of the INPUT command. I'm trying to create some sort of drop-down menu, so I can choose an option. I read the UG. and the built-in help on the calculator, I entered the corresponding code for that, and I'm still getting an error message. ("see screenshot # 1") I'm trying to create something like the screenshot # 2 & 3. here is my code: EXPORT program() BEGIN INPUT({D,{"OPTION 1","OPTION 2","OPTION 3","OPTION 4"},{20,70,3}},{"Main title"},{"LABEL"},{"HELP 1","HELP 2","HELP 3","HELP 4"},0,0); END; Thanks, any help will be appreciated. Spybot. |
03-23-2015, 06:44 PM
RE: INPUT Command Syntax
Two things. You are attempting to create a field for variable D, and then a non-existent type. Look at your variable list: {D,{"Strings"...
Also, you are defining help strings for 4 fields. Code: EXPORT program() Adding { } around the title field and similar is for additional pages of your input form. If you have one, no need to have it. TW Although I work for HP, the views and opinions I post here are my own. |
03-23-2015, 07:24 PM
Thank You Tim.
I notice something in the piece of code you wrote: {{D,{"OPTION 1","OPTION 2","OPTION 3","OPTION 4"},{20,70,3}}} ... In this line, it seems to me that there is an extra pair of brackets {}, so I took them out and ran the program, I realized that it didn't run!, so I put them back in place and it worked again. my question is why an extra pair of brackets make the difference? Spybot. |
03-23-2015, 08:06 PM
To define a choose in an an input form, you create a list of the form {var,{"choices"...}}.
{ A,B,{C,{"choices"...}} } is 3 objects, A, B and a choose object. Doing {D,{"choices"...} has made one real input D, and then an invalid input item - hence the error. TW Although I work for HP, the views and opinions I post here are my own. |
03-23-2015, 09:16 PM
That make sense Tim, Thank you for your answer.
Spybot. |
