HP50G on Emu48 : ->Tag for negative numbers
11-17-2019, 11:28 PM
I don't have a HP50G calculator, so that I use the great Emu48 application.
Question : Is it normal that, with the HP50G on EMU48, the ->TAG command adds parentheses to the negative numbers (it does not add these parentheses on HP48-calculator or on HP48-Emu48)? For instance : -5 "AB" ->TAG returns AB-5) (but it returns the clearer expression AB: -5 on HP48). Regards, Gil |
11-18-2019, 12:01 AM
RE: HP50G on Emu48 : ->Tag for negative numbers
Yes, it's the same on the real HP 50g. (Not that surprising, since Emu48 emulates the Saturn CPU running the same code as the real HP 50g. In fact, the real HP 50g also emulates the Saturn CPU.)
— Ian Abbott |
11-18-2019, 07:49 AM
RE: HP50G on Emu48 : ->Tag for negative numbers | |||
11-18-2019, 08:35 AM
(This post was last modified: 11-18-2019 08:39 AM by ijabbott.)
(11-18-2019 07:49 AM)Marco Polo Wrote:(11-18-2019 12:01 AM)ijabbott Wrote: Yes, it's the same on the real HP 50g. (Not that surprising, since Emu48 emulates the Saturn CPU running the same code as the real HP 50g. In fact, the real HP 50g also emulates the Saturn CPU.)Not on mine It does with the latest 2.15 firmware. What version is your HP 50g running? Maybe it depends on flag settings? — Ian Abbott |
11-18-2019, 09:22 AM
(This post was last modified: 11-18-2019 09:24 AM by Marco Polo.)
11-18-2019, 12:16 PM
The extraneous parentheses disappear when flag -79 is turned off (Textbook display mode).
<0|ɸ|0> -Joe- |
11-18-2019, 03:29 PM
(11-18-2019 12:16 PM)Joe Horn Wrote: The extraneous parentheses disappear when flag -79 is turned off (Textbook display mode). Nice find Just to clarify that Textbook mode is actually the opposite of flag -79. If you want to lose Textbook mode and the extraneous parentheses, you have to _set_ flag -79. There are only 10 types of people in this world. Those who understand binary and those who don't. |
11-18-2019, 04:25 PM
As always, HP was "right".
Thanks for your finding. Gil |
11-18-2019, 07:31 PM
