Can someone detail the new changes in 7-10-2017 update...
07-15-2017, 01:27 AM
When I updated it mentioned something about using the touchscreen to adjust graphs and that it now updates equations...Some details on this???
07-15-2017, 07:29 AM (This post was last modified: 07-15-2017 07:30 AM by critor.)
RE: Can someone detail the new changes in 7-10-2017 update...
See http://www.hpmuseum.org/forum/thread-868...l#pid76136
And just ignore the update infos about the touchscreen/graph/equations.
They're coming from the html files present in the update zip : http://ftp.ftp.hp.com/pub/calculators/Pr...170710.zip
And it seems those files haven't been updated.
They were showing exactly the same text in last year update.
07-15-2017, 08:20 PM (This post was last modified: 07-15-2017 08:22 PM by Tim Wessman.)
(07-15-2017 07:29 AM)critor Wrote:  See http://www.hpmuseum.org/forum/thread-868...l#pid76136
The html files in the zip belong to "marketing" and so they only get updated when they have items they are interested in highlighting. Hence, only major releases will have that information updated.
The "technical" notes are in the firmware zip only, and not translated. Here is what I left to go in the zip, but seems like it didn't make it in there. I'll figure it out when i get back from holiday in a few days.
Quote:This release of the calculator software brings the HP Prime firmware to the same level as the iOS, Android, macOS, Windows and Windows Store applications.
New Functionality (Calculator Software)
1. Added version information to exam mode start screen to allow easy identification by Proctors.
Resolved issues and changes excluding CAS
1. Resolved issue with SORT and real numbers 0 < X < 1
2. Resolved issue with calling integral from Home with complex lower/upper bounds.
3. Resolved issue with user program and nested RETURN call.
4. Resolved issue with EQ and nesed sublists.
5. Resolved issue with √(1_(MN/m^2)*1_(MPa)) generating an error
6. Resolved issue with split stem stem leaf plots with consecutive empty stems.
I think every one of those fixes can be traced back to a post on this forum (with the exception of the last one).
TW
07-16-2017, 05:02 PM
It appears issue 2 (didn't check the others yet) has not been resolved ???
