[Bug] Calculus calculation in xcas
05-17-2019, 05:01 AM (This post was last modified: 05-17-2019 05:04 AM by yangyongkang.)
(i) calculating indefinite integrals
(1)
Xcas can calculate this
int(x^-n,x)
But can't calculate this
int(1/x^n,x)
(2)
Multiple integral questions in this article
(ii) In terms of derivative
(1)
tcollect(laplacian(f(r*cos(theta)*cos(beta),r*cos(theta)*sin(beta),r*sin(theta))​,[r,beta,theta]))
(2)
zeros(diff(f(x,y,z(x,y)),[x,y]),diff(z(x,y),[x,y]))
thank you parisse!
study hard, improve every day
05-28-2019, 02:07 PM (This post was last modified: 05-28-2019 02:09 PM by yangyongkang.)
RE: [Bug] Calculus calculation in xcas
int(e^x*sin(x)^2/(1+sin(x)+cos(x))^2,x)
Xcas can't solve
Wolfram alpha
05-28-2019, 02:51 PM
Xcas can't solve
Wolfram alpha
Seems to work on okay on my Prime virtual and hardware calculators as well as xcas on the computer. It's pretty messy till you use simplify, but it works.
05-28-2019, 10:24 PM
Xcas can't solve
Wolfram alpha
For what it's worth, the TI Nspire can't solve it either!
— Ian Abbott
05-29-2019, 02:51 AM
Select more complex indefinite points and test xcas or hp prime
normal(([int(1/(x^3+x+1), x),
int(sin(a*x)*sin(b*x)*sin(c*x), x),
int((x+x^(1/2)+1)^(1/2), x),
int(exp(-i*x)/cosh(x)^3, x),
int(arctan(x)*ln((x^2+1)*(1/2))/(x+1), x),
int(ln(2*sin((1/2)*x))^2, x),
int(exp(a*x^n), x),
int(x^2/cos(x), x),
int(x*sin(x)*cos(x^2), x),
int(cos(sin(x)^2), x),
int(max(sin(x), cos(x)), x),
 int(1/(sin(x)*sqrt(1+cos(x))), x),
int(sqrt(-x^2+1)*arcsin(x), x),
int(arcsin(sqrt(x))/sqrt(x*(1-x)), x),
int(arccos(x)/(-x^2+1)^(3/2), x),
int(arcsin(x)*(x^2+1)/(x^2*sqrt(-x^2+1)), x),
 int(1/((x-1)^4*sqrt(1/x)), x),
int(x^3/sqrt(-x^2+2*x+1), x),
 int(sqrt(x*(x+1))/(sqrt(x)+sqrt(x+1)), x),
int(1/(1+sqrt(-x^2-2*x+1)), x),
int(1/(x+sqrt(x^2+x+1)), x),
int(sqrt(x^2+x+1)/(x+1), x),
int(sqrt(x/(1+x*sqrt(x))), x),
 int(x/sqrt(1+2^x), x),
int(2^x/sqrt(1+3^x), x),
int(sqrt(1+4*x+sqrt(x)), x),
int(ln(x+1)/(x^2+1), x),
 int(ln(1/2+(1/2)*sqrt(1+4*x))/x, x),
int(x*ln(x/(1-x))/sqrt(-x^2+1), x),
int(1/((x^2+a)*(x^2+b)), x),
int(1/(x^6+x^3+2), x),
int((x-sin(x))/((pi^2+x^2)*x^3), x),
int(1/(x^4+x^2+x+1))]))
05-29-2019, 04:27 AM (This post was last modified: 05-29-2019 04:27 AM by Wes Loewer.)
(05-29-2019 02:51 AM)yangyongkang Wrote:  Select more complex indefinite points and test xcas or hp prime
Actually, the Prime is able to find antiderivatives for some of these, but others not. Of the ones for which it could not, I tried a few on WolframAlpha and it also failed to find the antiderivatives. I didn't bother checking them all. Are there any of these that you listed that another CAS solves but Prime does not? Some functions simply don't have antiderivatives that can be expressed in closed form.
You can't blame the Prime/xcas for not finding something that's not there.
05-29-2019, 05:08 AM
[suggestion] supports region integration and Boolean functions
For example, to calculate the area of a circle, we can do this
int(int(when(x^2+y^2<=r^2,1,0),x,-r,r),y,-r,r)
but not support
05-29-2019, 05:10 AM
This is just testing, not comparing, because these examples are complicated
06-14-2019, 08:34 AM
The problem is not solved, there is a new fixed point problem
10-25-2019, 09:25 AM
hello, every one.I am back again. The unhappy thing is that these bugs are still not solved, new firmware is coming out, I hope the new CAS version can solve these problems.
