SandMath incomplete beta function broken?
01-16-2016, 07:25 PM
When trying to evaluate incomplete beta (ICBT) on the two versions of SandMath I'm using (SM9F and SM9G), the calculator just displays "RUNNING..." for a long time and never converges on an answer. ICBT is a FOCAL program, so I decided to have a look at it. It has an inauspicious beginning...
01 ST* 01
02 STO 00
03 STO 00
...and continues on for some 66 lines, eventually attempting to find the answer via the generalized hypergeometric function, HGF+. I tried calculating incomplete beta manually using SandMath's HGF+ function, and I get the right answer, with HGF+ converging reasonably quickly.
I don't have room in my NoV64 for the 32K monster that the latest SandMath has become, so I was wondering if someone with a 41CL could see if the function has been fixed. You can use the example from the manual:
PI
1
E^X
0.7
XEQ “ICBT“
->0.029623046
Thanks.
David Brunell
Houston, Texas
01-16-2016, 07:47 PM (This post was last modified: 01-16-2016 07:55 PM by Ángel Martin.)
RE: SandMath incomplete beta function broken?
(01-16-2016 07:25 PM)quantalume Wrote:  I don't have room in my NoV64 for the 32K monster that the latest SandMath has become, so I was wondering if someone with a 41CL could see if the function has been fixed. You can use the example from the manual:
PI
1
E^X
0.7
XEQ “ICBT“
->0.029623046
Thanks.
Works for me ;-? I just sent you the latest MOD files, you may have a version mismatch somewhere...?
01-17-2016, 01:34 AM
(01-16-2016 07:47 PM)Ángel Martin Wrote:  Works for me ;-? I just sent you the latest MOD files, you may have a version mismatch somewhere...?
OK, it looks like it was fixed somewhere between versions 9G and 9L. Since I'd like to continue to use the earlier 8K versions, what would be the easiest way to patch the ROM images? Here is, for example what the function looks like in version 9G:
_XR_002.19  B028 00B 050      .FATFUN     ICBT          BB50          ; MCode XROM 00.19  "ICBT"
            BB4F 009 003 002  .FNAME      "ICBT"                      ; 009 003 002 094
ICBT        BB50 1B9 100      ?NC XQ      406E
            BB52 130 175      LDI         175
            BB54 132          A=A+B       P-Q
LB_BB55     BB55 171 192      ?NC GO      645C
            BB57 002          A=0         @R
            BB58 133          JNC  +26    LB_BB7E       BB7E
            BB59 134          UNDEF134
LB_BB5A     BB5A 174          UNDEF174
            BB5B 171 153      ?C GO       545C
            BB5D 11B          JNC  +23    LB_BB80       BB80
            BB5E 131 192      ?NC GO      644C
LB_BB60     BB60 003          JNC  +00    LB_BB60       BB60
            BB61 1A0          A=B=C=0
            BB62 0FD 174      ?NC XQ      5D3F
LB_BB64     BB64 153          JNC  +2A    LB_BB8E       BB8E
            BB65 142          A=A+C       @R
            BB66 124          SELPF       4                           ; Peripheral 4: HP-IL
            BB67 143          JNC  +28    LB_BB8F       BB8F
            BB68 134          UNDEF134
            BB69 120          ?P=Q
            BB6A 1E0          GOTOADR
LB_BB6B     BB6B 007          JC   +00    LB_BB6B       BB6B
            BB6C 080          UNDEF080
            BB6D 124          SELPF       4                           ; Peripheral 4: HP-IL
            BB6E 142          A=A+C       @R
            BB6F 17F          JC   +2F    LB_BB9E       BB9E
LB_BB70     BB70 185 101      ?C XQ       4061
            BB72 11B          JNC  +23    LB_BB95       BB95
            BB73 171 166      ?NC GO      595C
            BB75 1B6          A=A-1       XS
            BB76 087          JC   +10    LB_BB86       BB86
LB_BB77     BB77 171 112      ?NC GO      445C
            BB79 1CE          A=A-C       ALL
            BB7A 071 1A0      ?NC XQ      681C
            BB7C 08D 185      ?C XQ       6123
LB_BB7E     BB7E 106          A=C         S&X
            BB7F 130 177      LDI         177
            BB81 123          JNC  +24    LB_BBA5       BBA5
            BB82 122          A=A+B       @R
            BB83 191 070      ?NC XQ      MSGNO         1C64          ; HP41 SYSTEM ROM 1
            BB85 141 132      ?NC GO      4C50
            BB87 177          JC   +2E    LB_BBB5       BBB5
            BB88 120          ?P=Q
            BB89 11B          JNC  +23    LB_BBAC       BBAC
            BB8A 193          JNC  +32    LB_BBBC       BBBC
            BB8B 000          NOP
            BB8C 177          JC   +2E    LB_BBBA       BBBA
            BB8D 120          ?P=Q
LB_BB8E     BB8E 143          JNC  +28    LB_BBB6       BBB6
LB_BB8F     BB8F 112          A=C         P-Q
            BB90 1CE          A=A-C       ALL
            BB91 071 171      ?C XQ       5C1C
            BB93 1A0          A=B=C=0
            BB94 08D 174      ?NC XQ      5D23
            BB96 132          A=A+B       P-Q
            BB97 177          JC   +2E    LB_BBC5       BBC5
            BB98 120          ?P=Q
            BB99 154          ?R=         6
            BB9A 121 153      ?C GO       5448
            BB9C 143          JNC  +28    LB_BBC4       BBC4
            BB9D 1CC          UNDEF1CC
LB_BB9E     BB9E 00B          JNC  +01    LB_BB9F       BB9F
LB_BB9F     BB9F 22F          JC   -3B    LB_BB64       BB64
            BBA0 000          NOP
            BBA6 012 007 013  .FNAME      "RGSORT"                    ; 012 007 013 00F 012 094
RGSORT      BBA7 21D 122      ?NC GO      4887
You list this as a FOCAL function in the SandMath manual, but does it have some sort of MCODE launcher? How would I replace this with a straight FOCAL function? I think there is enough room without breaking the downstream addresses.
David Brunell
Houston, Texas
01-17-2016, 07:56 AM
(01-17-2016 01:34 AM)quantalume Wrote:  You list this as a FOCAL function in the SandMath manual, but does it have some sort of MCODE launcher? How would I replace this with a straight FOCAL function? I think there is enough room without breaking the downstream addresses.
This may not be as simple as it should, many versions have happened since and I have archived those older source files...
For a 'straight" FOCAL program I'd suggest you use JM Baillard's, which is the same I used in the SandMath. It is posted at the bottom of this page: http://hp41programs.yolasite.com/gamma.php
01-17-2016, 08:49 AM
(01-17-2016 07:56 AM)Ángel Martin Wrote:  This may not be as simple as it should, many versions have happened since and I have archived those older source files...
Ok, perhaps the easiest thing to do is put a FOCAL program of the same name in user memory or HEPAX memory, which sits below the first ROM. This way it will find the replacement program first.
Do you ever break backwards compatibility with Library4 updates? For example, might I have a problem if I'm using an old SandMath44 with the latest Library4?
David Brunell
Houston, Texas
01-17-2016, 03:10 PM (This post was last modified: 01-17-2016 03:11 PM by Ángel Martin.)
In very rare instances that may occur, but not likely. The Lib#4 code has been more or less frozen for a couple of years except a couple of tweaks for the 16C Emulator and the GJM Modules. . It's hard to say 100% since there are so many inter-dependencies.
User(s) browsing this thread:
