Transfer files between HP-71b/PC and then to HP-75c
07-08-2018, 12:53 PM
RE: Transfer files between HP-71b/PC and then to HP-75c
(07-08-2018 08:10 AM)coitboy2000 Wrote:  3. I have a 15 pin female ended (both ends) null model cable; one end connected to the end of the USB to serial cable; the other end to a simple 15pin to 25pin adapter which is connected to the HP-82164A.
I assume these are normal 9-pin connectors? Serial ports are typically 9- or 25- pin; 15-pin connectors (same size d-shell as 9-pin) are for video/VGA.
07-08-2018, 09:45 PM
Sorry, yes standard 9 pin serial connector.
07-09-2018, 09:27 AM
(07-07-2018 02:45 AM)coitboy2000 Wrote:  There are bound to be some errors Smile
Richard
right, minor typo: ... caption of section 2. should read "METHOD 2", not "METHOD 3"...
It is always appreciated if people make write-ups like this available to all of us.
07-09-2018, 10:35 AM
Richard
Thanks, noted.
05-18-2024, 01:35 PM
(07-07-2018 02:45 AM)coitboy2000 Wrote:  I have created some instructions below.
https://www.dropbox.com/s/t0qj0xwkbotms0...B.pdf?dl=0
Richard
Unfortunately doesn't seem to be available anymore - would appreciate it if anyone could show me where to find this file?
Kind Regards,
Jack
