Integration issue
10-13-2016, 09:02 PM
Integration issue
Hello
I've got a HP50g and tried to integrate by using RISCH the next expression A*exp(-Ax)*x^2 but the calculator only integrates x^2 and take the rest like a constant. using wolfram should be https://www.wolframalpha.com/input/?i=%E...)+x%5E2+dx any ideas? tried all cas menu's modifications and flags, rpn and algebraic mode Thanks |
10-14-2016, 12:35 AM
RE: Integration issue
Hello, you are missing the * sign between the A and the x.
10-14-2016, 01:16 AM
Thank you so much, it worked and checking rigorous and non-rational in cas modes
