HP Prime Virtual Calculator 20161208 on WINE
02-08-2017, 04:52 PM (This post was last modified: 02-08-2017 04:55 PM by Simone Cerica.)
I can't install HP Prime VC on WINE:
[Image: attachment.php?aid=4464]
[Image: attachment.php?aid=4465]
log:
[002A:002B][2017-02-08T17:28:27]i001: Burn v3.9.1006.0, Windows v6.1 (Build 7601: Service Pack 1), path: Z:\home\gems\Scaricati\HP_Prime_Virtual_Calculator_2016_12_08.exe, cmdline: '-burn.unelevated BurnPipe.{8019D419-5980-4041-8976-FDED636E0779} {99F1255E-2D44-4DA0-8FFD-B339C998B52B} 8 '
[002A:002B][2017-02-08T17:28:27]i000: Setting string variable 'WixBundleLog' to value 'C:\users\gems\Temp\HP_Prime_Virtual_Calculator_20170208172827.log'
[002A:002B][2017-02-08T17:28:27]i000: Setting string variable 'WixBundleOriginalSource' to value 'Z:\home\gems\Scaricati\HP_Prime_Virtual_Calculator_2016_12_08.exe'
[002A:002B][2017-02-08T17:28:27]i000: Setting string variable 'WixBundleOriginalSourceFolder' to value 'Z:\home\gems\Scaricati\'
[002A:002B][2017-02-08T17:28:27]i052: Condition '((VersionNT >= v5.2) AND (ServicePackLevel >= 2)) OR (VersionNT >= v6.0)' evaluates to true.
[002A:002B][2017-02-08T17:28:27]i000: Setting string variable 'WixBundleName' to value 'HP Prime Virtual Calculator'
[002A:0030][2017-02-08T17:28:27]i000: Setting version variable 'WixBundleFileVersion' to value '1.31.11226.0'
[002A:002B][2017-02-08T17:28:27]i100: Detect begin, 2 packages
[002A:002B][2017-02-08T17:28:27]i000: Setting version variable 'MFC120_Version_x86' to value '12.0.21005.1'
[002A:002B][2017-02-08T17:28:27]i101: Detected package: vcredist_x86EXE, state: Absent, cached: None
[002A:002B][2017-02-08T17:28:27]i101: Detected package: PrimeEmulatorMSI, state: Absent, cached: Complete
[002A:002B][2017-02-08T17:28:27]i199: Detect complete, result: 0x0
[002A:0030][2017-02-08T17:28:37]i000: Setting numeric variable 'EulaAcceptCheckbox' to value 1
[002A:002B][2017-02-08T17:28:37]i200: Plan begin, 2 packages, action: Install
[002A:002B][2017-02-08T17:28:37]w321: Skipping dependency registration on package with no dependency providers: vcredist_x86EXE
[002A:002B][2017-02-08T17:28:37]i000: Setting string variable 'WixBundleLog_vcredist_x86EXE' to value 'C:\users\gems\Temp\HP_Prime_Virtual_Calculator_20170208172827_0_vcredist_x​86EXE.log'
[002A:002B][2017-02-08T17:28:37]i000: Setting string variable 'WixBundleRollbackLog_PrimeEmulatorMSI' to value 'C:\users\gems\Temp\HP_Prime_Virtual_Calculator_20170208172827_1_PrimeEmula​torMSI_rollback.log'
[002A:002B][2017-02-08T17:28:37]i000: Setting string variable 'WixBundleLog_PrimeEmulatorMSI' to value 'C:\users\gems\Temp\HP_Prime_Virtual_Calculator_20170208172827_1_PrimeEmula​torMSI.log'
[002A:002B][2017-02-08T17:28:37]i201: Planned package: vcredist_x86EXE, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: None, cache: Yes, uncache: No, dependency: None
[002A:002B][2017-02-08T17:28:37]i201: Planned package: PrimeEmulatorMSI, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: No, uncache: No, dependency: Register
[002A:002B][2017-02-08T17:28:37]i299: Plan complete, result: 0x0
[002A:002B][2017-02-08T17:28:37]i300: Apply begin
[0008:0009][2017-02-08T17:28:37]i360: Creating a system restore point.
[0008:0009][2017-02-08T17:28:37]i362: System restore disabled, system restore point not created.
[0008:0009][2017-02-08T17:28:37]i000: Caching bundle from: 'C:\users\gems\Temp\{45f6fe44-8e06-48ed-9cea-b9a5a99ce995}\.be\HP_Prime_Virtual_Calculator.exe' to: 'C:\users\Public\Application Data\Package Cache\{45f6fe44-8e06-48ed-9cea-b9a5a99ce995}\HP_Prime_Virtual_Calculator.exe'
[0008:0009][2017-02-08T17:28:38]i320: Registering bundle dependency provider: {45f6fe44-8e06-48ed-9cea-b9a5a99ce995}, version: 1.31.11226.0
[0008:002F][2017-02-08T17:28:38]i305: Verified acquired payload: vcredist_x86EXE at path: C:\users\Public\Application Data\Package Cache\.unverified\vcredist_x86EXE, moving to: C:\users\Public\Application Data\Package Cache\DF7F0A73BFA077E483E51BFB97F5E2ECEEDFB6A3\vcredist_x86.exe.
[0008:002F][2017-02-08T17:28:38]i304: Verified existing payload: PrimeEmulatorMSI at path: C:\users\Public\Application Data\Package Cache\{CD086760-4BF3-4EDF-8BA4-00224DFB941E}v1.31.11226.0\PrimeEmulator.msi.
[0008:0009][2017-02-08T17:28:38]i301: Applying execute package: vcredist_x86EXE, action: Install, path: C:\users\Public\Application Data\Package Cache\DF7F0A73BFA077E483E51BFB97F5E2ECEEDFB6A3\vcredist_x86.exe, arguments: '"C:\users\Public\Application Data\Package Cache\DF7F0A73BFA077E483E51BFB97F5E2ECEEDFB6A3\vcredist_x86.exe" /q /norestart -burn.ancestors={45f6fe44-8e06-48ed-9cea-b9a5a99ce995}'
[0008:0009][2017-02-08T17:28:38]e000: Error 0x80070538: Failed to create the security descriptor for the connection event and pipe.
[0008:0009][2017-02-08T17:28:38]e000: Error 0x80070538: Failed to create embedded pipe.
[0008:0009][2017-02-08T17:28:38]e000: Error 0x80070538: Failed to run bundle as embedded from path: C:\users\Public\Application Data\Package Cache\DF7F0A73BFA077E483E51BFB97F5E2ECEEDFB6A3\vcredist_x86.exe
[0008:0009][2017-02-08T17:28:38]e000: Error 0x80070538: Failed to execute EXE package.
[002A:002B][2017-02-08T17:28:38]e000: Error 0x80070538: Failed to configure per-machine EXE package.
[002A:002B][2017-02-08T17:28:38]i319: Applied execute package: vcredist_x86EXE, result: 0x80070538, restart: None
[002A:002B][2017-02-08T17:28:38]e000: Error 0x80070538: Failed to execute EXE package.
[0008:0009][2017-02-08T17:28:38]i351: Removing cached package: vcredist_x86EXE, from path: C:\users\Public\Application Data\Package Cache\DF7F0A73BFA077E483E51BFB97F5E2ECEEDFB6A3\
[0008:0009][2017-02-08T17:28:38]i330: Removed bundle dependency provider: {45f6fe44-8e06-48ed-9cea-b9a5a99ce995}
[0008:0009][2017-02-08T17:28:38]i352: Removing cached bundle: {45f6fe44-8e06-48ed-9cea-b9a5a99ce995}, from path: C:\users\Public\Application Data\Package Cache\{45f6fe44-8e06-48ed-9cea-b9a5a99ce995}\
[002A:002B][2017-02-08T17:28:38]i399: Apply complete, result: 0x80070538, restart: None, ba requested restart:  No[/quote]
The latest version that I can install on WINE is HP Prime VC 20150617.
P.S. I installed on linux mint cinnamon 18.1 (64 bit) winehq-staging 2.0 and vcrun2013.
Attached File(s) Thumbnail(s)
02-09-2017, 09:41 AM
RE: HP Prime Virtual Calculator 20161208 on WINE
Maybe use a VM to install it and then copy the program files/ folder files?
My website: ried.cl
02-10-2017, 04:45 PM
In the end I did as you suggested, thanks.
