Wanted: HP71b port cover
01-19-2018, 02:45 PM
hi,
I need the four plastic port cover (front side) of the HP 71b.
Is someone has them, please, PM me...
Thank you
Salvo
01-19-2018, 04:24 PM
RE: Wanted: HP71b port cover
Nate's been tweaking the model on Shapeways to the point where we feel it's close enough to the original. The last sample I received didn't snap into the 71 exactly like an original, but perhaps with a little trimming of the detent tab it might be improved.
https://www.shapeways.com/product/KXBVLX...d=63044258
The white plastic can be dyed using fabric dye and there are plenty of instructions that can be found on the web. If you come up with the formula for matching HP's dark brown, please share it.
Dave
01-19-2018, 04:29 PM
(01-19-2018 04:24 PM)Dave Frederickson Wrote:  Nate's been tweaking the model on Shapeways to the point where we feel it's close enough to the original. The last sample I received didn't snap into the 71 exactly like an original, but perhaps with a little trimming of the detent tab it might be improved.
Dave
These 71B port covers Nate designed work well. I too would like to have the same olive/brown to match the 71B case, but until someone cracks the code on how to reliably match the color, black ones will do for me. My next shipment of these should arrive later today, together with a few other parts. Smile Smile
01-19-2018, 04:41 PM
Dave
(01-19-2018 04:29 PM)rprosperi Wrote:  ...
thanks a lot, Dave and Bob!
I'll order from Nate the covers.
Salvo
01-27-2018, 11:38 AM
got them by Shapeways!
they are almost perfect, happy.
Salvo
