A Replacement for the HP-41 CPU Connector
05-23-2017, 07:00 PM (This post was last modified: 03-02-2021 10:39 PM by mfleming.)
As promised, I've written up my experience in creating and testing a replacement for the HP-41 CPU connector. The whole process came about when dealing with two calculators with bad zebra connectors. Corrosion on a spot in a wrapped wire form of connector prevented a key connection between CPU and main board, while contamination of a foam style connector prevented any operation at all.
Restoring those two calculators to normal operation was my main motivation, as was solving a problem that had also vexed others. I'd like to express my appreciation to those who provided suggestions and a helping hand in testing the solution. Here's hoping the HP-41 is still going strong twenty years from now!
~Mark
Attached File(s)
.pdf  A Replacement for the HP-41 CPU Connector.pdf (Size: 298.09 KB / Downloads: 246)
