Ratio Equation Program
09-08-2017, 11:04 AM (This post was last modified: 09-08-2017 11:44 AM by Gamo.)
Found this program on HP Keys Note newsletter about Ratio Equation
A/B = C/D
With unknown quantity input as Zero and key in the values for A, B, C, and D
Program:
Quote:LBL A
X=0?
GTO1
Rv
X=0?
GTO2
Rv
X=0?
GTO1
Rv
LBL2
Rv
x
RTN
LBL1
Rv
x
X<>Y
RTN
Examples:
13/22 = X/44
13 ENTER 22 ENTER 0 ENTER 44 ---> LBL A = 26
X/22 = 26/44
0 ENTER 22 ENTER 26 ENTER 44 ---> LBL A = 13
Anyone have an idea on how to make this program shorter and
program to work for HP 12C since 12C don't have GTO for goto Label.
Thank You
Gamo
09-08-2017, 11:40 AM
RE: Ratio Equation Program
(09-08-2017 11:04 AM)Gamo Wrote:  Anyone have an idea on how to make this program shorter and
Here is a working program on the 12C:
001 x=0?
002 GTO 14
003 Rv
004 X=0?
005 GTO 10
006 Rv
007 X=0?
008 GTO 14
009 Rv
010 Rv
011 /
012 x
013 GTO 00
014 Rv
015 x
016 X<>Y
017 /
018 GTO 00
Examples:
13/22 = X/44
13 ENTER 22 ENTER 0 ENTER 44 R/S ---> 26
X/22 = 26/44
0 ENTER 22 ENTER 26 ENTER 44 R/S ---> 13
Note: you should not have ENTER after the last number (D) as it would duplicate it in the Y register and you would loose the content of T (A).
09-08-2017, 11:54 AM
Thank You Didier Lachieze
I just edit the last [D] no need to ENTER
Your program work very good I try many difference ratio and it all work
Thanks
Gamo
09-08-2017, 04:09 PM
A shorter version (2 steps less):
001 x=0?
002 GTO 14
003 Rv
004 X=0?
005 GTO 10
006 Rv
007 X=0?
008 GTO 14
009 Rv
010 Rv
011 /
012 x
013 GTO 00
014 +
015 x<>y
016 GTO 06
09-08-2017, 11:32 PM (This post was last modified: 09-08-2017 11:32 PM by Joe Horn.)
Here's an even shorter program that takes the 3 known values, entered on the stack in either clockwise or counterclockwise order, starting from the unknown but skipping it. For example, if this is the equation: \(\frac { 51 }{ 57 } =\frac { 68 }{ x } \), then you'd enter the values either of these two ways:
57 ENTER 51 ENTER 68 [clockwise]
68 ENTER 51 ENTER 57 [counterclockwise]
Then run this program:
001 ÷
002 ÷
Of course, cross-multiplying and then dividing also takes only two operations, but I like the circular input pattern of this RPN-friendly method.
<0|ɸ|0>
-Joe-
