[HP35s] Fastest way to increment a variable
04-29-2019, 03:13 PM (This post was last modified: 05-06-2019 08:56 AM by fred_76.)
Hello
There are several ways to increment an integer variable by 1. But some are faster than others.
First of all, the "most common one", which is the base time :
STO+V
=> takes 37 ms and 2 lines of code
With the slow equations :
EQN 1+V►V
=> takes 125 ms (3.4x slower) but only 1 line of code
The ugly one :
RCL V
1
STO V
=> takes 49 ms (1.3x slower) and 4 lines of code
After an idea of Csaba, the counter is stored in the stat pile (to be recalled by the function [SUMS][n]) :
CLSTK
Σ+
=> takes 37 ms (as fast as the base case), and 2 lines of code, but requires the use of the stat pile and clears the xyzt pile
Note that the CLSTK is required for time effectiveness as Σ+ runs faster when the registers x=y=0. If you want to be more friendly with the pile, use CLx instead of CLSTK, you will loose about 2 ms but it will be better for the pile's health !
If you don't use CLSTK or CLx, the execution time of Σ+ with x,y<>0,0 will take about 42 ms.
The official alternative :
ISG V
Dummy line
=> takes 31 ms (1.2x faster) and 2 lines of code
The unexpected but quite fast one :
RCL V
NOT
STO V
=> only takes 22 ms (1.7x faster) but 4 lines of code, and only works with integers
If you agree to store constants in variables (here 1 in N), then :
RCL N
STO+V
=> only takes 14 ms (2.6x faster) and 2 lines of code, but requires to store the constant 1 in a variable
These are some ways to optimize the execution time on slow machines, like the HP35s, especially if those instructions are repeated hundreds of times.
As a conclusion :
RCL N | STO+V = 14 ms
RCL V | NOT | +/- | STO V = 22 ms
ISG V | Dummy line = 31 ms
CLSTK | Σ+ = 37 ms
1 | STO+V = 37 ms
CLx | Σ+ = 39 ms
Σ+ = 42 ms
RCL V | 1 | + | STO V = 49 ms
EQN 1+V►V = 125 ms
Fred
04-29-2019, 06:18 PM
RE: [HP35s] Fastest way to increment a variable
(04-29-2019 03:13 PM)fred_76 Wrote:  The unexpected and quite fast one :
RCL V
NOT
STO V
Is NOT the bitwise negation operator ? (instead of logical NOT, returning 0, 1)
What range of integers until above not work anymore ? Some 2^n powers ?
If the order NOT +/- is switched, does it decrement the number ?
If true, that make the code *very* unreadable ...
04-29-2019, 06:51 PM (This post was last modified: 04-29-2019 06:57 PM by Csaba Tizedes.)
(04-29-2019 03:13 PM)fred_76 Wrote:  There are several ways to increment an integer variable by 1.
Two notes:
1.) How you measured?
2a.) Please test 0 SUM+ (this increases stat variable n) OR
2b.) 1 SUM+ (this increases stat variable n AND SUMx)
Thanks,
Csaba
04-30-2019, 07:23 AM
(04-29-2019 06:51 PM)Csaba Tizedes Wrote:  2a.) Please test 0 SUM+ (this increases stat variable n) OR
These will both be pretty slow because of the other calculations going on whenever data is added to the statistics.
04-30-2019, 07:56 AM
RCL V
NOT
STO V
Yes, 36-bit bitwise negation.
Quote:What range of integers until above not work anymore ? Some 2^n powers ?
2's complement range [-(2^35), 2^35-1].
Quote:If the order NOT +/- is switched, does it decrement the number ?
Yes. E.g.: "0 +/- NOT" produces -1.
— Ian Abbott
04-30-2019, 08:28 AM (This post was last modified: 04-30-2019 10:47 AM by Csaba Tizedes.)
Yes, it is obvious, but with this you can add and count in one step and you have a possibility to count back and stop without counter==zero condition checking (eg. with an error):
LBL label
  // do something here, which you think is important in your life
  SUM-
  LN
GTO label
BTW: on my 20S 1 STO+ var and 1 SUM+ speed ratio is 2.05, it is good profit for the additional benefits.
Csaba
04-30-2019, 01:18 PM (This post was last modified: 04-30-2019 03:27 PM by fred_76.)
(04-29-2019 06:51 PM)Csaba Tizedes Wrote:  Two notes:
Csaba,
As the HP35s does not have a timer, I had to measure manually with this code :
Z001 LBL Z
Z002 500               *** number of loops, 500 gives a reasonable time ranging from 22 s to about 2 minutes for the slowest functions
Z003 STO I
Z004 123456          *** number entered in accordance to the function to test
Z005 STO X
Z006 654321          *** number entered in accordance to the function to test
Z007 STO Y
Z008 RCL X            *** loop to be repeated 500 times
Z009 RCL Y
Z010 ........            *** I enter here the function to test
Z011 DSE I
Z012 GTO Z008
Z013 RTN
I first measured the time for the empty loop, 10 times and I retain the median time = T0 (=21.80 s)
I then measure the time for the tested function, 5 times, retaining the median time = Tf
The execution time for the tested function is then :
Tef = (Tf-T0)/500*1000 in ms
For example :
function = x²
- Tf = 27.07 s >> Tef = (27.07-21.80)/500*1000=10.54 ms
--- edited ----
[SUM+] is [Σ+] on the HP35S and take 42.1 ms to execute. This is far more than [STO+ var] with 9.1 ms. To recall the number of samples from the stat pile, we have to call the function [n] which takes 4.8 ms to execute, a bit faster than [RCL var] with 5.1 ms.
I tested
Σ+
Time : 63 ms (1.7x slower)
CLSTK
Σ+
Time : 37 ms (as fast as the base case)
Note that Σ+ runs faster when x = 0 (34 ms) and even faster when also y=0 (30 ms) so the CLSTK.
Σ+
Time : 69 ms (1.9 slower)
04-30-2019, 01:26 PM (This post was last modified: 04-30-2019 01:29 PM by fred_76.)
RCL V
NOT
STO V
On the HP35s, it works until you overflow the precision of 12 digits, ie within the range of :
-999 999 999 999 ; +999 999 999 999
04-30-2019, 01:49 PM
(04-30-2019 01:18 PM)fred_76 Wrote:
(04-29-2019 06:51 PM)Csaba Tizedes Wrote:  1.) How you measured?
I had the same question as Csaba and I liked your answer, Fred.
The timing aspect was as interesting to me as the incrementation results themselves.
Thanks!
