HP 50g Solve on object?
04-29-2019, 09:22 AM
Just purchased a HP50g as I enjoyed using a HP12C and wanted more. I was trying to programmatically use the SOLVE command and I think the following exemplifies what I am trying to do. Say I have a small program like this: « « X 5 + » 'X' SOLVE » The SOLVE command fails on running this program. However, if I use the solver via the menus ("NUM.SLV" and select "1. Solve equation") and enter << X 5 + >> in the equation input the solver correctly returns -5 (screenshot attached). Is there a way I can use the solver in a program on an object <<>> (hopefully I'm using the right terms..)? As a background on why - I created a program for the value of a call option (which would replace <<X 5 +>> above) and wanted to use the solver to back out the implied volatility (one of the inputs to price of call). Thank you! |
04-29-2019, 11:27 AM
(This post was last modified: 04-29-2019 11:27 AM by grsbanks.)
RE: HP 50g Solve on object?
The 50g expects an expression or an equation on level 2, not a program.
So, this works: Code: \<< |
04-29-2019, 12:22 PM
Thanks for the reply! Perhaps I am misusing the solver or there is an alternative method to do what I'm looking for.
This is my program, BSCALL (I've added '->' since I copied it over): Code:
Overall, I'm looking to use the calculator to solve for one of the inputs, volatility, v when BSCALL() = .25. This seems to work when I use the solver via the solver in the menu with these inputs: << 25 30 X .5 .03 BSCALL .25 - >> solves for X = .2069... correct! or this: 'BSCALL(25,30,X,.5,.03) = .25' works too. However, neither of these methods works via the key input on the stack. So in a general sense is there any way in the calculator to solve for one of the inputs of another program (without using the menus)? |
04-29-2019, 04:41 PM
(This post was last modified: 04-30-2019 11:50 PM by Giuseppe Donnini.)
I would rather rely on the good ol' HP-48 routines still present in the HP-50G, and use the ROOT command.
ROOT is the programmable form of HP Solve and takes the following arguments: +---------------+---------------------+------------------------------------------+ | Stack level 3 | 'alg' / << prog >> | 1. An algebraic expression or a program | | | | acting as the current equation. Note | | | | that the variable EQ is *not* used by | | | | ROOT. | | | | | | Stack level 2 | 'global' | 2. The name of the unknown. | | | | | | Stack level 1 | guess / {guesses} | 3. A number or a list of 1, 2, or 3 | | | | numbers acting as initial guess(es). | +---------------+---------------------+------------------------------------------+ Don't forget the third argument! In contrast to its interactive implementation, the programmable version of the root-finder requires you to supply an initial guess. (The HP Solve environment uses a default guess if you don't supply one, which is simply the current value of the unknown variable, if it already exists, or zero, if it doesn't [formal variable]). Note that ROOT only displays a message if an error occurs (Bad Guess(es) or Constant?). As it is not meant to be used interactively, it does not provide intrepretative messages when a root (or extremum) is actually found (Zero, Sign Reversal, or Extremum), nor does it allow you to monitor the root-finding process as during an HP Solve session. Applying this to your example, we get the following program: \<< @ Begin program \<< X 5 + \>> @ Current equation 'X' @ Unknown 0 @ Initial guess ROOT @ Call root-finder \>> @ End program Executing the program puts -5 on stack level 1, just as you wanted. |
04-30-2019, 04:02 PM
That's amazing, thank you!! Works perfectly with my original code too. Thanks again!
04-30-2019, 07:47 PM
(This post was last modified: 04-30-2019 08:09 PM by Gilles.)
(04-29-2019 09:22 AM)iainiain32 Wrote: Hi all, the HP50g is a jewel for me ;D with your example the simplest way is : 'X+5' SOLVEVX in 7 keystrokes ' X+5 ENTER LeftShift S.SVL SOLVEVX result : X=-5 Another example in |R~ mode 'X^3.+7.*X^2.+9.*X-12.' SOLVEVX { 'X=.791287847478' 'X=-3.79128784748' 'X=-4.' } This works for rational expression. for non rational expression you can you the MSLV command. exemple [ '√(x^2+y^2)=5' '√(2*a^2-(2*x+2*y)*a+(x^2+y^2))=3' '√(a^2-2*y*a+(x^2+y^2))=4' ] [ 'x' 'y' 'a' ] [ 3 3 6] @ initial guess MSLV result [ 3.44599325458 3.62286219575 5.65390392093 ] |
04-30-2019, 08:14 PM
But that's not exactly what the original poster wanted. As a matter of fact, SOLVEVX does not work with an equation/expression in the form of a program. So, for the given problem, the best solution is still to use the ROOT command.
04-30-2019, 09:10 PM
(This post was last modified: 04-30-2019 09:14 PM by Gilles.)
**Deleted **
04-30-2019, 09:18 PM
(04-30-2019 08:14 PM)Giuseppe Donnini Wrote: But that's not exactly what the original poster wanted. As a matter of fact, SOLVEVX does not work with an equation/expression in the form of a program. So, for the given problem, the best solution is still to use the ROOT command. You are right. I though UTPN was a equation/expression but it is a command/program. |
