Natural logarithm of 2 [HP-15C/HP-42S/Free42 & others]
10-12-2019, 12:32 AM
My goal is finding a fast and short way to compute the natural logarithm of 2 on the HP-15C and other RPN calculators like the HP-42S, without using any built-in function (LN, LOG, ATANH...). By fast I mean under 10 seconds on the HP-15C for maximum possible precision. By short I mean no more than 30 or 40 RPN steps.
I have provided two RPN programs and a Decimal BASIC program. The latter avoids any multiplication operations inside the loop, except for the two necessary divisions. I would like to have tried it on the HP-11C which is slightly faster, but currently I have none. Later I will post the (partially original) formula I have used, in case it is not so obvious from the listings. You are invited to contribute code for other RPN calculators (HP-41C, HP-32S, HP-12C...), based on this algorithm or improved versions thereof, or based on more efficient ones (plenty of formulas in the above hyperlink). Pseudo code and short BASIC programs are also welcome. Thanks in advance for your interest and contribuitions. Gerson. ====================================== HP-15C ====================================== 001- 42 21 11 f LBL A 002- 44 25 STO I 003- 4 4 004- 20 × 005- 1 1 006- 40 + 007- 44 1 STO 1 008- 0 0 009- 44 0 STO 0 010- 42 21 0 f LBL 0 011- 45 40 1 RCL + 1 012- 45 25 RCL I 013- 43 11 g x² 014- 34 x↔y 015- 10 ÷ 016- 45 25 RCL I 017- 45 40 25 RCL + I 018- 43 11 g x² 019- 43 36 g LSTx 020- 30 - 021- 15 1/x 022- 44 40 0 STO + 0 023- 34 x↔y 024- 42 5 25 f DSE I 025- 22 0 GTO 0 026- 45 40 1 RCL + 1 027- 15 1/x 028- 45 40 0 RCL + 0 029- 43 32 g RTN 4 f A -> 0.6931471808 ( ~ 8.5 seconds ) 5 f A -> 0.6931471805 ( ~ 10.0 seconds ) ====================================== HP-42S/Free42 ====================================== 00 { 48-Byte Prgm } 01▸LBL "Ln2" 02 RCL ST X 03 4 04 × 05 1 06 + 07 0 08 STO 00 09▸LBL 00 10 RCL+ ST Y 11 RCL ST Z 12 X↑2 13 X<>Y 14 ÷ 15 RCL ST Z 16 STO+ ST X 17 X↑2 18 RCL- ST L 19 1/X 20 STO+ 00 21 R↓ 22 DSE ST Z 23 GTO 00 24 + 25 1/X 26 RCL+ 00 27 END 6 XEQ Ln2 -> 0.69314718056 ( ~ 2 seconds, HP-42S ) 16 XEQ Ln2 -> 0.6931471805599453094172321214581766 ( Free42 ) ====================================== Decimal BASIC ====================================== OPTION ARITHMETIC DECIMAL_HIGH ! Log(2) INPUT PROMPT "Number of decimal places: ":nd LET t = TIME LET k = CEIL(ND/LOG(8)) LET n = k*k LET m = 2*k - 1 LET c = 8 LET d0 = c*(k - 2) + 10 LET d1 = 2*k*(2*k - 1) LET d2 = 4*k + 1 LET s1 = 0 LET s2 = 0 FOR i = 1 TO k LET s1 = s1 + 1/d1 LET d1 = d1 - d0 LET d0 = d0 - c LET s2 = n/(s2 + d2) LET n = n - m LET m = m - 2 NEXT i LET s2 = 1/(s2 + d2) LET r = TIME - t LET r$ = STR$(s1 + s2) PRINT " "; PRINT r$(0:1); FOR i = 2 TO nd + 1 PRINT r$(i:i); IF MOD((i - 1),10) = 0 THEN PRINT " "; IF MOD((i - 1),50) = 0 THEN PRINT " "; END IF NEXT i IF MOD (i - 2,50) <> 0 OR nd = 0 THEN PRINT PRINT "Runtime: "; PRINT USING "0.##": r; PRINT " seconds" END Number of decimal places: 1000 .6931471805 5994530941 7232121458 1765680755 0013436025 5254120680 0094933936 2196969471 5605863326 9964186875 4200148102 0570685733 6855202357 5813055703 2670751635 0759619307 2757082837 1435190307 0386238916 7347112335 0115364497 9552391204 7517268157 4932065155 5247341395 2588295045 3007095326 3666426541 0423915781 4952043740 4303855008 0194417064 1671518644 7128399681 7178454695 7026271631 0645461502 5720740248 1637773389 6385506952 6066834113 7273873722 9289564935 4702576265 2098859693 2019650585 5476470330 6793654432 5476327449 5125040606 9438147104 6899465062 2016772042 4524529612 6879465461 9316517468 1392672504 1038025462 5965686914 4192871608 2938031727 1436778265 4877566485 0856740776 4845146443 9940461422 6031930967 3540257444 6070308096 0850474866 3852313818 1676751438 6674766478 9088143714 1985494231 5199735488 0375165861 2753529166 1000710535 5824987941 4729509293 1138971559 9820565439 2871700072 1808576102 5236889213 2449713893 2037843935 3088774825 9701715591 0708823683 6275898425 8918535302 4363421436 7061189236 7891923723 1467232172 0534016492 5687274778 2344535347 Runtime: 0.32 seconds |
10-12-2019, 11:04 AM
RE: Natural logarithm of 2 [HP-15C/HP-42S/Free42 & others]
Hi !
Here is an HP-41 version: 01 LBL "LN2" 02 1 03 STO 00 04 2 05 STO 01 06 1/X 07 LBL 01 08 RCL 01 09 RCL 00 10 ST/ Y 11 1 12 + 13 STO 00 14 * 15 ST+ X 16 STO 01 17 1/X 18 + 19 X#Y? 20 GTO 01 21 END (32 bytes) It takes about 13 seconds with an HP-41 which gives 0.6931471808 So, an error of about 2 E-10 ( and perhaps a little too slow ) But with free42, the result 6,931471805599453094172321214581773e-1 is returned in much less than 1 second. Best regards. |
10-12-2019, 12:22 PM
(10-12-2019 12:32 AM)Gerson W. Barbosa Wrote: Number of decimal places: 1000 For comparison, the HP 50g with LongFloat returns the result above (except for the last digit being 8) in 637 seconds. |
10-12-2019, 12:47 PM
(This post was last modified: 10-12-2019 12:49 PM by Paul Dale.)
The WP 34S algorithm for logarithms might be appropriate here:
Code: /* Natural logarithm. Either use an argument of 2 directly or take advantage of \( \frac{\sqrt{2} - 1}{\sqrt{2} + 1} = 3 - 2 \sqrt{2} \). Pauli |
10-12-2019, 01:30 PM
Perhaps the methods used here may be of interest.
http://elib.mi.sanu.ac.rs/files/journals...tm1212.pdf |
10-12-2019, 04:18 PM
(This post was last modified: 10-12-2019 04:19 PM by Gerson W. Barbosa.)
(10-12-2019 11:04 AM)JMBaillard Wrote: Hi ! Hello, Jean-Marc, Very concise program! Here is another one, based on formula #20 at MathWorld (not what I’ve been using). 01 LBL "LN2" 02 0 03 3 04 STO 00 05 9 06 STO 01 07 LBL 00 08 * 09 1/X 10 + 11 2 12 ST+ 00 13 RDN 14 9 15 ST* 01 16 RDN 17 RCL 00 18 RCL 01 19 DSE T 20 GTO 00 21 2 22 ST* T 23 R^ 24 + 25 3 26 / 27 END 9 XEQ LN2 -> 0.6931471807 (6.5 seconds on my HP-41C) I am sure this can be optimized for size, but the lack of recall arithmetic is always a problem to me. Best regards, Gerson. |
10-12-2019, 07:30 PM
Hello Gerson,
thank you for the link, I didn't know this forrmula ! Here is another HP41-version: 01 LBL "LN2" 02 CLX 03 STO 00 04 SIGN 05 STO 01 06 LBL 01 07 RCL 01 08 9 09 * 10 STO 01 11 RCL 00 12 1 13 + 14 STO 00 15 ST+ X 16 LASTX 17 + 18 * 19 1/X 20 + 21 X#Y? 22 GTO 01 23 ST+ X 24 3 25 / 26 END (37 bytes) The HP41 returns 0.6931471807 in 5.1 seconds and free42 gives 0,693147180559945309417232121458174 Best regards, JM. |
10-12-2019, 10:20 PM
(This post was last modified: 10-13-2019 12:15 AM by Gerson W. Barbosa.)
Here is an HP-41 equivalent of my previous HP-15C and HP-42S programs:
01 LBL "LN2" 02 RCL X 03 4 04 * 05 1 06 + 07 0 08 STO 00 09 LBL 00 10 RCL Y 11 + 12 RCL Z 13 X^2 14 X<>Y 15 / 16 R^ 17 ST+ T 18 X<> T 19 X^2 20 ST- L 21 X<> L 22 1/X 23 ST- 00 24 RDN 25 DSE Z 26 GTO 00 27 + 28 1/X 29 RCL 00 30 + 31 END 4 XEQ LN2 -> 0.6931471808 ( ~ 2.9 seconds ) 5 XEQ LN2 -> 0.6931471805 ( ~ 3.5 seconds ) P.S.: For the sake of completeteness, here is the formula I've been using: \[\ln (2)\approx \sum_{n=1}^{k}\frac{1}{2n\left ( n+1 \right )}+\frac{1}{4k+1+\frac{1}{4k+1+\frac{4}{4k+1+\frac{9}{4k+1+\frac{\ddots }{ 4k+1+\frac{k^{2}}{4k+1}}}}}}\] The known series together with this continued fraction correction terms yield about 2.09 digits per k. This comes from sheer observation, thus being provided with no proof. However, it appears to hold. |
10-12-2019, 10:22 PM
(This post was last modified: 11-12-2019 08:32 PM by toml_12953.)
Here's a Python program modeled after the Decimal BASIC version but it doesn't have extended precision. I'm new to Python and don't know how to get the most out of it.
Code: def log_2(): Tom L Cui bono? |
10-12-2019, 11:16 PM
(10-12-2019 10:22 PM)toml_12953 Wrote: Here's a Python program modeled after the Decimal BASIC version but it doesn't have extended precision. I'm new to Python and don't know how to get the most out of it. Decimal BASIC is easy to use, but it’s limited to only 1000 digits. I’ve noticed this algorithm produces about 2.09 digits per iteration, hence the use of ln(8) in the estimation of the required number of iterations for a given number of digits. |
10-13-2019, 01:56 AM
(This post was last modified: 10-13-2019 04:18 PM by Albert Chan.)
Here is HP-71B code to calculate log(2)
Line 10: the code actually do log(8), with guess = 2 Line 20: Y = SINH(X-2) ≈ (X-2) + (X-2)^3/3! + (X-2)^5/5! + (X-2)^7/7! Line 30: Y = EXP(2) * EXP(X-2) = EXP(X) Line 40: cubically convergent iterations for LOG(N) Code: 10 N=8 @ X=2 @ E2=EXP(2) >RUN .69313326289 .69314718056 Ref: http://rnc7.loria.fr/brent_invited.pdf, page 20 Ref: https://pdfs.semanticscholar.org/2db2/10...5e12fe.pdf |
10-13-2019, 02:07 AM
(10-12-2019 12:22 PM)John Keith Wrote:(10-12-2019 12:32 AM)Gerson W. Barbosa Wrote: Number of decimal places: 1000 Considering 0.32 seconds was achieved on a 2.6 GHz, that’s pretty good on the HP-50g @ 125 Mhz or so and one emulation layer. |
10-13-2019, 02:12 AM
(10-12-2019 04:18 PM)Gerson W. Barbosa Wrote: Here is another one, based on formula #20 at MathWorld (not what I’ve been using). This looks to be the same as the method the 34S uses but calculating the series at x=2 directly (i.e. without the prescaling). Pauli |
10-14-2019, 07:49 PM
HP 50g:
200 -> 0.69314718055994530941723212145817656807550013436025 52541206800094933936219696947156058633269964186875 42001481020570685733685520235758130557032670751635 07596193072757082837143519030703862389167347112335 ( 350 seconds ) |
11-08-2019, 03:18 PM
(This post was last modified: 11-09-2019 02:29 AM by Albert Chan.)
Using Pi and AGM to get log(2): see http://rnc7.loria.fr/brent_invited.pdf, page 32
\(\large log(2^n) = \frac{\pi/2}{AGM(1, \frac{4}{2^n})} \left(1 + O(\frac{1}{2^{2n}}) \right)\) Big enough n so that error term may be ignored. Assume O(1/4^n) = 1/4^n : 1/4^n < 1e-12 n ≥ 12 / log10(4) ≥ 19.93 Casio FX-115MS, with n = 20: A=1 B=2^-18 C=A+B : B=√AB : A=C/2 : A-B ==== → 0.4980487824 ==== → 0.2197274566 ==== → 0.0525527223 ==== → 0.0030466068 ==== → 0.0000102395 ==== → 0.0000000001 Convergence close to quadratic. With final A,B, we have log(2) ≈ pi/(n(A+B)) = 0.693147180558, under-estimated 2e-12 Update: More precise calculations shows that n=20 over-estimated log(2) by 2e-12 Below suggested relative error term O(1/4^n) ≈ 1/4^(n-1) python> from gmpy2 import * python> f = lambda n: const_pi() / (2 * n * agm(1, 4/2**n)) python> for n in range(20, 25): print n, "%.15g" % f(n) ... 20 0.693147180562285 21 0.693147180560532 22 0.693147180560093 23 0.693147180559982 24 0.693147180559955 |
11-09-2019, 05:27 PM
(11-08-2019 03:18 PM)Albert Chan Wrote: Using Pi and AGM to get log(2): see http://rnc7.loria.fr/brent_invited.pdf, page 32 Interesting, even though it requires \(\pi\). Because I’m lazy I’ll take the wp34s for this one: 001 LBL A 002 # π 003 RCL Y 004 # 002 005 - 006 # 1/2 007 STO+ X 008 DSE Y 009 BACK 002 010 STO* Z 011 STO+ X 012 INC Y 013 AGM 014 RCL* T 015 / 016 END 20 A -> 0.6931471805622850 2 LN - -> 2.33975581274e-12 40 A 2 LN - -> 2.210713576e-24 62 A 2 LN - -> 0 2^x would’ve saved a few steps, but I want to avoid the use of logarithms in the program. |
11-11-2019, 06:14 PM
(11-08-2019 03:18 PM)Albert Chan Wrote: Update: More precise calculations shows that n=20 over-estimated log(2) by 2e-12 n = 1663 will be enough for 1000 digits: -------------------------------------------------------- OPTION ARITHMETIC DECIMAL_HIGH LET n = 1663 LET nd = 1000 PRINT "Log(2) = " LET t = TIME LET p = 2^(n - 3) LET d = PI*p LET a = 1 LET b = p + p FOR i = 1 TO 20 LET c = a LET a = (a + b)/2 LET b = SQR(b*c) NEXT i LET g = d/(a*n) LET r = TIME - t LET r$ = STR$(g) PRINT "0"; PRINT r$(0:1); FOR i = 2 TO nd + 1 PRINT r$(i:i); IF MOD((i - 1),10) = 0 THEN PRINT " "; IF MOD((i - 1),50) = 0 THEN PRINT " "; END IF NEXT i IF MOD (i - 2,50) <> 0 OR nd = 0 THEN PRINT PRINT "Runtime: "; PRINT USING "0.##": r; PRINT " seconds" END -------------------------------------------------------- Log(2) = 0.6931471805 5994530941 7232121458 1765680755 0013436025 5254120680 0094933936 2196969471 5605863326 9964186875 4200148102 0570685733 6855202357 5813055703 2670751635 0759619307 2757082837 1435190307 0386238916 7347112335 0115364497 9552391204 7517268157 4932065155 5247341395 2588295045 3007095326 3666426541 0423915781 4952043740 4303855008 0194417064 1671518644 7128399681 7178454695 7026271631 0645461502 5720740248 1637773389 6385506952 6066834113 7273873722 9289564935 4702576265 2098859693 2019650585 5476470330 6793654432 5476327449 5125040606 9438147104 6899465062 2016772042 4524529612 6879465461 9316517468 1392672504 1038025462 5965686914 4192871608 2938031727 1436778265 4877566485 0856740776 4845146443 9940461422 6031930967 3540257444 6070308096 0850474866 3852313818 1676751438 6674766478 9088143714 1985494231 5199735488 0375165861 2753529166 1000710535 5824987941 4729509293 1138971559 9820565439 2871700072 1808576102 5236889213 2449713893 2037843935 3088774825 9701715591 0708823683 6275898425 8918535302 4363421436 7061189236 7891923723 1467232172 0534016492 5687274778 2344535347 Runtime: 0.08 seconds -------------------------------------------------------- That's one fourth of the time required by my original program based on series combined with a continued fraction. Only 20 iterations here compared to 481 there, but AGM requires the evaluation of one square root per iteration. I'll post later another solution based on a previously suggested algorithm which does it in 0.04 seconds. It would be better to compare those running times on a compiled language, though. |
11-12-2019, 08:30 PM
(11-11-2019 06:14 PM)Gerson W. Barbosa Wrote: Only 20 iterations here compared to 481 there, but AGM requires the evaluation of one square root per iteration. We can lower loop count by 2, and extrapolate for the AGM. (it probably make no difference to the timings though ...) Loop 19 arithmetic mean: c = (a+b)/2 Loop 19 geometric mean: d = √(ab) = √(c^2 - ε^2), where ε = (a-b)/2 Taylor series for √(1+x) = 1 + x/2 - x^2/8 + x^3/16 - 5x^4/128 + ... → d = c * √(1 - (ε/c)^2) ≈ c - ε^2 / (2c) Loop 20 aritmetic mean: AGM ≈ ½(c + d) = c - ε^2 / (4c) = c - (a-b)^2 / (16*c) Code: FOR i = 1 TO 18 |
11-13-2019, 02:47 AM
(11-12-2019 08:30 PM)Albert Chan Wrote:(11-11-2019 06:14 PM)Gerson W. Barbosa Wrote: Only 20 iterations here compared to 481 there, but AGM requires the evaluation of one square root per iteration. Albert Chan, you rock! OPTION ARITHMETIC DECIMAL_HIGH LET n = 1663 LET nd = 1000 PRINT "Log(2) = " LET t = TIME LET p = 2^(n - 3) LET d = PI*p LET a = 1 LET b = p + p FOR i = 1 TO 18 LET c = a LET a = (a + b)/2 LET b = SQR(b*c) NEXT i LET c = (a + b)/2 LET a = c - (a - b)^2/(16*c) LET g = d/(a*n) LET r = TIME - t LET r$ = STR$(g) PRINT "0"; PRINT r$(0:1); FOR i = 2 TO nd + 1 PRINT r$(i:i); IF MOD((i - 1),10) = 0 THEN PRINT " "; IF MOD((i - 1),50) = 0 THEN PRINT " "; END IF NEXT i IF MOD (i - 2,50) <> 0 OR nd = 0 THEN PRINT PRINT "Runtime: "; PRINT USING "0.##": r; PRINT " seconds" END ---------------------------------- Log(2) = 0.6931471805 5994530941 7232121458 1765680755 0013436025 5254120680 0094933936 2196969471 5605863326 9964186875 4200148102 0570685733 6855202357 5813055703 2670751635 0759619307 2757082837 1435190307 0386238916 7347112335 0115364497 9552391204 7517268157 4932065155 5247341395 2588295045 3007095326 3666426541 0423915781 4952043740 4303855008 0194417064 1671518644 7128399681 7178454695 7026271631 0645461502 5720740248 1637773389 6385506952 6066834113 7273873722 9289564935 4702576265 2098859693 2019650585 5476470330 6793654432 5476327449 5125040606 9438147104 6899465062 2016772042 4524529612 6879465461 9316517468 1392672504 1038025462 5965686914 4192871608 2938031727 1436778265 4877566485 0856740776 4845146443 9940461422 6031930967 3540257444 6070308096 0850474866 3852313818 1676751438 6674766478 9088143714 1985494231 5199735488 0375165861 2753529166 1000710535 5824987941 4729509293 1138971559 9820565439 2871700072 1808576102 5236889213 2449713893 2037843935 3088774825 9701715591 0708823683 6275898425 8918535302 4363421436 7061189236 7891923723 1467232172 0534016492 5687274778 2344535347 Runtime: 0.04 seconds My system: Processor: Intel(R) Core (TM)2 Duo CPU E4700 @ 2.6GHz 2.6 GHz 64-bit Operational System |
11-13-2019, 05:40 PM
(This post was last modified: 11-23-2024 01:59 PM by Gerson W. Barbosa.)
Former forum member Mike (Stgt) sent me two RPN programs which give perfect 10-digit and 12-digit results instantaneously on RPN calculators, inspired in Paul Dale's suggestion in message #4 of this thread:
01 LBL "LN2" 02 66 03 2 04 RCL Y 05 1/X 06 Y^X 07 RCL X 08 1 09 ST- Z 10 + 11 / 12 ENTER 13 X^2 14 3 15 ST+ Y 16 / 17 * 18 * 19 ST+ X 20 END That's log(2) = 132*atanh((2^(1/66) - 1)/(1 + 2^(1/66))), evaluated to two terms of the atanh(x) series: 132*((2^(1/66) - 1)/(1 + 2^(1/66)) + 1/3*((2^(1/66) - 1)/(1 + 2^(1/66)))^3) = 0.6931471806, on the HP-41 01▶LBL "LN2" 02 74 03 2 04 RCL ST Y 05 1/X 06 Y^X 07 RCL ST X 08 1 09 STO- ST Z 10 + 11 ÷ 12 ENTER 13 X^2 14 3 15 STO+ ST Y 16 ÷ 17 × 18 × 19 STO+ ST X 20 END That's log(2) = 148*atanh((2^(1/74) - 1)/(1 + 2^(1/74))), evaluated to two terms of the atanh(x) series: 148*((2^(1/74) - 1)/(1 + 2^(1/74)) + 1/3*((2^(1/74) - 1)/(1 + 2^(1/74)))^3) = 0.693147180560, on the HP-42S Inspired in Mike's contribution, I've written two HP-42S programs that give perfect results, either on the HP-42S or on Free42S: --------------------------------------------------- 00 { 52-Byte Prgm } 01▸LBL "Ln2" 02 3 03 2 04 SQRT 05 FP 06 1 07 RCL+ ST L 08 ÷ 09 STO 00 10 X↑2 11 LASTX 12▸LBL 00 13 RCL× ST Y 14 RCL÷ ST Z 15 STO+ 00 16 X<> ST L 17 X<> ST Z 18 SIGN 19 STO+ ST X 20 RCL+ ST L 21 X<> ST Z 22 DSE ST T 23 GTO 00 24 4 25 RCL× 00 26 .END. 6 XEQ Ln2 -> 0,69314718056 (under 2 seconds on the HP-42S) 21 XEQ Ln2 -> 0,6931471805599453094172321214581760 (Free42) 2 LN -> 0,6931471805599453094172321214581766 (Free42) --------------------------------------------------- 00 { 55-Byte Prgm } 01▸LBL "Ln2" 02 3 03 2 04 SQRT 05 SQRT 06 1 07 - 08 2 09 RCL+ ST Y 10 ÷ 11 STO 00 12 X↑2 13 LASTX 14▸LBL 00 15 RCL× ST Y 16 RCL÷ ST Z 17 STO+ 00 18 X<> ST L 19 X<> ST Z 20 SIGN 21 STO+ ST X 22 RCL+ ST L 23 X<> ST Z 24 DSE ST T 25 GTO 00 26 8 ; double this constant after each additional SQRT 27 RCL× 00 28 .END. 4 XEQ Ln2 -> 0,69314718055 (HP-42S) 14 XEQ Ln2 -> 0,6931471805599453094172321214581766 (Free42) 2 LN -> 0,6931471805599453094172321214581766 (Free42) --------------------------------------------------- This approach has allowed me to get 999 correct digits in 0.03s on my computer, with Decimal BASIC: OPTION ARITHMETIC DECIMAL_HIGH LET nd = 1000 PRINT "Log(2) =" LET t = TIME LET k = 298 LET r = TIME - t LET a = SQR(SQR(SQR(SQR(2)))) LET x = (a - 1)/(a + 1) LET d = 1 LET s = x LET a = x*x FOR i = 1 TO k LET d = d + 2 LET x = x*a LET s = s + x/d NEXT i LET s = 32*s LET r = TIME - t LET r$ = STR$(s) PRINT "0"; PRINT r$(0:1); FOR i = 2 TO nd + 1 PRINT r$(i:i); IF MOD((i - 1),10) = 0 THEN PRINT " "; IF MOD((i - 1),50) = 0 THEN PRINT " "; END IF NEXT i IF MOD (i - 2,50) <> 0 OR nd = 0 THEN PRINT PRINT "Runtime: "; PRINT USING "0.##": r; PRINT " seconds" END --------------------------------------------------- Log(2) = 0.6931471805 5994530941 7232121458 1765680755 0013436025 5254120680 0094933936 2196969471 5605863326 9964186875 4200148102 0570685733 6855202357 5813055703 2670751635 0759619307 2757082837 1435190307 0386238916 7347112335 0115364497 9552391204 7517268157 4932065155 5247341395 2588295045 3007095326 3666426541 0423915781 4952043740 4303855008 0194417064 1671518644 7128399681 7178454695 7026271631 0645461502 5720740248 1637773389 6385506952 6066834113 7273873722 9289564935 4702576265 2098859693 2019650585 5476470330 6793654432 5476327449 5125040606 9438147104 6899465062 2016772042 4524529612 6879465461 9316517468 1392672504 1038025462 5965686914 4192871608 2938031727 1436778265 4877566485 0856740776 4845146443 9940461422 6031930967 3540257444 6070308096 0850474866 3852313818 1676751438 6674766478 9088143714 1985494231 5199735488 0375165861 2753529166 1000710535 5824987941 4729509293 1138971559 9820565439 2871700072 1808576102 5236889213 2449713893 2037843935 3088774825 9701715591 0708823683 6275898425 8918535302 4363421436 7061189236 7891923723 1467232172 0534016492 5687274778 2344535343 Runtime: 0.03 seconds Thank you, Pauli and Mike, for your contributions! Gerson. Edited to fix a typo in line 7 of Mike’s first RPN program (RCL X, not RCL Y). Also, 1 E in line 8 has been replaced with 1, as in his second program. That is one byte shorter and doesn’t cause Free42 to show an “Internal Error” message upon execution, when being pasted to it. Somehow Free42 3.1.10 doesn’t accept the constant 1E or 1 E, unless these are entered manually. |
