(HP-65) Distance, Speed and Time
07-16-2019, 10:11 AM (This post was last modified: 07-16-2019 10:44 AM by Gamo.)
Going through HP-65 Owner's Handbook and noticed some error located on
page 88 about on how to use Flags in program.
The program is use to solve for Distance, Speed and time.
The error is located in [LBL] B under [TF1] should insert [STO] [1] [RTN]
Page 90
Example #3 the answer is not right and should be 4482.8333
Remark: I'm not sure if this is a real error or my mistake.
I do not have a real HP-65
I try to adapt this program to work on HP-11C
Flags on HP-65 skip two steps if false and it is difference on HP-11C
Procedure: FIX 4
[A] Initialize
[B] Distance
[C] Speed
[D] Time
[E] Calculate
Procedure is the same as shown in the HP-65 Owner's Handbook
Here is the program: Distance, Speed, and Time for HP-11C
LBL A  // Initialize
SF1
CLx
RTN
LBL B  // Distance
STO 1
F1
RTN
RCL 2
RCL 3
x
RTN
LBL C  // Speed
STO 2
F1
RTN
RCL 1
RCL 3
RTN
LBL D  // Time
->H
STO 3
F1
RTN
RCL 1
RCL 2
->H.MS
RTN
LBL E  // Calculate
CF1
RTN
Gamo
07-16-2019, 01:14 PM (This post was last modified: 07-16-2019 02:11 PM by teenix.)
RE: (HP-65) Distance, Speed and Time
(07-16-2019 10:11 AM)Gamo Wrote:  Going through HP-65 Owner's Handbook and noticed some error located on
Page 90
Procedure: FIX 4
[A] Initialize
[B] Distance
[C] Speed
[D] Time
[E] Calculate
LBL A  // Initialize
SF1
CLx
RTN
LBL B  // Distance
STO 1
F1
RTN
RCL 2
RCL 3
x
RTN
LBL C  // Speed
STO 2
F1
RTN
RCL 1
RCL 3
RTN
LBL D  // Time
->H
STO 3
F1
RTN
RCL 1
RCL 2
->H.MS
RTN
LBL E  // Calculate
CF1
RTN
Gamo
Hi Gamo,
Your Label B code may be wrong, modified follows...
LBL
B
f
STO 1
RTN
RCL 2
RCL 3
x
RTN
Your 4482.8333 answer was correct.
After running the code, here is the program trace from my HP65 emulator for Example 3...
  1.      LBL
  2.      A
  3.      f
  4.      -   // SF1
  5.      f
  6.      CHS   // clr STK
  7.      DSP
  8.      .
  9.      4
 10.      RTN
 21.      LBL
 22.      C
 23.      f
 24.      +   // TF1
 25.      STO 2
 26.      RTN
 31.      LBL
 32.      D
 33.      f
 34.      +   // TF1
 35.      GTO
 36.      1
 43.      LBL
 44.      1
 45.      f-1
 46.      3   // ->D.MS
 47.      STO 3
 48.      RTN
 49.      LBL
 50.      E
 51.      f-1
 52.      -   // SF1
 53.      RTN
 11.      LBL
 12.      B
 13.      f
 14.      +   // TF1
 17.      RCL 2
 18.      RCL 3
 19.      x
 20.      RTN
cheers
Tony
07-17-2019, 01:34 AM
Hello Teenix
Under [LBL] B is missing [STO] 1
Thanks for the correction.
Gamo
07-17-2019, 10:07 AM (This post was last modified: 07-18-2019 12:31 PM by PedroLeiva.)
Here my compilation for HP65 with correct keystroke program and examples, from the Owner´s Handbook
Pedro
Attached File(s)
.pdf  RPN 65 SD - Distance, Speed and Time_compressed.pdf (Size: 67.22 KB / Downloads: 25)
