HP-48 as external core for an Arduino
01-06-2014, 06:44 PM (This post was last modified: 01-06-2014 09:23 PM by eried.)
This is from a few years ago, but since Arduino is probably trending topic maybe it is interesting to keep records of this procedure.
1) Connections
You can use an audio-cd cable for the connections. Just follow:
[Image: bmpkfzJvJixzo.bmp]
HP-48 GND to Arduino GND, RX to TX and TX to RX arduino pins respectively.
2) HP-48 serial server code scripts
START:
<< CLLCD 0 'N' STO CLOSEIO CLLCD "READY" 1 DISP OPENIO REV >>
REV:
<< CLLCD BUFLEN DROP SRECV DROP DUP "" == IF THEN DROP ELSE RREP OBJ-> END REV >>
RREV:
<< BUFLEN DROP SRECV DROP DUP "" == IF THEN DROP ELSE RREP 1 CLLCD DISP END REV >>
RREP:
<< "" -> S Q << S 1 S SIZE START DUP NUM 255 - NEG 2 / CHR Q SWAP + 'Q' STO TAIL NEXT DROP Q >> >>
P:
<< BUFLEN DROP SRECV DROP >>
IOPAR (it's the default one):
{ 9600 0 0 0 3 3 }
3) Arduino sample code
Just send 0x00 and then any command you want to evaluate!
void setup()
  Serial.begin(9600);
  // Preparing the calculator
  Serial.print(0x00,BYTE);
  Serial.print("#131 #64 BLANK PICT STO { #0 #0 } PVIEW ");
  delay(100);
  Serial.print("\"\\<<\" \"HELLO WORLD\" 34 CHR SWAP + 34 CHR + \"
MSGBOX \\>>\" + + OBJ\\-> 'helloworld' STO ");
  delay(100);
  Serial.print("PICT { #2 #2 } \"Starting...\" 1 \\->GROB REPL
1000 0.2 BEEP 2000 0.1 BEEP 1 WAIT");
If you want responses from the arduino, you have to XMIT them to you back to the microprocessor, example:
Serial.print("1 1000 FINDPRIMESROUTINE XMIT");
And that's all!
___________________________
Working sample
Here is a bit more lengthy sample for the arduino:
http://servicios.ried.cl/arduino/hp48_la...ounter.pde
That counts boxes:
My website: erwin.ried.cl
