HP41/HP48 Transitions
11-18-2017, 08:46 PM
I just picked a nice copy of the Bill Wickes book "HP 41/HP 48 Transitions." When the book was published, you could write the publisher to get a floppy disc with all of the book's programs on it.
Does anyone have or know where I can get a copy of those programs?
11-19-2017, 02:26 AM (This post was last modified: 11-20-2017 09:33 AM by Giuseppe Donnini.)
RE: HP41/HP48 Transitions
I can only congratulate you on your choice. Every book by Bill Wickes has
given me countless hours of pure enjoyment.
Here are all the programs from the original floppy disk accompanying
"HP-41/HP-48 Transitions". In the root folder you will find one file for each
program, but you should be aware that several file names do not correspond to
the variable names used inside the HP-48, because some characters either are
non-ASCII, like \->, or cannot be used in MS-DOS filenames, like ?. For this
reason the subdirectory BINARY is provided, which holds a single ready-to-use
HP-48 directory object containing all the programs in an appropriate tree
structure.
Since Eric Rechlin recently uploaded to his site the programs from one of Bill
Wickes' other great books ("HP-48 Insights I"), I assume that there are no legal
problems here.
Attached File(s)
.zip  41TO48.zip (Size: 19.13 KB / Downloads: 96)
11-19-2017, 06:09 PM
Thank you so much Giuseppe. I agree with you about Bill Wickes. I wish I had met him.
11-20-2017, 09:15 AM
i am not able to download the file. am i the only one?
I am an happy owner of this book and the disk was missing.
Thanks
Giancarlo
11-20-2017, 09:30 AM
Ciao Giancarlo,
I just tried it again, no problem here.
Besides, the file has been downloaded 30 times already.
So I guess the problem is on your side.
If it doesn't work for you, just leave me a PM with your e-mail address.
