NewRPL: Draw commands
06-06-2019, 01:38 PM (This post was last modified: 06-06-2019 01:52 PM by compsystems.)
Hello, it would be very interesting to incorporate drawing commands to motivate more users to use NewRPL.
For example
TI-Nspire: DrawArc 20, 20, 100, 100, 0, 90
NewRPL: 20 20 100 100 0 90 DrawArc
TI-Nspire:
xlist := {0, 200, 150, 0}
ylist := {10, 20,150, 10}
DrawPoly xlist, ylist
NewRPL:
{0, 200, 150, 0} 'xlist' STO
{10, 20, 150, 10} 'ylist' STO
xlist ylist DrawPoly
Source
https://education.ti.com/html/webhelp/EG...ommand.htm
Another option is to adapt Python graphics syntax to RPL
[Image: 1558613789XsIikoU_1_.png]
PHP Code:
def modf(a,b):
  return
a-b*int(a/b)
def rosace(n=12,r=31,v=True):
o=0.
  ne
=n+(n%2)
a=360/n
  l
=r*sin(a*pi/360)
  for
d in range(n):
    if
v:
avance  r
      avance
-r
      tourne_gauche  a
/2
      avance  r
      avance
-r
      tourne_gauche
-a/2
for k in range(ne):
avance  l
      tourne_gauche a
/(1+((n!=ne) and ((k==ne/2-1) or (k==ne-1))))
tourne_gauche a
def demo
(n):
efface
  leve_crayon
  avance  0
  pas_de_cote
-3
  baisse_crayon
  rosace
(n,32
06-06-2019, 02:25 PM (This post was last modified: 06-06-2019 02:26 PM by JoJo1973.)
RE: NewRPL: Draw commands
If you look the sources on Sourceforge you'll see that a sophisticated graphical library is in the making.
So, keep the faith! Wink
06-06-2019, 02:54 PM (This post was last modified: 06-06-2019 02:54 PM by compsystems.)
(06-06-2019 02:25 PM)JoJo1973 Wrote:  If you look the sources on Sourceforge you'll see that a sophisticated graphical library is in the making.
ok
What would be the port to newRPL language of the previous code?
