48G won't turn on, any suggestions?
05-23-2017, 05:32 AM
Everything looks good and clean outside. No corroded battery contacts.
I checked batteries with a multimeter. All good.
Tried pressing and twisting the unit a little, nothing works.
Suggestions? Thanks.
05-23-2017, 06:10 AM (This post was last modified: 05-23-2017 06:11 AM by Joe Horn.)
RE: 48G won't turn on, any suggestions?
Try the old trick of pressing the ON key WHILE pressing down on the bezel just below the LCD and just above the B and C keys. It's amazing how many "dead" 48's can be turned on this way.
<0|ΙΈ|0>
-Joe-
05-23-2017, 06:45 AM
(05-23-2017 06:10 AM)Joe Horn Wrote:  Try the old trick of pressing the ON key WHILE pressing down on the bezel just below the LCD and just above the B and C keys. It's amazing how many "dead" 48's can be turned on this way.
Yes that's exactly what I did.
I will try again, with more force...
Any other suggestions if this doesn't work? Last (very last) resort will be to... open it and see...
05-23-2017, 09:45 PM
In my explorations of the general forum I do remember some posts talking about shorting contacts. So you may search this forum using Google ad hoc searches, maybe you get useful hints.
I'm sorry I don't have precise links.
05-23-2017, 11:31 PM
(05-23-2017 09:45 PM)pier4r Wrote:  In my explorations of the general forum I do remember some posts talking about shorting contacts. So you may search this forum using Google ad hoc searches, maybe you get useful hints.
OK thanks, let me see what I can find.
Otherwise... will have to do the POP and SNAP... which I really want to avoid.
