Woodstock Powered w/o Battery Pack
12-06-2018, 07:22 PM
Can the Woodstock series be powered without the battery pack installed?
12-06-2018, 07:26 PM
RE: Woodstock Powered w/o Battery Pack
Not from the charger w/o battery pack. Will toast the ACT chip
12-06-2018, 07:28 PM
(12-06-2018 07:22 PM)gcmrtin1 Wrote: Can the Woodstock series be powered without the battery pack installed? Yes, but NOT with the supplied charger. Otherwise the delicate circuits will be destroyed by overvoltage. If you want to power it without a battery pack you either cut the cable of the charger and connect it to a 2.5 to 3V regulated DC power supply or you connect that power supply to the battery contacts inside the calculator. Watch the polarity! Regards Max |
12-07-2018, 09:45 PM
RE: Woodstock Powered w/o Battery Pack | |||
