HP NUT CPU is not on Wikipedia
11-16-2018, 06:22 AM
I have browsed wikipedia for insights into the use of the NUT CPU and find that there is no "story" there, as far as I can tell only a dead link. That honestly took me a bit by surprise.
Voyager Series link Does any of you know why that is and should we not change that? I am sure this forum can come up with enough significant facts for me (or someone else) to author a short article on that topic. KimH |
11-16-2018, 07:56 AM
(This post was last modified: 11-16-2018 08:00 AM by Massimo Gnerucci.)
RE: HP NUT CPU is not on Wikipedia
(11-16-2018 06:22 AM)KimH Wrote: I have browsed wikipedia for insights into the use of the NUT CPU and find that there is no "story" there, as far as I can tell only a dead link. That honestly took me a bit by surprise. This should get you started. (You can also pay a visit to TOS for detailed documents) Greetings, Massimo -+×÷ ↔ left is right and right is wrong |
11-16-2018, 09:32 AM
Massimo, that link is sadly deceased.
The service will be held at 404 Apache Ave... |
11-16-2018, 10:30 AM
(This post was last modified: 11-16-2018 10:35 AM by Massimo Gnerucci.)
(11-16-2018 09:32 AM)grsbanks Wrote: Massimo, that link is sadly deceased. Really? That's odd: I can reach it from here. What about this? Greetings, Massimo -+×÷ ↔ left is right and right is wrong |
11-16-2018, 10:33 AM
RE: HP NUT CPU is not on Wikipedia | |||
11-16-2018, 10:38 AM
Just tried again with several browsers and I can confirm my initial finding:
11-16-2018, 10:47 AM
(11-16-2018 07:56 AM)Massimo Gnerucci Wrote:(11-16-2018 06:22 AM)KimH Wrote: I have browsed wikipedia for insights into the use of the NUT CPU and find that there is no "story" there, as far as I can tell only a dead link. That honestly took me a bit by surprise. Thanks a lot, this will help (opened a PDF in less than a second - on my iPad) I was/am also looking for whether we have some stories/anecdotes from HP about why and when this was made - rather than making a good suggestion. Sort of like the CPU is called NUT because 41C had the Codename CocoNUT (I think..) |
11-16-2018, 11:16 AM
(11-16-2018 10:30 AM)Massimo Gnerucci Wrote: Really? That's odd: I can reach it from here. That's better. Thanks. |
11-16-2018, 11:25 AM
That's a weird one. It's obviously a local problem because I logged into a remote server of mine and was able to download the PDF from the original link no trouble.
DNS here resolves the hostname to the same IPv4 address and IPv6 address. The host just replies 404 to me and 200 to everyone else! |
11-16-2018, 03:21 PM
(11-16-2018 10:33 AM)Harald Wrote:(11-16-2018 10:30 AM)Massimo Gnerucci Wrote: Really? That's odd: I can reach it from here. No problem here (USA) --Bob Prosperi |
11-16-2018, 05:09 PM
(11-16-2018 11:25 AM)grsbanks Wrote: That's a weird one. It's obviously a local problem because I logged into a remote server of mine and was able to download the PDF from the original link no trouble. I've had no problems with either the first link or the second link. I'm in the USA, so maybe the different path allow them to work well for me? smp |
11-16-2018, 05:48 PM
11-16-2018, 05:51 PM
(11-16-2018 11:25 AM)grsbanks Wrote: That's a weird one. It's obviously a local problem because I logged into a remote server of mine and was able to download the PDF from the original link no trouble. But within that same ip address it might get internally routed to different load-balancing servers (or VMs?) depending on where your request comes from. I get 404 as well on the first link, the second link works fine. |
11-16-2018, 07:30 PM
(11-16-2018 05:51 PM)Claudio L. Wrote:(11-16-2018 11:25 AM)grsbanks Wrote: That's a weird one. It's obviously a local problem because I logged into a remote server of mine and was able to download the PDF from the original link no trouble. Same for me here from Germany Günter |
11-16-2018, 10:00 PM
Massimo's PDF link works fine for me.
On my Windows 10 machine, tracert produces this output : Code: C:\Windows\system32>tracert hp41.deringenieur.net Jonathan Aeternitas modo est. Longa non est, paene nil. |
11-16-2018, 10:19 PM
Both links work for me (Chicago, USA).
