The Summing template on the C Key how does it work?
05-11-2019, 11:54 AM
[attachment=7229]Product: HP Prime G2
I tried using The Sum that E for lists with i=0 and infinity sign above and the expression after the = sign.
I put the template on my Home page and added all the parts it did not work.
Does anyone know how to use it
I have tried it in CAS and without CAS still, this function does not operate for me.
Help needed.
[Image: 7116522]
https://h30434.www3.hp.com/t5/Calculator...-p/7116522
[/quote]
05-11-2019, 01:12 PM
RE: The Summing template on the C Key how does it work?
The lower-case (script) i is the constant \( \sqrt{-1} \); use n for your index variable.
Graph 3D | QPI | SolveSys
05-11-2019, 01:21 PM
1. (Lower case) i is a reserved variable,
2. The angle mode should be set to radians,
3. Use == for the comparison.
05-11-2019, 02:57 PM (This post was last modified: 05-11-2019 03:06 PM by tom234.)
Thank you I have done the following, however, the answer is 1.9 It should be
1.5 for pi/2 and the answer should be 1.
I can't do this in a function app. I had to do it in just the regular window under CAS.
Is that where I should be entering it.
05-12-2019, 08:47 AM
It works fine in CAS.
Josep Mollera. HP PRIME, HW: C, SW: 2.2.15157 (2024-09-01).
05-12-2019, 10:50 AM
(05-11-2019 02:57 PM)tom234 Wrote:  Thank you I have done the following, however, the answer is 1.9 It should be
The problem with what is shown in your thumbnail is that the \((2n+1)!\) in the denominator is outside the summation, which is why it still appears in the final answer.
Nigel (UK)
