log(value,base) versus logb(value,base)
04-11-2015, 12:32 PM
exac mode and simplify maximun
logb(e,i) => -2*i/π ok // base i, value e log10(e)/log10(i)==logb(e,i) => 1 = true ok but the exact mode shows approximate =( log10(e)/log10(i) => −0.636619772368*i log(e,i) => [ (i*π/2), 1] ? |
04-11-2015, 03:31 PM
RE: log(value,base) versus logb(value,base)
Same reason sin(1,2,3,4) is a perfectly valid input in the CAS. Any number of arguments are accepted and calculated as [sin(1),sin(2)...]
04-11-2015, 10:33 PM
the help of log says:
LOG(Value, [base]) log(8,2) => 3 log(e,i) => base=I, value=e => [ (i*π/2), 1] ? |
04-11-2015, 11:39 PM
In the CAS environment, objects separated by commas are elements of a list. Thus command(a,b,c,d) is actually interpreted as command([a,b,c,d]) where [] is a list (in the CAS environment). Secondly, LOG() and log() are different commands. You are probably trying to evaluate LOG(e,i), which is \( \log_i(e) \). However, if you type log(e,i) in the CAS environment then this is equivalent to LN({e,i}) in the Home environment since the CAS implements ln(x) as log(x) -- most CAS do this as well.
That said, when I type in log(e,i) in the CAS view, I get \( [1 \quad \frac{i}{2}*\pi ] \) and not the reverse-ordered list that you typed. Graph 3D | QPI | SolveSys |
04-13-2015, 02:35 PM
(This post was last modified: 04-13-2015 03:47 PM by compsystems.)
Thanks Han
Without a real help, it is difficult to manipulate the hpPrime the true help LOG command should be as follows, are agree or not? General Logarithm
LOG(Value,[Base])General logarithmic function Return the logarithm of value in Base, By default, Base=10 Example LOG(100,10) ▶ 2 LOG(100) ▶ 2 LOG(10,2.) ▶ 3.32192809489 LOG(10,e^1.) ▶ 2.30258509299 log(Value1,[Value2],[Value n]) Return the natural logarithm of value(s) Example log(100,10) ▶ [ln(100),ln(10)] ok ln(100.,10.) ▶ [ 4.60517018599,2.30258509299 ] I agree that the command can be written in lowercase or uppercase, to duplicate the function of the same =), is not valid is that no finds a documentation or help of each case |
